SRS Light On - Mercedes Benz SLK Forum
Help and Support Ask and post general questions and how-to's
#1 Old 09-20-2009
Vehicle: '12 SLK 55
Other Toys: Audi SQ5 (with all the toys), Kalkhoff Pro-Connect 'leccy bike
Chats: 2
Quoted: 46 Post(s)
SRS Light On
After a weekend of "spirited" driving around the Lakes and few harder than expected landings, my SRS light and a warning message has come on.
Is this a Dealer only job or is there anything I can do at home? I have an OBDII interface if thats of any use? Can I re-set it? I had a quick look under the seats and I can't see any obvious loose connections but there is such a mess of wires under there I'm not sure what I'm looking for...
Russ
russj is offline
#2 Old 09-20-2009
FOUNDER - SUPER MODERATOR
Vehicle: SLK350 MT
Chats: 1297
Quoted: 114 Post(s)
Do a search on the forum for 'clock spring' - allegedly, it's a little coily spring in your steering wheel that fails on a regular basis and shows up as an SRS prob.
Woolly is offline
#3 Old 09-23-2009
Vehicle: '12 SLK 55
Chats: 2
Quoted: 46 Post(s)
I dropped in to my local indie "Millenium Mercedes" at Dereham and they hooked the car up to their Star machine.
They reset the SRS and told me that it was the wiring connector in the steering column which probably pulled apart slightly after one of my more enthusiastic landings...
Told me to keep an eye on it and if the light returned they could do a mod to the wiring to fix it. He didn't think it would reappear under "normal" use though.
Top service and at no charge! Highly recommended for anyone in the Norfolk area.
They'll be fitting my '55 exhaust for me soon.
Russ
russj is offline
#4 Old 09-23-2009
Vehicle: SLK350 '06
I had the same -- MB dealer diagnosed same as Russj, but fitted a partial new loom (under warranty) to fix.
ipcress is offline
#5 Old 09-23-2009
Quoted: 294 Post(s)
Is this because of the frequent turns on the steering wheel and the rapid change in the lateral G forces?
#6 Old 09-24-2009
Vehicle: '12 SLK 55
Chats: 2
Quoted: 46 Post(s)
Could be but more likely to be the hard landing after I took off over a humpback bridge!
russj is offline
#7 Old 09-24-2009
Vehicle: 05 55 (Brabus 6.1 S)
Chats: 28
Quoted: 7 Post(s)
Pleased you had good service, its always nice to hear but the wiring should be replaced as it is a known defect and will fail again the connectors should not come apart no matter how hard the landing that's why they are all positive locking.
I think it might even be a TSB.
DansSlk is offline
Go Back   Mercedes Benz SLK Forum > Technical Information > Help and Support
Human Verification
SRS light on HwoALanG SLK R171 General Discussion 10 11-12-2015 11:31 AM
2001 R170 Adding footwell lights / Ashtray light ?? toolguy General Modifications R170 6 04-14-2010 05:33 PM
SRS warning light - Warranty hell LynxFX SLK R171 General Discussion 7 08-22-2009 08:51 PM
SRS indicator light Borderwave2 General Discussion 3 10-26-2006 05:00 PM
