Windrestrictor
LinkBack (2) Thread Tools
Old 10-05-2006   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Vehicle: SLK55 2006
Default So, my question is, what parts are required to enable US R171 COMAND to use AUX video
http://www.benzworld.org/forums/audi...omand-2-a.html
aftermarket, expensive, questionable tech support, requires "TV" button, US stardiagnostic can't program it.
http://www.slkworld.com/general-modi...ehiclehub.html
expensive and complex Alpine system
http://www.benzworld.org/forums/audi...ight=aux+video
Stock MBZ video unit, REQUIRES "TV" button, moderately expensive. intended for w211, but some w211 comand system parts can be integrated with r171.
see also here:
http://www.benzworld.org/forums/r171...highlight=ipod
Dan says:"There is not really any way to integrate the cam into the COMAND for many reasons the biggest being the US spec head unit does not have a video function so it has no way to receive the feed from the cam."
So, my question is, what parts are required to enable US R171 COMAND to use AUX video?
Thanks,
Edward
Old 10-05-2006   #2 (permalink)
Founding Member #8
Vehicle: 2004 SLK350
Easy Peasy - just fit a European spec COMAND unit I honestly think for you guys in the States, unfortunately, it's the only way to get the functionality - unless you swap out the HU for a Pioneer or Alpine, and then if you do, the steeering wheel buttons won't work.
1999 Ducati ST2
2003 Vauxhaul Vectra
1974 Triumph Bonneville 750
T140V
1937 Norton 500 single
(all still current)
Old 10-05-2006   #3 (permalink)
Woolly's right, check ebay for availability of EURO spec COMAND unit for the R171, or if you have friends/contacts in Europe.
Old 10-05-2006   #4 (permalink)
-1-
Don
-1-'s Avatar
I check ebay almost everyday for SLK items. It's been months since I've seen one listed. Maybe only two in the last year. Can't say if any were the European version. I search using SLK and not R171. I couldn't imagine anyone using R171 rather than SLK for their listing. Steve at MBenzNL list the European units as being available. Contact him. Personally, I could care less about watching video in the SLK or any car I'm driving. As a passenger, maybe. Rather than go to the expense of replacing a perfectly good HK display, I'd go with a simple 7" display with a built in or add on DVD player.
THE MON55TER ON THE BLOCK
View -1-'s Photo Album -1- is online now
Old 10-05-2006   #5 (permalink)
Vehicle: SLK55 2006
Well, i'd like to keep this car lightweight (my last car had about 200 lbs of audio/visual equipment). i just want the video input for front/rear cams, i don't really want to change the electronics in this car too much, and i DEFINETELY don't want to spend as much money on the electronics.
Old 10-05-2006   #6 (permalink)
Vehicle: SLK55 2006
also, if i use euro spec unit, won't i lose Sirius?
Old 10-05-2006   #7 (permalink)
Vehicle: 2006 Slk 350
Other Toys: Lots of ATV's
Maybe try contacting a dealer in the UK or something. Theyre english too! Go to MBinternational, and maybe have them order you one and ship it to you across the pond.
Old 10-06-2006   #8 (permalink)
Unfortunately there really is not much that cam be done about this the problem being that the HU lacks not just the TV button but all the associated hardware.
Not really much you can do to enable the video to a US spec sorry mate the only way i can see would be to replace the thing with an EU setup but yeah you will lose Sirius if you do that so i guess its swings and roundabouts whatever you do really.
Best thing would be an aftermarket LCD for the cams but that would not work with the weight reduction plan but it would be cheaper than swapping head units.
Old 10-06-2006   #9 (permalink)
Vehicle: '05 SLK350
Another thing, though i am not 100% sure on this one, but as far as i know the EU Command does not have AV-input. It only allows DVD playback via the drive in the Command itself.
If you are serious about the upgrade, toss the cupholders and set it up "Noregret Customs" style I doubt the additional weight of the screen and some AV cables exceeds 5-7 lbs total. Will give you 3 AV inputs and a tv tuner if you choose to use it.
Sounds like you know car audio, so imagine a 1/2 din unit, with no addional brain or module to connect.
To balance it out, leave the 5 lb manual at home...
Old 10-06-2006   #10 (permalink)
Ya, if you ever seen the setup he has youll love it. I am seriously contemplating doing it. And sweet name nr4l, very creative.
Old 10-06-2006   #11 (permalink)
x2, Noregret Custom.
Old 10-06-2006   #12 (permalink)
Vehicle: SLK55 2006
noregret, i've done a bit of car-modding myself, (my other car has full carputer with full audio, gps, tracking, video, surround sound, limited data-logging, 10.4 inch touch screen, front and rear cams, etcetera), but i really want to take advantage of the COMAND screen...not as much because it's a great screen, but just because everything it displays is so ugly...no 3d mapping, no song & artist titles, no engine data...just plain ugly.
i just think the 'AUX' input should be utilised better.
Old 10-06-2006   #13 (permalink)
noregret mate 100% correct about the HU no AV in just DVD.
I know what you mean cyberdrakon the COMAND does have lots of wasted space but the only real thing you could do to enable it to show cams would be an EU headunit and a TV tuner that has AV inputs so you could hook up to that and then it would fire the images across the MOST really no other way to integrate into the HU.
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/general-modifications-r171/782-so-my-question-what-parts-required-enable-us-r171-comand-use-aux-video.html
Posted By For Type Date
So, my question is, what parts are required to enable US R171 COMAND to use AUX vide - Benzworld.org - Mercedes Benz Discussion Forum This thread Refback 01-18-2007 02:51 AM
So, my question is, what parts are required to enable US R171 COMAND to use AUX vide - Benzworld.org - Mercedes Benz Discussion Forum This thread Refback 10-06-2006 09:10 PM
Comand Video Input SLK55UAE Help and Support 7 08-22-2008 05:59 PM
New Comand in a R171 Marco06 Ask DansSLK 2 05-13-2008 01:32 PM
Opinions on TVandNav2go.com video input on Comand? Tummy SLK R171 General Discussion 1 04-01-2008 12:28 PM
Slk 350 (R171) parts for sale sejoon85 Where to get R171 SLK Items 8 02-15-2008 06:52 AM
Another SLK (r171) video Ynot SLK Videos 1 01-06-2007 09:33 PM
