Windrestrictor
LinkBack (33) Thread Tools
Old 12-10-2007   1 links from elsewhere to this Post. Click to view. #81 (permalink)
Vehicle: 2006 SLK 280 w. 6M
Originally Posted by Zeiser50 View Post
This is a resonance phenoma : each time the total lenght of the antenna is good, the number is low -> I select 37 cms for the next test
I find this result a bit suprising. Is what you're saying that with a wire of length lambda/8 (37.5cm), one is getting better results than with one of length lambda/4 (75cm)?
View Ikarus's Photo Album Ikarus is offline
Old 12-10-2007   #82 (permalink)
Ok ....
Now, the conclusion :
- wire can be any gauge
- only one wire, soldered on the metal part, just below the transparent cable
- lenght of 37cm....
This might explain why the initial mod by DSB had good results at 15 in/37cm albeit on the R170 antenna.
Old 12-10-2007   #83 (permalink)
Originally Posted by mtiede View Post
Great scientific testing. Nice to have the equipment
One thing that you apparently didn't test was whether that second wire some have used makes any actual difference. I think the second wire was to ground, but who knows whether there could be some sort of interaction in the coils of wire.
My experience initially with the R170 antenna was with just one wire and thought a second wire on the ground might make a difference but it didn't. I may have to go back and diassemble the R170 antenna and just try with one wire at 37 cm/14.5 in.
R230 antenna is on order (since I broke the one I already have).
Old 12-10-2007   #84 (permalink)
I'm not saying that 37cm would not work, so it might be worth trying as a compromise, but according to antenna theory, a dipole with a total length of lambda/2 (i.e. ~2 x 75cm) should still work best.
Old 12-10-2007   #85 (permalink)
Sid
Founding Member #5
Sid's Avatar
Etyu, how much does that cost? Do you think they come in Diamond Silver?
View Sid's Photo Album Sid is offline
Old 12-10-2007   #86 (permalink)
SL antenna is a bit more expensive, list is around $80 and MB MSRP is $125 ! You may call to see what they have (MB dealers usually stock the black and iridium silver, but the warehouse may have the color that matches your car, give them the color code and they can check).
Last edited by etyu; 12-12-2007 at 06:16 PM. Reason: revised MSRP price after seeing invoice
Old 12-10-2007   #87 (permalink)
dsb
Silver Supporter
dsb's Avatar
Vehicle: '06 slk55
You lost me here:
The equipment have used is a radio bench.
Seriously, thanks for all the work. Quite informative!
SOLD!
06 Mercedes Benz SLK55
Caspian Blue / Black & Ash
Old 12-10-2007   #88 (permalink)
-1-
Don
-1-'s Avatar
Zeiser50, I agree with others. Thanks for the scientific testing. Very interesting. I like the look of the SL antenna, but I can't beat the performance of the modified R170 antenna. Thanks everyone for their input on this thread.
THE MON55TER ON THE BLOCK
Old 12-10-2007   #89 (permalink)
It looks like everyone believe A is ground in R170 antenna. I tested and found A and B are connected. There is no ground in antenna.
Take a look at my second photo. Metal thread inside bottom of antenna is connected to nothing. It is just for mounting. So connecting one wire to A and connecting wire to B as ground(this is not true) is eventually connecting two separated wires to antenna.
I connected 75cm 24guage wire to A. I didn't get any gain on remote. I think 75cm is good for FM frequency but not for remote frequency.
What is the frequency used by remote? I want to optimize antenna length for remote frequency.
View zxxn's Photo Album zxxn is offline
Old 12-11-2007   #90 (permalink)
I was going to ask the same question - what is the RF frequency used by smartKey?
Old 12-11-2007   #91 (permalink)
I observed a gain in the range of the SmartKey if you attach it to point B.
Old 12-11-2007   #92 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
Is that an SL antenna or the R170?
This analysis has been done on SL antenna.
Do not forget that the antenna lenght is the total lenght (including the PCB), as there is adaptation (capacitor+resistor+ PCB patch). 75cms is not the antenna lenght, it is the lenght of additional cable.
Correct. but antenna theory (dipole) is based on simple antenna (no adaptation). Also, a single dipole (75cm) is ok with a gnd plane (car configuration).
Right : Usually, the antenna lenght is measured between ground plane, and the highest point (in a single dipole configuration). Using a second wire as ground, which can generate a global coil becomes ...... what i call "plumbing" . Only a very specialist is able to answer. However, 2 wires inside an SL antenna is a lot (space wise) ...
Not tested for remote control. It should be interesting to check it (but the frequency may depend of country regulations).
Even if electrically the point A and B are identical, antenna point of view, a wire on point A extends the antenna lenght, and on point B create a new "dipole". In this configuration, plumbing ...... Also, as the frequency may be high (for the remote control, 833Mhz ?), the impact of any small wire may be increased.
Right : A and B are connected (SL or R170). But there is a ground : the thread of the antenna is the antenna ground (car ground) (antenna thread and center pin should not be short circuited.
Why not solder 35 cm (accounting for length of wire in the transparent part) at the tip of the transparent part and then wind the wire around the transparent part? This way, one doesn't have to pick apart the coloured molded plastic.
Below the result : if you solder the wire at the top of transparent cable, a lenght of 37 or 35cm has similar result (you can solder it also on the metal base of the transparent cable).
If this wire is wound around the transparent cable or around the plastic base does not globally modify the antenna behaviour (for purist, the noise floor is better around plastic base, but sensitivity is less).
The figure below is the result.
------Michel------
-SLK 55 AMG 2005-
View Zeiser50's Photo Album Zeiser50 is offline
Old 12-11-2007   #93 (permalink)
-1-
Don
-1-'s Avatar
Using the original "non specific" separate wiring lengths attached to "A" & "B", I have increased radio and remote reception. I've checked the remote range twice, and I'm getting close to 200 feet. I'm using a recently purchased new MB key fob. For those with older key fobs with original battery, a new battery might be a small investment for additional range. Here's a recent link on replacing the key fob battery. http://www.slkworld.com/slk-r171-gen...tery-died.html
Old 12-11-2007   #94 (permalink)
I just checked this morning and found FM reception is very good!
But, no improvement on remote.
Originally Posted by -1- View Post
I just checked the range (car in the garage) and I'm getting over 200 feet. Might even be better than the factory antenna. I checked from the rear, and then the opposite side (away from antenna) and still getting 200 feet plus, even in the woods. Both AM-FM reception are excellent with the car in the garage.
I really like to know -1-'s magic length.
Old 12-11-2007   #95 (permalink)
... if you solder the wire at the top of transparent cable, a lenght of 37 or 35cm has similar result (you can solder it also on the metal base of the transparent cable).
Thank you very much for this Michel
Old 12-11-2007   #96 (permalink)
Vehicle: '98 SLK230
Other Toys: '96 328IS
Send a message via Yahoo to SLKjay
WOW!! Zeiser50 again I'm just blown away and I think your work is awesome.
View SLKjay's Photo Album SLKjay is offline
Old 12-11-2007   #97 (permalink)
-1-
Don
-1-'s Avatar
