Go Back   SLK World Forum > Mercedes Benz R171 SLK Class Cars > General Modifications R171
Wheel Clearance Event Promo
Old 11-23-2007   #1 (permalink)
Default Protecting leather seats from seatbelt scuff/rub marks
This is for those with light colored leather seats, e.g., beige, ash, or red.
As a corollary to this thread: http://www.slkworld.com/slk-r171-gen...eed-ideas.html
This is a simple DIY (do-it-yourself) project that takes a small amount of time, inexpensive materials and will save time and effort in trying to keep light-colored leather seats from having dark marks from the seat belts rubbing on the leather seats.
Material :
Translucent plastic that's normally sold as flexible chopping board (usually less than $5 USD for a pair; check out kitchen outlet stores when you're out with your mate shopping).
Tools:
1. Sharp Exacto-type hobby knife or a handy medium-sized utility knife (the ones where you can break off the blades in segments to have a fresh new sharp blade).
2. Hole puncher
3. Sharp and strong medium-sized scissors
4. Metal straight-edge or ruler
5. Motor tool with cylindrical sanding discs, small and medium (if you don't have one, it's okay, one can still do this project without a motor tool)
Precautions:
1. You're working with sharp knife and scissors, so take your time in cutting and be very careful to avoid any cuts/injuries
2. Safety glasses, especially when cutting or grinding, to avoid eye injury, especially with power tools
See photos below:
Last photo shows how the plastic is cut from the chopping board material. The length is 170mm and the width is 35mm. The distance between the scored lines to the longitudinal border is 7 mm (distance between the two yellow chevrons). The hole on the left side of the photo is 9mm in diameter. The C- shaped cut on the right is 15mm in diameter.
I used a hole puncher to make a series of cuts/holes after outlining the intended circle in pencil. The edges of the opening were then smoothed out with a motor tool using a small cylindrical sanding disc. One can also use a drill with the appropriate sized drill bit to make the hole. I initially used an opening that was the exact fit of the male metal snap on the seat but it turns out the plastic was too thick to allow the snaps to come together. Enlarging the hole to 9 mm dia. allowed enough room for the snap buttons to click together nicely.
The C-shaped cut is done with scissors and the opening made smooth and round with a large cylindrical sanding disc on a motor tool.
When finished, insert the side with the C-shaped cut unto the lower part of the leather loop (that's used to hold the seat belts) and the hole unto the snap part of the loop, 2nd photo above. Thread the seat belt, snap the loop and you've got yourself a nice leather seat protector along the seat belt loop area, first photo above. You can attach stickers of your choice as desired, e.g., MB logo, AMG logo, mate's name, favorite sports team, etc. I prefer mine plain and less observable and makes it look almost OEM.
Hope the above DIY is helpful, especially to those with light-colored leather seats.
Below is how it looks from a distance:
Last edited by etyu; 11-23-2007 at 11:36 PM. Reason: updated 3rd pix, added 4th pix
View etyu's Photo Album etyu is online now   http://www.slkworld.com/Boss Key
The Following 2 Users Say Thank You to etyu For This Useful Post:
Old 11-23-2007   #2 (permalink)
Super Moderator
You never cease to impress mate.
Top notch work
Old 11-23-2007   #3 (permalink)
Ynot's Avatar
Looks great, thanks for sharing.
View Ynot's Photo Album Ynot is offline   Boss Key
Old 11-23-2007   #4 (permalink)
-1-
Don
-1-'s Avatar
Eddy, I agree, excellent idea and how to. The beige and ash combo seats are beautiful, but a challenge to keep mark free. I've had a black car, and a car with white seats. Just not interested in those combinations again. Kudos for those that choose those colors.
-----------------1-----------------
---------SLK 55 ///AMG---------
TOP D0WN-URGE 2 DRIVE GOES UP
View -1-'s Photo Album -1- is offline   Boss Key
Old 11-23-2007   #5 (permalink)
Sid
Founding Member #5
Sid's Avatar
Hey Etyu,
How about just making a bunch and selling it to us?
Mods: vario roof, clear side markers, clearbra, V1, tint, Green Filters
Sound: Genesis Profile 5, Hertz Speakers, Image Dynamics
View Sid's Photo Album Sid is offline   Boss Key
Old 11-23-2007   #6 (permalink)
Default What do you think Cyberdrakon?
Originally Posted by Sid View Post
Hey Etyu,
This could be easily done as a fun and quick one- to two-hour afternoon project on a weekend.
I wonder what cyberdrakon's thoughts would be in terms of getting this patented/copyrighted and getting a limited production run. He could add this to his catalog for the different MB dealers to order from him. This would be a good promotional item for the dealers. The dealer's logo could be printed on the plastic.
View etyu's Photo Album etyu is online now   Boss Key
Old 11-24-2007   #7 (permalink)
alroumi's Avatar
Very innovative eddy, thank you for sharing.
Its not an issue with my car, Black leather
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
Old 11-24-2007   #8 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
So simple, cheap and efficient !!!
Great Mod Eddy !!
------Michel------
-SLK 55 AMG 2005-
View Zeiser50's Photo Album Zeiser50 is offline   Boss Key
Old 11-24-2007   #9 (permalink)
Vehicle: 06 Kleemann Slk 200
Send a message via MSN to GregoryGR
Eddy, just great! Very clever!
Well done!
View GregoryGR's Photo Album GregoryGR is offline   Boss Key
Old 06-12-2008   #10 (permalink)
Default Follow-up, need two bits per seat
I found out the other day that the plastic piece only protects the leather on the seat side. It does not protect the underside of the leather loop (that guides the seat belt), and as a result I have almost black linear marks at the underside of the leather loop; easily cleaned off luckily. (see red arrow at pix below, pix already show the two bits in place)
The solution was to make two of the plastic bits and sandwich the seat belt in-between. The hole that goes on the snap part should be enlarged by 1mm so the snap will work, otherwise two plastic bits are a tad thick. Now, the light colored leather is protected at the seat side and at the underside of the leather loop. This should help those with beige, grey and red leather leather seats. Photo below:
Old 06-13-2008   #11 (permalink)
Buckle up shut up hold on / Moderator
FishtailnZ's Avatar
Vehicle: 2006 SLK55
Donation Award
You da man Eddy!
- Bill
2006 SLK55 Caspian Blue/Beige
Stock 1/4 mile results: ET 12.72, trap 110.80, 60' 1.90
O.Z. Ultraleggeras, Magnaflow X-pipe, E55K Airbox, Windrestrictor.
View FishtailnZ's Photo Album FishtailnZ is offline   Boss Key
The Following User Says Thank You to FishtailnZ For This Useful Post:
Old 07-04-2008   #12 (permalink)
Vehicle: '09 SLK350,AMG Appearance Kit, Media and Premium,Red and Beige
Other Toys: Computers, Skateboards
Very Interesting. Awesome idea. I have beige seats. may have to do this.
View XBarbarian's Photo Album XBarbarian is offline   Boss Key
Seatbelt marks on leather !Need ideas! noregret4life SLK R171 General Discussion 30 07-11-2006 10:44 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
