| Register | SLK Products | Clubs | Garage | Blogs | Members List | Social Groups | Search | Today's Posts | Mark Forums Read |
| General Modifications R171 Details that make your car different |
#81 (permalink)
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | I have great news everyone!!! Brake flasher module is 100% integrated into my car. No wires cut, 100% reversable. Total install time - 15 min. Here is what the whole thing looks like. I kept the wires long just for testing and will shorten them in the final release. Up close of each connection. Connection to harness: Connection to LED 3rd Brake light: And you are finished. Tuck it all in. Attach the resistor to a point away from any wiring. Close panel... and feel a little safer on the roads I will run it through for a little while just to make sure everything is safe, and there are no issues. Then can start putting the rest together. |
| Sponsored Links | |
| | #82 (permalink) | |
| Founding Member #2 Join Date: Jun 2006 Location: Orange County, CA
Country: Thanks: 1,161
Chats: 5 | Quote:
Thanks for developing and getting the module together.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., Clear sidemarkers & parking lamps w/error-warning-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake. | |
| | #84 (permalink) | |
| Fanatical SLK World Member Join Date: Jun 2006 Location: North Carolina
Vehicle: ///AMG 06
Country: Thanks: 28
Chats: 0 | Quote:
Standard mode Burst Mode Last edited by easty; 08-23-2006 at 02:19 AM. | |
| | #85 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
I want to redo the videos a bit. And will try to find a better host not to take up space on yours. Thanks again! | |
| Sponsored Links | |
| | #86 (permalink) |
| Don - Founding Member #4 Join Date: Jun 2006 Location: Virginia USA
Country: Thanks: 215
Chats: 0 | NoRegret4Life - catch my drift? Are you picking up what I'm putting down? WOW! This is a great mod. The addition of the third brake light (way back when) was a great safety feature. This refines the original concept. More visibility represents greater safety. One day, this will (should) be adopted by all automotive manufacturers. Admit it, you're a mad scientist, trapped in a mind mannered SLK owners body. Make sure I'm on your list when they become available. Thanks for your contributions!
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. -----------------1---------------- --------SLK 55 ///AMG--------- IT'S THE GOOD LIFE, FULL OF FUN! |
| | #87 (permalink) |
Vehicle: 05 55 (Brabus 6.1 S)
Country: Thanks: 350
Chats: 28 | That looks really good noregret mate. Real happy to hear everything went in OK and looks like its all working fine for you.
| | #88 (permalink) |
Chats: 5 | I actually don't mind the slightly longer wire as I was thinking of mounting the module near the green lighted trunk/boot release switch, so I can switch modes as needed. Either way is fine however. I just can't wait. How much heat would the resistor generate as the brake lights are not always on (perhaps 3-4 minutes at the longest at a red traffic light)?
| | #89 (permalink) | |
Vehicle: ///AMG 06
Country: Thanks: 28
Chats: 0 | Quote:
its cool! | |
| | #90 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
The heat from the resistor is not very high at all. Even at constant on in gridlock traffic. The aluminum wrapping you see around it will protect any thing close to it, even plastic or wires. I had 2 of these resistors running my license plate LED bulbs full time, and never had a problem. | |
| Sponsored Links | |
| | #91 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | UPDATE UPDATE!!! -The Kleyman 1 module now features a "Service mode" - simply flip 2 of the mini switches on, and your module returns your 3rd brake light to normal ON operation. I disconnected the resistor just to double check, and received no error in this mode! this means no need for additional bypass switches when you go in for service or inspection. -Also the "Constand flashing" mode (which just keeps flashing the light nonstop) is now adjustable via a mini turn knob on the module. Which means you can adjust the number of flasher/sec. (just for this mode only only) __________________________________________________ ________________________ Ok my friends... i am getting ready to place the next order for modules! Thus far i have seen 7 people interested on this module. Please copy and repost the list below with confirmation and i will place an order for you. "Kleyman 1" 3rd Brake light flasher order: etyu > Confrimed -1- > Confirmed Last edited by noregret4life; 08-23-2006 at 09:37 PM. |
| | #92 (permalink) |
| "Sergeant At Arms" Join Date: Jun 2006 Location: Valrico, Florida
Vehicle: 2009 SLK 55 AMG
Country: Thanks: 144
Chats: 11 | no regret, did you post a price anywhere yet or did i just miss it? I would also like to see a step by step install when you get that far. i installed the vario roof successfully myself so i am not that dumb but that had pictures! you know, remove this screw here, turn that screw there, etc. thanks for the great work!
__________________ Jeff, Retired US Army Master Sergeant 2009 SLK 55 AMG Black/Black Premium 1, Multimedia, Lighting packages Clearshield Protective Film OEM MB Plexiglass Windscreen Eurolight Clear Side Markers Smarttop version 3.22 Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works) Last edited by jbanks15; 08-23-2006 at 10:08 PM. |
| | #93 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
I would expect the price to be around $40 + shipping... how does that sound to everyone, reasonable??? __________________________________________________ ___ "Kleyman 1" 3rd Brake light flasher order: etyu > Confrimed -1- > Confirmed | |
| | #94 (permalink) | |
Vehicle: ///AMG 06
Country: Thanks: 28
Chats: 0 | Quote:
| | #95 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | __________________________________________________ ___ "Kleyman 1" 3rd Brake light flasher order: etyu > Confrimed -1- > Confirmed easty > Confrimed |
| Sponsored Links | |
| | #96 (permalink) |
Chats: 0 |
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. -----------------1---------------- --------SLK 55 ///AMG--------- IT'S THE GOOD LIFE, FULL OF FUN! Last edited by -1-; 08-23-2006 at 11:05 PM. |
| | #97 (permalink) |
Chats: 11 | Great price! etyu > Confrimed -1- > Confirmed easty > Confrimed jbanks15 > Confirmed
__________________ Jeff, Retired US Army Master Sergeant 2009 SLK 55 AMG Black/Black Premium 1, Multimedia, Lighting packages Clearshield Protective Film OEM MB Plexiglass Windscreen Eurolight Clear Side Markers Smarttop version 3.22 Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works) |
| | #98 (permalink) |
Vehicle: '06 slk55
Country: Thanks: 69
Chats: 0 | I'm in! Very nice. Looking forward to it! etyu > Confrimed -1- > Confirmed easty > Confrimed jbanks15 > Confirmed dsb > Confirmed |
| | #99 (permalink) |
| Elite SLK World Member Join Date: Jun 2006 Location: Spring Texas
Country: Thanks: 849
Chats: 59 | SLKman wants one!!!!! I can paypal you or mail the cash to you...either way. Just let me know. |
| | #100 (permalink) | |
| Founding Member #6 Join Date: Jun 2006
Chats: 0 | Quote:
Also, have you considered that the flashing light may cause an epileptic to start a "fit"? Not saying that it would as I have no idea, but just something to think about in "sue for everything" USA. | |
| Sponsored Links | |
| Bookmarks |
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/general-modifications-r171/298-brake-light-flasher.html | ||||
| (Center) 3rd Brake Light Flasher - Page 2 - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 12-07-2006 05:37 PM | |
| (Center) 3rd Brake Light Flasher - Page 2 - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 12-07-2006 03:01 PM | |
| (Center) 3rd Brake Light Flasher - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 10-03-2006 01:10 AM | |
| (Center) 3rd Brake Light Flasher - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 09-19-2006 01:56 AM | |
| White third brake light | bejak | General Modifications R171 | 6 | 09-26-2009 12:09 AM |
| AMG smoked rear light clusters / 3rd brake light. | jfb1977 | Where to get R171 SLK Items | 2 | 07-24-2008 12:40 PM |
| 3rd brake light flasher | st2288 | General Modifications R171 | 21 | 05-23-2008 11:11 AM |
| 3rd Brake light flasher | noregret4life | General Modifications R170 | 30 | 12-21-2007 12:22 PM |
| Fitted the brake light flasher | PAPA | General Modifications R170 | 21 | 11-21-2006 04:47 AM |
