| | #41 (permalink) |
| Founding Member ![]() Join Date: Jun 2006 Location: Houston Texas
Country: Thanks: 265
| Needle nose pliers. Put ends of pliers in the slots and turned the blue section counter clockwise to back it out. Just be carefull to only apply downward pressure to hold the pliers in place to turn and not to squeeze the pliers together. You do not want to accidentally smash the inside silver connector together. |
| | #42 (permalink) |
Country: Thanks: 377
| Thanks SLKman, I used rounded nose jeweler's pliers unto the two circular indented areas on the light blue plastic. Light but firm pressure towards the antenna end and counterclockwise force was all that was needed to unscrew the blue plastic-antenna innards assembly out. Not much force is required to unscrew the assembly. I will be doing the mods but using G30 insulated wire (also available at Radio Shack) in the SL antenna and see if I can cram 75 cm in that small space. I know that 75cm of G26 insulated wire will fit inside the R170 antenna (with some room to spare), but haven't had the chance to solder it in place or test it out. I will report back after completing both mods this weekend.
| | #44 (permalink) | |
| Senior SLK World Member Join Date: Sep 2006 Location: Istanbul
Vehicle: 05 SLK 200
Country: Thanks: 2
| | #45 (permalink) |
| Elite SLK World Member ![]() Join Date: Mar 2007 Location: Paris
Vehicle: SLK 55 AMG
Country: Thanks: 6
| Normally, the wire gauge should not be very important.
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ------Michel------ -SLK 55 AMG 2005- |
| | #46 (permalink) | |
| Elite SLK World Member ![]() Join Date: Jul 2006 Location: NorCal
Vehicle: '06 slk55
Country: Thanks: 45
R170 with SL antenna R171 with R170 antenna R171 with SL antenna
__________________ FOR SALE! $39,995 OBO 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | |
| | #47 (permalink) | ||
| Don ![]() Join Date: Jun 2006 Location: Virginia USA
Country: Thanks: 50
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ----------------1----------------- --------SLK 55 ///AMG--------- THE MON55TER ON THE BLOCK | ||
| | #48 (permalink) | |
Thanks to SLKman on showing how to remove the insides of the SL antenna, I was able to do the modification tonight. As stated I used G30 insulated wire (leftover from my modeling work, and is available at RadioShack or Fry's Electronics) on the SL (R230) antenna. I soldered the wires first and then wound 75 cm of the wire firmly and gently around the part of the antenna that is above the blue plastic base. I had to wind the almost hair-thin wire up and down this 2.5 cm/1 inch-short corridor. To prevent the wire from unfurling or unwinding, I tucked the ends like one would do when winding up rope or twine. On the SL antenna, the range of the SmartKey has increased from 10 meters/30 feet to about 30 meters/100 feet. I also modified a R170 antenna tonight using G26 wire. This mod is easier as the 75cm length easily fits inside the longer antenna. The range with the SmartKey RF signal is better than the 100-foot range of the modified SL ant. I haven't had the chance to check FM reception with the modified R170 antenna. Edit: checked FM reception with the R170 antenna this morning and it is better than the modified SL antenna.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant. EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, HyperWhite license plate lamps ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Scott), bilateral rear fog lamps enabled. Last edited by etyu; 12-08-2007 at 05:10 PM. | |
| | #49 (permalink) | |
| | #50 (permalink) |
| Using Gauge 30 insulated wire, 75 cm each (I only had one color wire), below is a photo of the two wires soldered but not wound: ![]() Next, testing on the car before winding the wire, the range with the SmartKey is close to the R170 mod but maybe 15 ft less range. ![]() Gauge 30 wire after winding the wire. The winding of the wire is done with the antenna not connected to the car. I tested it again before putting on the antenna cover. ![]()
| | #51 (permalink) |
| Senior SLK World Member ![]() Join Date: Oct 2007 Location: USA
Vehicle: 2009 Mars Red SLK55
Country: Thanks: 10
| So what I gather is that on the r171: R170 antenna: 15 ft more than SL antenna and much better radio reception. 5 inches long SL Antenna: 15 ft less than R170 antenna. Radio reception a worse than r170 antenna. Only 2.5 inches long and color coded with car. Much nicer IMHO... |
| | #52 (permalink) | |
Word of caution: Do not touch the central silver hollow attachment point in the SL antenna when disassembling. I must have misaligned that piece when I was testing and broke it when I reattached the SL antenna this after all the testing. Now I have to call MB parts department on Monday. I hope they have a dented one that they want to throw away as I only want the inner/central piece.
| | #53 (permalink) |
| Senior SLK World Member Join Date: Dec 2006
| so let me get this strait, 1. the gauge of the wire does not count towards the range? 2. I understand that there are wires with a single solid copper core and some that branch into million of strands of metals whcih type should I use? |
| | #54 (permalink) | |
I am not knowledgable in electronics and I believe those with more advanced knowledge in electronics and electrical engineering should be able to give the answer. My impression is that up to a certain degree the gauge or thickness of the wire doesn't make a big difference as far as using it as an antenna. (See Zeiser50/Michel's post above, #49) I think winding the wire into a small cylindrical shape versus having the 75 cm wires in an unfurled state affects the reception. Remember there are compromises to be made in order to improve the range of an antenna that wasn't intended for this use in the R171.
| | #56 (permalink) |
Vehicle: SLK 55 AMG
Country: Thanks: 6
| Eddy is right : Gauge is not really important. Also Stranded or solid type wire (solid will be a little better, but not so much). I will make some measurement next week (i have all the necessary equipment for radio raception measurement). My point is the picture from eddy's winded wire : as there is two wire (one is GND and the second is antenna itself), it should winded carefully (i.e no layers, but both wires in parallel). If it's not possible, maybe it is better to have a shorter lenght of wire (performance point of view). But its only my understanding, i should check more deeply (i know more radio itself than antenna reception theory) .
| | #57 (permalink) |
| I think it may have already been mentioned, but I think the important thing is the length so that it can resonate to the frequencies desired to pick up. Hand wrapping a wire with tape out to be somewhat difficult to do. I'd go buy a piece of wire. |
