Windrestrictor
Old 08-21-2006   #1 (permalink)
Vehicle: '05 SLK350
Default New Bulbs
Placed an order online for a bunch of new replacement bulbs.
2 x Xenon Super White 50 Watt Back Up Bulbs
2 x Front turn signal Chrome Amber Bulbs
2 x Rear turn signal Chrome Amber
2 x 9 LED Super White LED License plate Bulbs
2 x Running lights Chrome Super White
Total price: $40.90 shipped.
Also plan to pick up a set of H7 Sylvania Silver Star bulbs for the fog lights from a local shop. They run for $37
I already have White LED bulbs for the Euro Clear side markers, and will drop those in with resistors as well.
Goodbye amber reflecting in the headlights, goodbye ugly hologen colored bulbs!
Will post pics as soon as its all in
Old 08-21-2006   #2 (permalink)
-1-
Don
-1-'s Avatar
NR4L - I thought the fog lights took a different size bulb than the standard headlight H7 bulb?
THE MON55TER ON THE BLOCK
Old 08-21-2006   #3 (permalink)
Vehicle: '05 SLK350
There are actually 2 types of bulbs used in our fog lights.
For those with the lighting package (which includes corner lighting feature) use H7 bulbs.
For those without the lighting package, you have the 9006 bulbs.
This is due to the optics of the bulb itself inside the fog light. H7 has a wider beam then the 9006 as it is mostly used in headlights. And with the cornering feature that is the key.
Old 08-21-2006   #4 (permalink)
Any parts nos. for the chrome Amber bulbs, front and rear? website perhaps? Thanks NG4L.
Old 08-21-2006   #5 (permalink)
Vehicle: '05 SLK350
I actually found the dealer on Ebay and contacted them directly for a price quote with the various bulbs i found in their Ebay store.
They do have a website, however i am not sure if the prices are the same as Ebay prices. (seems to be cheaper if you email them through Ebay for a price quote)
Front Turn Signals:
3157 (same as 3457)
Rear Turn Signals:
1156
You can see the Silver/Chrome bulbs there. No actual part# for them. Just called chrome or Silver online.
superlumination@cox.net
www.autolumination.com
Just an FYI, if you ever need to search for a bulb replacement type, you can always search at http://www.sylvania.com/ConsumerProd...de/default.htm
Has a search for any car.
Another interesting bit i found was that they sell a very unique ball they call the D-Cell flasher. It is actually a 1157 bulb that flashes for a few seconds then goes steady on just as the module i am working on for the center brake light. However there is a MAJOR advantage. Apparently they claim their circuit ONLY flashes when there is a sudden harsh braking. This would be AMAZING for my module.
Downside is that they are 1157 bulbs and are completely useless to us in the R171 SLK as we don't use 1157 bulbs for brake lights. I am going to contact them for details. Perhaps i can retrofit their 1157 bulb to our center brake light application.
Old 08-21-2006   #6 (permalink)
I kinda like the module you're working on as you can change the mode depending on your mood . Plus, I like it when it bursts/flashes three times and then goes constant when the brake pedal is engaged and not just ONLY on panic stops.
Old 08-21-2006   #7 (permalink)
Vehicle: '05 SLK350
Good point etyu. I am still going through with my module, however it would of been great if we had an additional mode on my module such as the one described above. Doubt i can put both together, but figured i would throw the info out there
I think their bulb has a mini "ball & contact" type sensor used in motion alarms. Pretty much means that when you throw some G-Forces on the unit, it send the little metal ball to the contacts and makes the connections. Otherwise it is conneted constantly if leveled.
Old 08-24-2006   #8 (permalink)
Vehicle: '05 SLK350
All the bulbs arrived today! That was some fast shipping.
I will drop in all the bulbs tonight. I'll try to remember to to one side of the car at a time. This way i can show a comparison of color and brightness.
Old 08-24-2006   #9 (permalink)
Do you still need resistors with these bulbs?
Old 08-25-2006   #10 (permalink)
Vehicle: '05 SLK350
Resistors are only needed on LED bulbs. Which in my case are the lisence plate lights only.
I actually did not have time last night to install everything in. Birthday outing came up and i found myself pulling into the driveway at 5:30am
I did however install the Rear turn signal, which by the way IS NOT 1156 as instructed. It is the Euro bulb similar to the 1156 but the pins are at a slight angle and not opposite each other like 1156. Easy to get it in, just shave off one of the pins. So the Chrome looks good, and is a bid darker amber color then stock. However the bulb is a bit dimmer due to the mirror coating on the outside. Nothign major but noticable.
Also installed the 50W rear backup bulb. This one was indeed a true 1156. It appears to be noticable brighter then the stock bulb. However i am fearing that heat will be an issue as it gets really hot, really fast. Not that i reverse for more then a few sec. But still causious of melting something.
The 194 bulb for the parking lights in the front is a nice mirror coating as well. The tint of the bulb is drastically whiter then the stock, however dimmer, once again due to the mirror coating on the outside. I do however like it a bit this way. As i never felt that i really needed those lights anyway.
Didn't get a chance to install the front turn signals as they are a MAJOR PAIN to get to. I'll need to drop the pannel in the wheel well for that.
Raining here yesterday so not much i could do. Will post some pics when i get a chance though. Thus far impressions are 50/50 statisfied vs not. I guess i had high expectations for brightness and color.
Sorry for all the reading... at work here on 2.5hrs of sleep after a long night out , getting kind of loopy
Old 08-25-2006   #11 (permalink)
Thats one hell of a night out mate, was it your bday is so happy birthday man
Old 08-25-2006   #12 (permalink)
Vehicle: '05 SLK350
Oh no... Not mine. A friend's co-worker's
I'm in April
Old 08-25-2006   #13 (permalink)
Ah right oh.
I will try and remember that my memory is useless sorry
Old 08-25-2006   #14 (permalink)
Vehicle: '05 SLK350
I found another potentially great bulb...
1w LED 194 type.
1w for an LED is a lot. and this thing better be all they hype it up to be
Old 08-25-2006   #15 (permalink)
Get some shut eye tonight (Thank God It's Friday) and you'll have all weekend to work on the lights.
Old 08-25-2006   #16 (permalink)
Vehicle: '05 SLK350
sleep... who needs that. I HAVE NEW BULBS TO INSTALL
I have to finish my hardwire for the V1. I have much to dooooooo....
....ZzzzzZzzzz...Z.zzzzz....Zzzzzz
Old 08-25-2006   #17 (permalink)
Ynot's Avatar
, don't hurt yourself, get some sleep.
View Ynot's Photo Album Ynot is online now
Old 08-25-2006   #18 (permalink)
-1-
Don
-1-'s Avatar
I've often stated, I wish I didn't need to sleep. I could get so much more accomplished per day. I get an average of about five to six hours per night. Anything more, makes me lazy.
Old 08-27-2006   #19 (permalink)
Vehicle: '05 SLK350
Well here are the results. What do you think?
Each bulb contains 9 white LEDs, for a total of 18 on the rear plate.
The pavement below has a nice clean cut line to it as well. Quite bright.
Front Parking lights
Digg this Post!
