Welcome to SLKWorld
Old 08-20-2008   #1 (permalink)
SLK World Junior Member
Vehicle: 2008 SLK 350
Default Lower replacement storage compartment
I need some advise on removing the lower storage tray with the cig lighter assembly. My customer had me replace the upper cup holders and would like to have me replace the lower unit as well. After removing both screws on the lower unit it should slide out in order to disconnect the wires from the cig lighter assembly, not wanting to force or break anything the unit is loose but will not slide out. Any suggestions from those who have replaced theirs would be appreciated.
View viperdrew's Photo Album viperdrew is offline
Old 08-20-2008   #2 (permalink)
dltslk's Avatar
Other Toys: 1968 Pontiac GTO
Donation Level 8
Have a look at this thread.
http://www.slkworld.com/showthread.p...arette+lighter
David
View dltslk's Photo Album dltslk is offline
The Following User Says Thank You to dltslk For This Useful Post:
Old 08-20-2008   #3 (permalink)
Vehicle: Black with black 2005 SLK350. Roof module, chrome door pins, AMG bonnet vents, R170 antenna.
You need to make sure the gear shifter (if it's a 7G box) is in D - (or basically out of the way) first.
Then, in order to get the ashtray / storage compartment out, you'll need to move the panel above out of the way (this is the one with the air con / heating dials on it). To do this, you simply need to gently prise the two top corners (top left and top right) of the air con panel with a screw driver or similar (be careful not to damage it). It should just pop out.
Once you removed this you can remove the lower storage compartment / ashtray without too much trouble.
Hope that helps!
View jfb1977's Photo Album jfb1977 is offline
The Following User Says Thank You to jfb1977 For This Useful Post:
Old 08-20-2008   #4 (permalink)
Thanks for the quick answers. Very helpful info, now I'll have another go at it. Thanks again.
DIY: Digital Climate Control & Lower Tray Compartment Installation dsb General Modifications R171 35 4 Weeks Ago 01:51 AM
Water coming out the pass side compartment hawkgt SLK R171 General Discussion 6 08-07-2008 05:00 PM
Winter Storage? jbarnaby General Discussion 9 01-02-2008 08:44 AM
Opening Storage compartment kiwii Ask DansSLK 4 07-09-2007 06:00 AM
Annoying Compartment alroumi Help and Support 8 02-06-2007 10:35 PM
