| | LinkBack (33) | Thread Tools |
#1 (permalink)
Vehicle: '06 slk55
Country: Thanks: 67
| What: How to strengthen signal reception with the R170 Antenna Who: For those of us that can't stand the look of the R171 long whip antenna but do not wish to sacrifice a ton of reception using just the R170 short antenna. Why: Why not? I for sure hate being limited to a few feet when I want to lock/unlock my doors. Plus, I spent good money on a Roof Module. From 50+ feet away, I want to walk to my car all the while it's roof is being lowered. By the time I get there, it's ready. When: How about now? It only takes about 20 minutes. Disclaimer: I am not an electrician and realize there's probably a better way to do this mod. Then again, this worked for me and that's what counts. Right? I was introduced to this mod from another member, (thanks Ikarus), and decided to put a quick tutorial together. I can say that I've already noticed a vast improvement in signal strength. Please note, I have only tested the lock/unlock range. I really don't listen to radio but I'm sure that signal has improved as well. What was the difference? Well, prior to the mod, I was able to lock/unlock at a maximum of 25 feet. That has grown to 120ft! So, in my experience that's 5 times better! Tools required: -Soldier gun and solder (RadioShack Model: 64-2802 $7.99) -22 gauge wire (RadioShack Model: 278-1224 $5.99) -R170 Antenna (MB part#A170 820 06 75 approx $70) -Allen Wrench -Pen -Ruler -Razor Blade ![]() ![]() Steps 1) Assuming you already have the R170 antenna installed, remove the antenna's upper section. This upper section is hollow plastic and is simply pulled off the base. I found that it's easier to leave the lower section screwed onto the vehicle. Pry the upper section off while slightly bending it. It should come off fairly easy. ![]() ![]() 2) Remove the lower section using the supplied Antenna 'Gear' ![]() 3) Take two strands of wire and begin wrapping them in a spiral around a small pen or allen wrench. The top section can be folded over. As you proceed, switch to a thicker pen. I used my child's paintbrush. The idea is to have a wire spiral that fits into the antenna cavity. I was able to utilize about 15" of length. ![]() 4) Next, strip the ends of the wire. Also, strip a small section of the antenna. Solder one piece to the inner section of the antenna and the other to the lower section. ![]() 5) Carefully fit the spiral wire onto the base of the antenna. Next, snap the Antenna's upper section back into place. 6) Reattach the antenna to your vehicle. Again, use the 'gear' to get a tight fit. That's it! Test it out and see the results for yourself. So far, I am happy with the improvement. I will conduct so more tests if I get the urge. For now, I am done. My biggest gripe with the small R170 antenna is now gone.
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
| The Following User Says Thank You to dsb For This Useful Post: |
Country: Thanks: 54
Country: Thanks: 54
Vehicle: '06 slk55
Country: Thanks: 67
| Don, I'm happy to hear your results are even BETTER than mine! Isn't this so much better than before?! One of the best mods for sure. I have a feeling I'll be using my Roof Module a lot more at the parking lot. BTW, I wonder if you're getting better distance because of a thinner and thereby longer wire? Perhaps, it's just interference around my house? Either way, it's all good. I did this install late last night and only did a quick test. I'll be testing radio reception (for the wife) today.
Country: Thanks: 96
| If the signal is not totally up to scratch after the mod you could always add the booster from the facelift car to it. You would probably end up with a range increased even over the whip. Remember to test it with a phone if you have one.
Country: Thanks: 376
| Thank you DSB, IKarus and to the person in Germany. Would a thinner wire work better because of the longer length that may be accomodated than Gauge 22?
| | #8 (permalink) |
| Senior SLK World Member Join Date: Oct 2007 Location: USA
Vehicle: 2009 Mars Red SLK55
Country: Thanks: 12
| Dan do you think the r170 antenna will fit the facelift model? BTW this is an awesome mod and definitely a solution to the ugly stock antenna... |
| | #9 (permalink) |
Country: Thanks: 96
| Yeah probably or if not I'm sure a similar mod could be carried out on the facelift stub.
| | #10 (permalink) |
| Elite SLK World Member Join Date: Aug 2007 Location: New York
Country: Thanks: 29
| Great Mod Can these only be purchased at Dealer? Thanks again to dsb and the original source...
__________________ Steven To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. 06 SLK 350, Iridium Silver, Blk Int, Chrome Trims, AMG Body, Aerowings,Wide Base Tire Flares (Thx CDRN) Green Filters, Filled Sidemarkers, Painted Ant, Komfort Module (Thks NR4L) Rear Spoiler - Piecha, Brabus springs, R170Moded Ant, 19" TSW Bremma, Mich PS2 |
| | #12 (permalink) | |
Vehicle: 2006 SLK 280 w. 6M
Country: Thanks: 18
| You're most welcome. I had found a great description of the idea on this page, but the publisher himself credits an mbslk.de member named mac67. It seems the whole thing got started by him in this thread.Quote:
So, ultimately, the best FM reception should be achieved with two wire branches of about 75cm length each. If you cannot fit as much with a particular wire, it may indeed be better to pick a thinner one. Darn, I really need that antenna now. It looks so much better! | |
| | #13 (permalink) |
| Thank you Ikarus for the explanation. I have called the parts dep't at MB. The antenna should be available in one to two days. I will attempt to do the same mod this weekend with a thinner insulated wire and try to get 75 cm if possible.
| | #14 (permalink) | |
Vehicle: '06 slk55
Country: Thanks: 67
Thanks for the links... of course I didn't understand any of it. So, I take it you're German. Are there any other easy mods we should be aware of? Looks like lots going on in those links?
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | |
| | #15 (permalink) |
| Elite SLK World Member Join Date: Jun 2007 Location: Honolulu, Hawaii
Vehicle: '07 SLK280
| Aww man, now I have to go and spend money on a roof module! The only thing that was keeping me from getting one is that I'd have to be near the car to use it anyway because of the range with the R170 antenna. I guess now I really want that module! Thanks for posting this dsb, I'll be making a trip to Radioshack today |
| | #16 (permalink) | |
Country: Thanks: 29
__________________ Steven To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. 06 SLK 350, Iridium Silver, Blk Int, Chrome Trims, AMG Body, Aerowings,Wide Base Tire Flares (Thx CDRN) Green Filters, Filled Sidemarkers, Painted Ant, Komfort Module (Thks NR4L) Rear Spoiler - Piecha, Brabus springs, R170Moded Ant, 19" TSW Bremma, Mich PS2 | |
| | #17 (permalink) |
Vehicle: '07 SLK280
| Went to Radioshack, got the supplies and did the mod. Works perfectly! Kinda makes you think which idiot designed the R170 antenna with so little wire! With xmas just around the corner, a roof module might be a fine present Just need to decide on which! |
| | #18 (permalink) | |
Country: Thanks: 18
