Windrestrictor
Old 10-28-2006   #1 (permalink)
-1-
Don
-1-'s Avatar
Default Aftermarket Bluetooth options
For those without factory Bluetooth, there are many aftermarket options. One is Parrot. I've seen it advertised on eBay along with a Motorola kit. I've held off, but found some new information this evening.
Check Parrot Kits site for some options.
http://www.parrotkits.com/donotcut.html
Here's the best part. http://www.parrotkits.com/steeringwheel.html
Steering Wheel Parrot Harness-Interfaces
For Audi, BMW, Mercedes and VW
Bluetooth Hands-Free that is as good or better than Factory OEM for a lot less cost!
Works with the Parrot 3000 Evolution and replaces the 3000 Evolution controller - so nothing to mount on your dash - Your steering wheel controls everything. Your car looks completely stock but with one
important additon: Bluetooth Hands-Free!
MERCEDES
Fits 2002-2007 C-Class, 2004-2007 CLK, 2002-2007 E-Class, 2005-2007 New Style ML, 2002-2007 SL, and 2002-2007 SLK
Does Not Fit the older ML or the S-Class
How to tell which of the follow 3 kits to order? Simply pull your radio and match up the connector....
Steering Wheel Interface for Mercedes with the 145 Style Connector - Complete Kit
$174.95
Steering Wheel Interface for Mercedes with "145" Style Connector - Complete Kit. This radio is usually in cars with the Audio 5, 20, 50 and Command NAV. The plug at left is included and interfaces with the SW100C Steering Wheel Controller shown below it. Just add the Parrot 3000 Evolution to your order if you don't already have one. Professional Installation is recommended. This product has a 30 Day Money-Back guarantee (less S&H) if you are not delighted.
**NOTE: Before ordering any of the above harnesses, please verify that the plugs at the back of your radio match the plugs on our Before ordering any of the above harnesses, please verify that the plugs at the back of your radio match the plugs on our adapters. If your car has a remote amplifier (JBL, Bose, Mark Levinson, Harmon Kardon, Rockford Fosgate, etc - DO NOT ORDER one of the above adapters unless compatibility is indicated. We now have special models for amplified Mazda, Volvo and Honda vehicles - please write. The QCJBL-1, QCGMCSS-2P, QCFCSS-1P, QCFCSS-2P and HBBH-1 adapters work fine with amplified vehicles
THE MON55TER ON THE BLOCK
View -1-'s Photo Album -1- is online now
Old 10-29-2006   #2 (permalink)
-1- i did have a look around the site and nowhere can i find and info about where this is supposed to connect i guess it would attach at the head unit but the connectors they are showing in the pic are either not for attaching to the head unit itself and the ones with the pins hidden in the background are or this kit wont fit the car because the size of all the MB connectors they are showing is well off the actual connectors size.
I don't have the phone on mine because i ordered the car when no bluetooth was available so it was the MB phone that i would have got and i did not fancy that so i would find a kit like this quite useful if it would add bluetooth and would also save me messing about retrofitting the phone that has a ridiculously stupid harness but from what i have seen this wont fit.
Since it looks like you are keeping an eye on it do you have any other info about it, i might drop the people who make it an e-mail and see what they say or something.
Dan
Old 10-29-2006   #3 (permalink)
Founding Member #7
mtiede's Avatar
Dan,
When I went to the site, there were a couple of connectors for the Benz. Another sef of connectors looked smaller and less complex.
I've tried to attach that picture.
Old 10-29-2006   #4 (permalink)
Founding Member #7
mtiede's Avatar
Picture didn't seem to go after I previewed or edited.
I'll try again here...
Old 10-29-2006   #5 (permalink)
Founding Member #7
mtiede's Avatar
How about I try a link:
http://www.parrotkits.com/144plug.jpg
Old 10-29-2006   #6 (permalink)
-1-
Don
-1-'s Avatar
Dan
Dan, I don't have any further information on this product other than what's provided at the web site. There are several Mercedes harnesses depending on radio. The Harmon Kardon system could be a problem with this kit. Conflicting information regarding this system on their site. If it will work with our cars, it would be a deal at $300. I'll contact them on Monday for a clarification. -1-
Old 10-29-2006   #7 (permalink)
OK thanks guys.
Got a small pic of the COMAND MOST plug and as i am sure you will be able to tell it looks way different from the few harnesses they are showing.
You have the two MOST line interfaces and the then 4 pins and thats all.
Only other place i can think of where you might be able to connect a harness is at the audio gateway but i cant find a harness that looks like it would fit there either.
Old 11-01-2006   #8 (permalink)
HwoALanG's Avatar
Vehicle: 2007 SLK 280
Donation Award
Default nice
ohhh~ finally i can use that phone button !!!!
View HwoALanG's Photo Album HwoALanG is offline
Old 11-01-2006   #9 (permalink)
-1-
Don
-1-'s Avatar
Hold on. DansSLK and I are corresponding with Parrot Kits to determine if this setup will work with the SLK. Should know something soon. I'll post the results.
Old 11-01-2006   #10 (permalink)
HwoALanG's Avatar
Donation Award
k k ~~ let me know mate ~~ and thanks for sharing information~
Old 11-08-2006   #11 (permalink)
-1-
Don
-1-'s Avatar
I haven't heard back from Parrot Kits. DansSLK is suspect whether this will work with the SLK. It's the manufacturers responsibility to makes sure everything works as advertised. In my correspondence with them, they appear less than confident. Many different connectors, Command HK system vs Audio 20, how and where to connect? Something will eventually become available.
Old 12-30-2006   #12 (permalink)
Vehicle: 2007 SLK350
Default Finally, a fix for the faux pas Mercedes made!
Hopefully this will fix the problem for those of us that want bluetooth without being forced to purchase the Command head unit (which I refuse to do). I am not very impressed with the navigation system either.
View SLK_girl's Photo Album SLK_girl is offline
Old 12-31-2006   #13 (permalink)
Founding Member #7
mtiede's Avatar
There are some other very impressive solutions depending on what you want to do without getting the COMAND unit. Somewhere, either on this forum or another SLK forum, someone described a very impressive double din sized, touch screen, GPS, Bluetooth system from Pioneer. However, I'm not sure if that model is available in the US. You might want to poke around and see if that is something you might like instead of COMAND.
Old 12-31-2006   #14 (permalink)
-1-
Don
-1-'s Avatar
The radio you're referring to is the Pioneer AVIC-Z1. Possibly one of two or three of the best multifunction radios currently available. Double DIN with a seven inch touch screen, AM-FM, CD, DVD, MP3, GPS with a hard drive. You can add either Sirius or XM satellite radio with NAV traffic, iPod adapter with full display and control of your iPod, and a Bluetooth adapter for full display and control of calls. I have an older (18 months) version, the AVIC-D1 in another vehicle. You can find the AVIC-Z1 on (eBay) for around $1500, XM tuner is around $140, Bluetooth is $125, iPod is about $90. You could adapt to the SLK with the new Metra double DIN kit. You would have to run new speakers and wire. MB uses fiber optics.
Old 01-01-2007   #15 (permalink)
Founding Member #7
mtiede's Avatar
Yep, that's the model I was thinking of.
ooh... I hadn't realized about the wiring. That wouldn't be so much fun running new wires.
Old 02-01-2007   #16 (permalink)
HWK
SLK World Junior Member
Vehicle: 2007 SLK 55
Other Toys: BMW 745I, TOYOTA SEQUOIA
Thanks to -1-, I purchased CP-147 and CK3000 from Parrot, and ask local parrot dealer installed for me. It works perfectly, you can use telephone on/off button also volume +/-, the sound quality is good. Only you can't use phone list from command center.
View HWK's Photo Album HWK is offline
Old 02-01-2007   #17 (permalink)
the new Pioneer AVIC-D3 is also quite impressive and is already available for as little as $799. I'm most likely going to throw one in my commuter car for the NAV, iPod and Bluetooth functionality.
View Shiny_side_up's Photo Album Shiny_side_up is offline
aftermarket exhaust options for the non amg! bjj007 Performance MODS for the R170 4 09-18-2008 12:37 PM
When you think that you have all the options SLK 55 Kleemann Off Topic 16 04-30-2008 01:31 PM
Adding Aftermarket Bluetooth Phones FishtailnZ Ask DansSLK
