| | LinkBack (33) | Thread Tools |
| | #121 (permalink) |
Vehicle: SLK 55 AMG
Country: Thanks: 6
| This thread is amazing : i haven't found anywhere else such technical study ...
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ------Michel------ -SLK 55 AMG 2005- |
| | #122 (permalink) |
| Elite SLK World Member Join Date: Aug 2007 Location: New York
Country: Thanks: 29
| Alright gentlemen, I have picked up my new R170 antenns from MB. by the way, for those who will be ordering this....when ordering insist on the part number provided by dsb...long story...too much detail. Now ,I have this antenna and a new understanding of how much free tme most of you have ...So what is the final outcome with the modified R170? 37cm OR 75cm, two wires or one, soldered to A or B...gauge?...is there a general consensus? By the way...Thanks to all who have contributed to this thread.
__________________ Steven To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. 06 SLK 350, Iridium Silver, Blk Int, Chrome Trims, AMG Body, Aerowings,Wide Base Tire Flares (Thx CDRN) Green Filters, Filled Sidemarkers, Painted Ant, Komfort Module (Thks NR4L) Rear Spoiler - Piecha, Brabus springs, R170Moded Ant, 19" TSW Bremma, Mich PS2 |
| | #123 (permalink) |
Vehicle: '06 slk55
Country: Thanks: 67
| I think -1- is getting the maximum distance out of the R170 antenna. Second, might be me? I'm not quite sure. Like mentioned, it has gotten quite technical. Although I wanted to boost reception in all areas, I was mainly concerned with the remote. That said, -1- is getting about 200ft, I get about 150ft and I'm not sure the distance others are getting. I think it's great that our members have taken such an interest in running these tests. However, I think there's a reason the German forum finally decided on 2 wires up to 75cm length. I did 2 wires at 37cm. I have to believe -1- did about the same since he did his mod before all the tests. So, that would be my recommendation. Here's another thought, I wonder if running the 2 wires in parallel and making it as tall as possible helps. It might have made the difference for -1- and I. Anyways, give it a shot and please post your results. You'll find it's a fairly easy mod and can be adjusted if you don't get your desired results.
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
| | #124 (permalink) | |
Vehicle: '06 slk55
Country: Thanks: 67
Looking at your pics, I wonder if the short height of the R170 antenna is hurting your performance? Why not try the 75cm or 37cm length and start from the base on up?
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | |
| | #125 (permalink) |
Country: Thanks: 376
| I will be trying 75cm tonight on the R170 antenna. I was able to coil 75cm of AWG30 insulated wire and use the heat-shrink tube the same way I did with the 35cm AWG26 wire. Total height of the coil is 2.3cm. The reason is: I'm planning to do the same on the R230 antenna if the range with the R170 antenna is increased with the 75cm wire. Nothing like a little trial-and-error after some theoritical and technical info.
| | #126 (permalink) | |
As for the 4-month-old infant, feed him only water after bedtime if the child wakes up in the middle of the night. There may be a battle for a good week (be prepared) but once they know there's no food after bedtime until the next day, they usually sleep throught the night. Disclaimer: doesn't work on all children, your experience may vary.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. Last edited by etyu; 12-15-2007 at 03:13 AM. | |
| | #128 (permalink) |
Vehicle: '06 slk55
Country: Thanks: 67
| We were recommended to bundle our children in their blanket like a snug little burrito. It kept them from flailing their arms and in turn waking themselves. It worked great as I have to believe it mimiced the womb. Or, there's always drugs and alcohol (JK)
| | #129 (permalink) | |
Country: Thanks: 29
), I was trying to be funny....he's actually a pretty good sleeper stretches to 6hrs. There is always the "ferber" method..(the parents out there will understand)Oh yeah, back to the SLK...I will wait patiently for your results...Thanks. The "Swaddle" technique (technical term, not to be confused with other previously represented technical facts herin) is/was used with great success....Thanks, dsb..we are keeping our other options open as well.
__________________ Steven To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. 06 SLK 350, Iridium Silver, Blk Int, Chrome Trims, AMG Body, Aerowings,Wide Base Tire Flares (Thx CDRN) Green Filters, Filled Sidemarkers, Painted Ant, Komfort Module (Thks NR4L) Rear Spoiler - Piecha, Brabus springs, R170Moded Ant, 19" TSW Bremma, Mich PS2 | |
| | #131 (permalink) |
| That's what I did. I cut off about 2-3mm of the clear insulation at its tip and left the central wire, so I could have some place to solder unto.
| | #132 (permalink) |
| The following applies only to the range/reception of the SmartKey on the R171 (all meaurements are approximate, all are done with single insulated AWG 26 solid wire unless specified otherwise, i.e., monopole configuration, based on personal experience, trial-and-error): R170 antenna Without modification, 30 ft Modified, 24cm wire, 50 ft Modified, 35cm wire, 100 ft Modified, 42cm wire (based on OEM whip antenna length), 110 ft Modified, 75 cm wire, 80 ft FM reception is moderately improved as an added bonus. R230 antenna Without modification, 30 ft Modified, 35 cm wire, 100 ft FM reception is somewhat improved, so-so bonus. Disclaimer: Your experience may vary significantly from the above. Edit: the range with SmartKey is improved to 200ft or better with 37cm-long AWG22 insulated solid wire on the R170 antenna. Post #139, see below, also check post #175
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. Last edited by etyu; 05-01-2008 at 05:08 PM. Reason: added more info |
| The Following User Says Thank You to etyu For This Useful Post: |
| | #133 (permalink) | |
| Senior SLK World Member Join Date: Sep 2006 Location: Istanbul
Vehicle: 05 SLK 200
Country: Thanks: 3
| | #134 (permalink) |
| FM reception with the modified R230 antenna is on-and-off; some stations come in strong and some are weak, irregardless of the FM number.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. Last edited by etyu; 12-16-2007 at 12:05 AM. |
| | #135 (permalink) |
| Senior SLK World Member Join Date: Oct 2007 Location: USA
Vehicle: 2009 Mars Red SLK55
Country: Thanks: 12
| Great job eddy! However, I don't know if you mentioned this already and forgive me if you have, but what is the range of the stock antenna? |
| | #136 (permalink) |
| Hold your horses. I know that in theory, the thickness or AWG of the wire may not matter but... Based on DSB's and -1-'s experience of a thicker gauge wire, I just had to try and find out (I know, too much free time on a nice sunny Saturday morning). I bought AWG 22 solid wire from RadioShack this am and wound 37cm in much the same way I did with the AWG26 wire (see prior photos). It was a tight fit because the wire does not extend below the tip of the central wire with the clear insulation. It looks like a slender Christmas tree as the tip was tapered to fit inside the antenna cover. I initially tried to use 42 cm (following OEM whip antenna) but this wouldn't fit inside the cover, so I trimmed about 5 cm off. I tried the SmartKey and was very pleasantly surprised to observe that the range has improved significantly. Three of the neighbors were curious and came to talk to me to see what I was doing -- walking back and forth, crossing and re-crossing the street, and using a 25 ft tape measure. Incidentally I found out that the lines of separation or expansion joints on the sidewalk is roughly 10 feet apart(maybe 4 inches less than 10 ft). Anyhow, the range is better than 200 ft and close to like 220 or 230 ft; I could operate the roof from more than half a (residential neighborhood) block away.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. Last edited by etyu; 12-17-2007 at 12:54 AM. Reason: corrected spelling |
