| | LinkBack (15) | Thread Tools |
#1 (permalink)
Country: Thanks: 135
| So I've been kinda promoting Sevas wheels due to the price, they sure look good but the old saying stays true, "You get what you pay for." Please be careful. There has been a lot of troubling stories lately with the Sevas wheels. http://www.bimmerfest.com/forums/sho...d.php?t=224219 http://www.bimmerfest.com/forums/sho...5&postcount=90 http://www.bimmerfest.com/forums/sho...&postcount=116 http://clublexus.com/forums/showthread.php?t=298539&highlight=cracked+rim%2A http://www.clublexus.com/forums/showthread.php?t=300702
__________________ 06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Last edited by Ynot; 10-19-2007 at 07:41 PM. |
Country: Thanks: 288
| Thank's for the heads up.
| Don't know why it did that but link should be fixed, if not then, just type in the whole word, replace ... with "showthread" extremely scary, one of the guys had his wheel blown on him on the highway.
Country: Thanks: 96
| As much as a wheel failure is scary (make that very scary) the failure of one wheel wont bring a car to its knees no matter what speed it fails at. The other 3 will be more than capable of supporting and balancing the weight of the car allowing you to bring it to a controlled stop. What i would be scared of is the shrapnel, the pics in the last linky show really well the explosive force they have and when you have a car like the SLK with wafer thin skin its not going to have any real effect on the speed those pieces are moving at. Only takes one of the fronts to fail and your legs are right in the firing line or for a rear to go and punch a hole in the tank so it can piss fuel onto the hot exhaust, I've not had time to read the threads from start to finish but hopefully they all understand that picking aftermarket wheels is not like picking what amount of tint to use, they are a vital part of the car and form follows function not the other way around and you make exceptions to that rule at your peril. Not one of the things you can go cheap on.
Country: Thanks: 54
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ----------------1----------------- --------SLK 55 ///AMG--------- THE MON55TER ON THE BLOCK Last edited by -1-; 10-20-2007 at 06:21 AM. |
| | #9 (permalink) | |
| i got some new wheels | mikestelfox | General Discussion | 9 | 04-26-2008 08:49 AM |
| Beware the fox | herve431 | Off Topic | 16 | 12-19-2007 07:48 AM |
| I need help with wheels! | jimojameso | General Modifications R171 | 20 | 05-24-2007 07:13 PM |
| Wheels.. | lontong | SLK R171 General Discussion | 13 | 05-05-2007 08:35 AM |
