| Elite SLK World Member ![]() Join Date: Mar 2007 Location: Paris
Vehicle: SLK 55 AMG
Country: Thanks: 5
| On my side, the cup holder has absolutely no use ! A solution : The MB P/N A17168000529116 : it will directly replace, and will provide a small area to store ticket, credit card , .... It costs 57€. Packaging : ![]() Top view : ![]() Front view, closed : ![]() Front view opened : ![]() Side view opened : ![]() Installation is easy. Remove the plastic cover ![]() Unscrew the 2 screws ![]() Remove the cup holder ![]() Install the new part ![]() Screw it ![]() Put the plastic cover ![]() FInal result : opened ![]() Final result : closed ![]() I have now to sell a cup holder .... ![]()
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ------Michel------ -SLK 55 AMG 2005- |
| The Following User Says Thank You to Zeiser50 For This Useful Post: |
Country: Thanks: 232
| Thanks for showing us the dyi, I am a coffee addict so the cupholders are a must.
Country: Thanks: 323
| Thanks Michel. Mate likes her tea, and I occasionally bring coffee, so the cupholder stays. This is however an alternative for those who don't want the cupholder.
Vehicle: SLK 55 AMG
Country: Thanks: 5
| @watsons : The order has been done directly to MB shop. I imagine that some web site should be able to sell it also. @etyu : We do not use so much (in fact never) such things in France. Maybe we drive in a more "italian" way our cars ......... (not so smooth)
| SLK World Member Join Date: Apr 2008
Vehicle: 2007 SLK280
| i love the ideas of have an storage area. I read another post about someone who made there own tray. it is way better it look like it fix right in. One question: Can you put it on the bottom where the ash tray and lighter is? i don't smoke and would never allow anyone to smoke in my car so i have no use for it. |
| | #8 (permalink) |
Country: Thanks: 85
| Our car's come standard with the cubby and while its not quite big enough to store most shades it does make a good spot to store smaller item's or in my case some displays Even if i did drink in the car (which i don't) and i did have the cupholders i still would not use them, right below them i have a few k's worth of COMAND screen and then another k in control panel and climate display below that. Not a chance in hell would i risk damaging them for a drink it's just not worth it.
| | #9 (permalink) |
| Elite SLK World Member Join Date: Feb 2008 Location: Exeter, UK
Country: Thanks: 12
| I'm with Dan on this one. Although the cup holder is handy, I would never have a drink in my car (just too risky) and so I would probably change to having a cubby hole to keep my sunglassess, insulin and car parking permit in ![]() |
| | #10 (permalink) |
| SLK World Member Join Date: Jan 2007 Location: Connecticut
Vehicle: 2005 MB SLK 350 Everest Green Metallic (6 speed manual]
Country: Thanks: 2
| I have the cubby - replaced my cupholder as I would have never used them. The cubby is the perfect size for the remote display from my V1. It will not hold sunglasses, but is good for parking passes or credit card size items. Should be a standard option. |
| | #12 (permalink) |
Vehicle: SLK 55 AMG
Country: Thanks: 5
| Space size : -> depth : 68 mm -> height : 29 mm -> width : 155 mm
| | #14 (permalink) | |
| SLK World Member ![]() Join Date: Jul 2006 Location: Germany
Vehicle: '06 SLK55
Country: Thanks: 11
Dan can verify but I believe the lower tray part number is A 171 680 0552. | |
| | #17 (permalink) | |
Country: Thanks: 85
coolboarder, just disconnect them from the lighter, it is a plug/socket connection so that's all it takes. That section of the dash does contain carpet so a little electrical insulation tape wrapped over the connector to stop FOD getting at the contact's is advised. nmslk, Imagine the ashtray over that comes with the lighter extended right across the length of the panel (it looks like the upper cubby)
| | #18 (permalink) |
Vehicle: '06 SLK55
Country: Thanks: 11
| nmslk, as Dan said, just imagine a drawer using all the space of the ash tray and lighter. It's about the same space offered above except as a drawer rather than a front access cubby. The bottom of the tray has a rubber pad which helps to keep things from sliding or rattling pretty well. I keep change and my garage door opener in there and rarely hear anything. I would take a picture but unfortunately left both of my cameras at my wife's house in Czech last weekend. |
| | #19 (permalink) |
| Buckle up shut up hold on / Moderator ![]() Join Date: Jul 2006 Location: Nfld., Canada
Vehicle: 2006 SLK55
Country: Thanks: 257
| Excellent info! But like Mohammed, I like my coffee too much to lose the cupholders *L*.
__________________ - Bill 2006 SLK55 Caspian Blue/Beige Stock 1/4 mile results: ET 12.72, trap 110.80, 60' 1.90 O.Z. Ultraleggeras, Magnaflow X-pipe, E55K Airbox, Windrestrictor. Some guys they just give up living and start dying little by little, piece by piece. Some guys come home from work and wash up and go racin' in the street... - B. Springsteen To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
| | #20 (permalink) | |
,I cant resist the mornings coffee, the smell the taste and of all the concentration.
