Windrestrictor
Old 08-29-2006   #1 (permalink)
Default Where's the switch for trunk/boot light?
Does anyone know where the switch is to turn off the light in the trunk/boot of the R171? I couldn't locate the switch so I could tape it down to turn the lights off. I wanted to change the clamp/festoon type 10w 44 mm bulb to an aftermarket white LED but it's a bit too hot to handle as it stays on as soon as the trunk/boot is opened.
Old 08-29-2006   #2 (permalink)
Founding Member #3
mcat's Avatar
Wait 15 mins and it will go off by itself.
View mcat's Photo Album mcat is offline
Old 08-29-2006   #3 (permalink)
I think the switch is encased in the lock mechanism etyu, best thing to do would be to wait for it to go off by itself like mcat said it only take 15 mins
Old 08-29-2006   #4 (permalink)
Thanks for the replies. I knew it would go off after 10 to 15 minutes (after leaving the boot/trunk open) but thought I was mssing something when I couldn't locate the switch. Thanks guys.
Old 08-29-2006   #5 (permalink)
On a related note: The trunk/boot light I presume is not monitored, so an LED replacement should be okay without resistors, right?
Old 08-29-2006   #6 (permalink)
As far as i am aware that is correct yes etyu
Old 08-29-2006   #7 (permalink)
Thanks a bunch, Dan.
Old 09-05-2006   #8 (permalink)
Vehicle: '05 SLK350
etyu, you can also just disconnect the entire housing with the lens.
Post up some pics once you get it done!
Fuse box in trunk/boot jmeredith SLK R171 General Discussion 4 06-21-2008 11:17 PM
Help - Removing light switch Chris-h General Discussion 1 06-10-2008 05:44 PM
Help removing light switch panel Chris-h Ask DansSLK 0 06-10-2008 12:19 PM
R171 Boot / Trunk Size? Paul Help and Support 13 12-13-2007 04:57 PM
R170 Hazzard switch light SLKman Ask DansSLK 3 07-28-2007 05:36 PM
