| SLK World Member Join Date: Jun 2007 Location: California
Vehicle: 2006 SLK 350 Iridium Silver | 2007 CLS 63 AMG
Country: Thanks: 4
| There was a DIY posted her a while ago, but I figured since I did one for the CLS last weekend, I need to do one for the wife's car since it was saying Service E Due in 2200 miles. Tools Required : 8mm & 13mm sockets + wrench. Mercedes Oil Filter removal tool (19$ ebay) ![]() Step1: Drive the Car around to warm up the oil , then drive up the Rhino Ramps, (or jack the car up, whatever is your preference) ![]() Step2: Pop the hood and remove the Oil-Fillup Cap and the Oil Filter. This is optional , but I feel like I'm relieving the pressure a bit before draining her out. ![]() Step3: Get under the car armed with our 8mm socket wrench, and remove 6 or so bolts holding the 1st plastic piece in place. Then remove the 2nd plastic piece (there are two bolts very hard to find, close to the wheel wells). You will now see the Oil Drain Pan and the Oil Drain Plug. ![]() ![]() ![]() Step4: Position your Oil Drain container and using the 13mm socket wrench, remove the Oil Drain Plug and let the oil pour out. Go have a snack / watch some TV and let her drip for an hour or so. ![]() Step5:Remove the Oil Filter using the "special mercedes tool" and a 1/2 drive wrench. remove the old filter, clean the encasing and remove the rubber o-rings. Slide in the new filter, and put on the new O-rings provided. (3 in all) ![]() ![]() ![]() ![]() Step6: Get back under the car, Put the Drain Plug bolt back on (don't forget the washer) and wipe the area clean (to check for leaks later) Step7: Pour in about 5qts of new fully synthetic Mercedes-approved Oil. I used Pennzoil 5w-30, since I live in super-sunny yet not that hot California. You can use whatever you prefer, the last time some people had issues with not using mobil1 or not using 0w-40 etc. If you live on the east coast or where its really cold, you may want to use 0w-40. My car, my choice, same with yours. ![]() Step8: Get back under the car and check for leaks. If everything looks good, put the two plastic pieces back on and drive off the Rhino Ramps. This is very important since you want the car totally level before pouring in more oil to avoid incorrect max readings. Step9: Pour more oil and keep checking the oil dipstick to make sure you don't go over the max level indicator. I was able to get almost 8.5 qts in... about 8.3 or so I would guess. Step10: Follow the Service reminder reset procedure and woohoo...you're done! |
Country: Thanks: 135
| That's for the tutorial, very simple and easy to follow instructions.
| Senior SLK World Member Join Date: Nov 2006 Location: Bremen
Vehicle: 2006 SLK 350 AMG Package
Country: Thanks: 9
| Thanks a lot, very good instruction!
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
Country: Thanks: 54
Country: Thanks: 4
| You're welcome everyone, glad to be of help... never done this before on a merc... just used prior knowledge from my Z... the Z filter was worse cause its located underneath the car... also my handy blackberry was small enough to fit in my pocket while i was under the car |
| | #8 (permalink) |
Country: Thanks: 288
| Nicely done, thanks for the detalied pics.
| | #9 (permalink) |
| SLK World Junior Member Join Date: Jan 2008
| Hi, I'm a noob here. I appreciate this great step-by-step tutorial. My problem is oil is leaking (dribbling, seeping, once spurting) from around the lip of the filter housing. I tried over and over to get it right, but I've never done it before. I think I put the "O" rings in the right spots on the assembly. I used a regular filter wrench to loosen and tighten the housing, not the special tool. I can't imagine that would be the issue, though, if the filter was otherwise properly installed. Anyone have thoughts? Thanks. |
| | #10 (permalink) |
| Get another set of o-rings. Take the filter off and try again? Look carefully at the old o-rings to see what might have been pinched, etc. |
| | #11 (permalink) | |
- think that matters? It looks the same on both ends, so I just slid it up there. It doesn't seem to "latch" once it's up there - it can still be rotated. Normal? Also, is it normal for there to be a small amount of "play" around the O rings? The width of the grooves allow the rings a small amount of jiggle/rotation. Would tossing the damn thing and getting a new fleece filter make sense, or would I still have the same issue IYO? The car is actually a SLK320, not 350.Sorry for all the annoying noob questions. It's nice of you to help me | |
| | #12 (permalink) |
Vehicle: SLK55 2006
Country: Thanks: 24
| Sounds like you have the wrong part then. the rings should have no jiggle; on my car, they are actually quite difficult to get on. |
| oil change | mazeka | SLK R171 General Discussion | 1 | 08-25-2008 05:53 PM |
| Oil Change | Connecticut Roy | SLK R171 General Discussion | 24 | 07-06-2008 07:25 PM |
| Quick question, oil gauge shows 9.0L after oil change | cyberdrakon | Ask DansSLK | 8 | 03-06-2008 01:45 PM |
| Oil Change | microbe | SLK R171 General Discussion | 6 | 03-05-2007 03:37 PM |
| oil change | SLeeK350 | SLK R171 General Discussion | 10 | 12-10-2006 08:51 PM |
