Welcome to SLKWorld
Old 05-28-2008   #1 (permalink)
Cold Shot's Avatar
Vehicle: 2007 SLK55 AMG
Other Toys: 2007 ML 350
Donation Level 6
Default Not a good day for a "do it yourselfer"
Oh man, what a day. Had some time today so decided to focus on the SLK.
First, had to send my stubby antenna to another forum member for help with replacing my stock antenna with a stubby R170 version. I tried to solder the wire mod myself and failed miserably. Only later discovered that there is a "break in" procedure for new soldering irons I was not aware of...and this probably contributed to my issues. 4 hours plus wasted. But many thanks to one of our guys for so eagerly volunteering to save me. What a great community we have!!!
Got to the house and decided to attach the Eurolights clear side markers. Remembering all the tips, I dug in. Remove the four screws, bent the wheel well liner back behind the tire turned out. Remove the OEM markers, pre-tapped the new clear markers...no worries. Screwing the single mounting screw in I heard a "crack" on the first one I installed. Damn...I barely had the screw seated and the outside of the lens cracked. It's only noticable from close up, and is probably going to be OK. But I'll have to watch it never the less.
Next, time to clean the Green Filters. Easy enough...I've done it three times before. Pulling the front engine cover off..."snap"!! I broke the front right retaining clip. SH!T. The break was clean, and the wife had some new Crazy Glue in the house. It worked!!! It seems to be holding, and you can't even tell by looking at it close that it ever broke. Let's see how it does when the temp is 122 here plus the internal engine compartment temperature.
At least my antenna is safe!! Thanks for letting me vent folks.
2007 Black/Black SLK55 AMG (Green Filters, SmartTop V1, Eurolight Clear Side Markers, R170 Modded Antenna)
2007 Pewter/Black ML350
19xx White/Blonde Wife (Lmtd Edition Model)
View Cold Shot's Photo Album Cold Shot is offline
Old 05-28-2008   #2 (permalink)
Sorry to hear that mate.
We all make mistakes, it could have been worse.
Old 05-28-2008   #3 (permalink)
-1-
Don
-1-'s Avatar
Sorry about the bad day Cold Shot. I'm a fairly good "do it yourselfer" also. I'm off on Wednesday and always have something to do around the house. We have a sixty foot tree on one side of the house that's blocking some of my HD DirecTV channels. I thought I'd just climb up and top out the top twenty feet. I got about one third of the way up and realized I was out of my element (the ground). I quickly came to my senses and decided to leave it to a professional. One of Clint Eastwoods lines from his movie "Magnum Force", "a man's got to know his limitations". I'm often guilty of applying this rule after the fact.
THE MON55TER ON THE BLOCK
Old 05-28-2008   #4 (permalink)
Cold Shot's Avatar
Donation Level 6
I feel you -1-. I often recall climbing around on 4" steel beams thousands of feet above the ground in Chicago, or working on my house by "bouncing" my 20' ladder down the side. It's an odd thing when age and wisdom meet your youthful memory...especially at times of perceived personal peril.
I am a DTV guy myself. One of the first 100 customers in the US. I am on dish number 5 and have been through about 20 receivers. Hopefully, the new sat launch a few months back will bring more bandwidth (less compression) to our existing HD offerings and not another 42 shopping channels. Good luck with your LOS issues. And thanks!!
Old 05-28-2008   #5 (permalink)
Vehicle: '05 SLK350
Cold Shot, i know the feeling. I've had those days many times. one bad thing just leads to another and another. I have learned to just STOP. at that point where i realize Karma is not on my side.
Quit while you're ahead!
Old 05-28-2008   #6 (permalink)
Cold Shot's Avatar
Donation Level 6
Thanks for justifying my time tonight with a nice bottle of cabernet. I just stopped.
Old 05-29-2008   #7 (permalink)
Here's a link to my prior post on breaking the clips (yep, I broke two!) on the front decorative piece of the air filter box: http://www.slkworld.com/amgs/4227-bo...oke-clips.html
On the clear side marker: perhaps it's a defective material from the maker, you may be able to exchange/return the defective part to the seller. On mine I did shorten the screw by perhaps 1/8" as it would push the aluminum foil that I use to cover the holes.
Old 05-29-2008   #8 (permalink)
Cold Shot's Avatar
Donation Level 6
In other words: "Boy, did you F-up. If one of the lads in my shop did that...they would be selling fish sticks at Kensington Station about now".
Thanks Dan...I needed that chance to laugh at myself
Old 05-29-2008   #9 (permalink)
LOL, honestly mate it's not that bad, only some minor damage.
I messed up while cutting a wire tie a month or so back and cut part way into the wiring harness, took me over a day to fix it using the MB method and then test it all.
Unless it's a big big mistake (forget to add engine oil before starting engine or something) then the way it normally work's is we have to carry out the repair on our own dime and don't charge the customer for the original job (part's only).
So a 1 second slip cost me over $2k USD
Old 05-29-2008   #10 (permalink)
HwoALanG's Avatar
Vehicle: 2007 SLK 280
Donation Award
~ it reminds of my RSX day~~ DIY~~
you will be fine~ not a major issue~
View HwoALanG's Photo Album HwoALanG is offline
Old 05-29-2008   #11 (permalink)
dsb
Silver Supporter
dsb's Avatar
Vehicle: '06 slk55
Sounds like it was a fun day.
Life goes on. If it makes you feel any better, I'm one of many that have broken clips on the airbox. It still works just fine though.
SOLD!
06 Mercedes Benz SLK55
Caspian Blue / Black & Ash
Old 05-29-2008   #12 (permalink)
Lifetime SLK World Member
ir-ops's Avatar
Vehicle: happily owning a '08 black on black manual/sport r171 200k f/l since 07 jul '08
Donation Level 5
peter sellers rules!!!
brgds
ir-ops
View ir-ops's Photo Album ir-ops is offline
Old 06-02-2008   #13 (permalink)
SLK World Junior Member
Vehicle: 2001 SLK230 Compressor
Other Toys: '06 Mini Cooper S, '93 500SEL
It all depends on the soldering iron/gun that you are using as well... but some days, it doesn't pay to get out of bed.
Glad you things sorted out finally!
View motionmonk's Photo Album motionmonk is offline
How to: get rid of "Service C due XX days ago" notice on dashboard rdfield Ask DansSLK 4 08-06-2008 10:38 AM
Mercedes Turns AMG Into New Brand, Opening "Performance Centers" in US Tummy General Discussion 3 03-11-2008 11:45 AM
Pro/Con "Digital Automatic Climate Control" Worth it? webslinger General Discussion 45 03-10-2008 11:01 PM
DECEMBER 2007 Picture Contest "Unexpected Locations" VOTE HERE easty Off Topic 0 12-12-2007 12:00 AM
Baby Monster "SLK55" meets the Baby Aston "AMV8" alroumi Off Topic 9 09-26-2007 06:54 AM
