Old 06-23-2008   #1 (permalink)
SLK World Junior Member
Vehicle: 2005 350 SLK
Default Help with Sirius wiring
I have a 2005 SLK 350 (with HK7 and Command). I want to run a cable that has mini jack plugs on each end. One will plug into my portable car kit Sirius, which is attached on the floor on the left side of the driver (right in front of the seat). The other end will plug into the Aux line in located in the glovebox. I used to use the FM transmit with my old unit, but the new Sirius unit is very weak and the sound is poor.
Any ideas on how to run the line in a consealed manner? Is there a channel behind the dashboard? I already have the Sirius antenna and power supply wired into the car and completely consealed.
Tom
View Eclipse Anesthesia's Photo Album Eclipse Anesthesia is offline   http://www.slkworld.com/Boss Key
Battery Trickle Charger pre-wiring install etyu General Modifications R171 24 07-06-2008 07:02 PM
removing the sirius antenna linuxpro General Discussion 2 06-09-2008 07:54 PM
Comand Retrofit - speaker wiring VitaminT Ask DansSLK 2 04-26-2007 09:36 AM
Phone cradle for tele pre-wiring chris_m Where to get R171 SLK Items 2 07-29-2006 10:00 AM
Phone cradle for tele pre-wiring questions chris_m SLK R171 General Discussion 26 07-13-2006 09:44 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80
