| | LinkBack (2) | Thread Tools |
#1 (permalink)
Vehicle: '05 SLK350
Country: Thanks: 1
| So i was faced with a decision to buy the MB mount for the front of the car and spend $85 for something i didn't want in the first place... or come up with my own solution. Well here it is. Total cost $6 Here are the parts: ![]() ![]() Here you see the extender with all nuts,washer, and spacers attached. Left is the front where the plate is mounted. Right mounts to the grill. ![]() Attached extenders to the lower mounting holes on the license plate and the plate is bent to curve around the nose of the front bumper: ![]() Industial strength velcro attached to the top of the License plate: ![]()
__________________ Obsidian Black Metallic / Red Leather Comfort, Lighting Premium Package Heating Package Airscarf Sport Suspension MHI Installed Entertainment Package Nav Komfort Variodach Module (Piecha) Kleyman Puddle Lights Euro Clear Side Markers Pirelli PZero Nero Custom Flipout 7" LCD w/Rear Camera Front Nightvision Camera TV tuner 250gig Media Drive (movies/pics/music) Kleyman 3BFM V1.5 (Noregrets Custom Works) White LED License plate bulbs Chrome Rear Turn Signals 50watt Xenon White Reverse Bulbs 8000K Fog Light HIDs Full LED conversion:doors, parking, sidemarkers, dome lights _________________ -NoRegret Customs- |
Vehicle: '05 SLK350
Country: Thanks: 1
| Here is 1 of the rubber expanders inserted into the grill. The inside part is all rubber, and in the front there is a nut mounted: ![]() ![]() This was the tough part. After attaching the screw rods, you have to drop the front cover of the bumper to get access to behind the grill. To Add the washer and back nut: ![]() Leave the velcro on till the very last step. Make sure it all lines up, and then peal the velcro backings off to stick to the bumper: ![]() And you are done: ![]() Don't mind the nasty copper lower nuts on the above, i will get a nice black license plate holder and paint them black to match.
| Founding Member #5 ![]() Join Date: Jun 2006 Location: Los Angeles, CA
Country: Thanks: 33
| Cool. Very nice. Will do this once I get that fix-it ticket for no front plates. ![]() Thanks for the write-up w/pics.
__________________ Mods: vario roof, clear side markers, clearbra, V1, tint, Green Filters Sound: Genesis Profile 5, Hertz Speakers, Image Dynamics |
| Founding Member ![]() Join Date: Jun 2006 Location: Colorado
Country: Thanks: 93
| You are a genius. ... ![]()
Vehicle: '05 SLK350
Country: Thanks: 1
| I used to watch MacGyver a lot when i was little ![]()
| | #8 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
| I think if there is a low steed frontal crash, there will be more to worry about for the person doing the crashing... that boxcutter in the glovebox will come flying out ... ![]() Actually not true FPF422. The rods are rather short to reach the radiator, and the rubber expanders are actually "floating" so to say. So they can be pushed inwards but not pulled out because of the washer. So if someone was to tap my plate in the front (say a parking situation) the mose that would happen is the velcro comes appart at the top, and the rods get pushed through my grill. Still not reaching the radiator though.
| | #10 (permalink) |
Country: Thanks: 311
| What is the trade name/technical term for the threaded bolt and the rubber expanders? Are they sold as a set?
| | #11 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
| FPF422, you got me thinking about this, so i went out to test it... the rubber expanders just poped out of the grill inwards, and the velcro start to come undone... All good thanks for the followup though.etyu, I got these parts from Home Depot. I think the "bolt" is just called a Threaded rod, it is sold in various lengths and diameters (found it in the section right next to where the velcro strips were) and the "rubber exbanders" i think are called just that (can be found in the drawers in the isle with screws and bolts). I think i still have the wrapings at home with SKU numbers... can check later after i get out of work. Rod is about $3 (1 is enough to make 2 rods) and the Expanders are $0.95 each i think (you need 4)
| | #12 (permalink) |
Vehicle: ///AMG
Country: Thanks: 12
| you should buy the bits and sell it as a $50 kit on ebay. good work. I'm not sure if a front plate is required in texas, ive been stopped twice and they have never mentioned it. My english ignorance of local laws seems to work quite good here. ![]()
| | #13 (permalink) |
| Founding Member / Moderator ![]() Join Date: Jun 2006 Location: Rowlett, TX
Vehicle: 2002 C2DSLK32K
| In Texas front plates are required by law.......but no one seems to have them on and most officers don't seem to be enforcing that law.
__________________ C2D 2002 SLK32K C2Design and Kleemann Modified 360.0 rwhp 349.8 rwtq Check My vBGarage for all Modifications |
| | #14 (permalink) | |
Country: Thanks: 93
| | #15 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
__________________ Obsidian Black Metallic / Red Leather Comfort, Lighting Premium Package Heating Package Airscarf Sport Suspension MHI Installed Entertainment Package Nav Komfort Variodach Module (Piecha) Kleyman Puddle Lights Euro Clear Side Markers Pirelli PZero Nero Custom Flipout 7" LCD w/Rear Camera Front Nightvision Camera TV tuner 250gig Media Drive (movies/pics/music) Kleyman 3BFM V1.5 (Noregrets Custom Works) White LED License plate bulbs Chrome Rear Turn Signals 50watt Xenon White Reverse Bulbs 8000K Fog Light HIDs Full LED conversion:doors, parking, sidemarkers, dome lights _________________ -NoRegret Customs- | |
| | #16 (permalink) | |
Country: Thanks: 229
| | #17 (permalink) |
| Founding Member ![]() Join Date: Jun 2006 Location: Houston Texas
Country: Thanks: 217
| I too am waiting on that, "I have to get it now!", ticket. Until then, I'm running without it. Great Idea and thanks for sharing. ![]()
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. 2000 SLK230 copper Designo Sport To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. So many come here FOR help but are not willing TO help? C'mon people...Help the site survive...Become a Supporting Member or just Donate $5, $10 or whatever you can! Your SLK will go faster, get better gas mileage, never get dusty or dirty.... Well,... maybe not, but you WILL feel good you helped the site! To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
