Windrestrictor
Old 11-26-2007   #1 (permalink)
Senior SLK World Member
Silver Supporter
Vehicle: 2005 SLK350
Default Accessing Tail Lights??
I want to change out the amber bulbs in the tail lights with Stealth bulbs - what is the easiest way to access the back of the tail lights to do this??
View SLKDawg's Photo Album SLKDawg is offline
Old 11-26-2007   #2 (permalink)
There is a small flap on each side just behind the rear light assembly(felt covered). The flap can be moved away and the opening is enough for one medium to small sized hand only. The cylindrical plastic that houses the bulb/lamp can be twisted and removed. You need some dexterity on the wrists and good finger strength.
Old 11-26-2007   #3 (permalink)
BTW, if one has the satellite radio (Sirius) module on the left side of the trunk/boot, this needs to be removed by loosening the top plastic screw and the whole receiver thing will swing downward allowing you access to the flaps.
HELP Need to Borrow Tail Lights noregret4life General Modifications R171 2 07-06-2008 12:03 AM
HELP Need to Borrow Tail Lights noregret4life SLK R171 General Discussion 8 07-02-2008 12:23 AM
Why do the tail lights look so good?? jimbobalooba SLK R171 General Discussion 21 11-02-2007 04:11 PM
AMG smoked tail lights jamesbond007 General Modifications R171 2 04-16-2007 11:35 AM
AMG Tail Lights beverage Where to get R171 SLK Items 2 09-27-2006 06:30 PM
