Bluetooth MMI Adapter - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By MartinatMersea
  • 1 Post By Seanhump
#1 Old 01-10-2017
Vehicle: 2009 350 SLK R171
Hi Guys
I have recently just purchased one of these
https://www.amazon.co.uk/dp/B01JMANY...986871_TE_item
Its a " Mercedes Multi Media Interface MMI to Bluetooth Music Audio Streaming adaptor "
I basically wanted to get my phone music streaming to the car. I have a 2009 SLK
I thought it would just work after some usual bluetooth pairing etc but it seems to need something doing to comand to get it to work. The description on Amazon says'
Mercedes Multi Media Interface MMI to Bluetooth Music Audio Streaming adaptor This cable will work on Mercedes cars which have a Media Interface factory fitted to the car on Mercedes A,B,C, CLS , E, GLK , SL , SLK Class from 2009 on (please note not the Year of Reg The Year that your model was released) The MMI MI interface can be found in either the glove box or arm rest How it works is simple plug the Lead into MMI socket, search on your phone for bluetooth device select the product it will pair up no need for a pass code. On the stereo it you will need to select media then External Media. Sometimes you will need to refer to the user manual to turn external media on then you simple select the song , apps etc on you phone an it will play you audio through the stereo on any bluetooth product, work the same way as bluetooth headphone work. Please note that no art work or text or control from the stereo to the phone works it will only play audio. To Get these function to work this way you need to upgrade the stereo to high model which is about 1600 this is a solution for under 20 that will work on any phone we have tested as of June 2016 if newer phones come out note we won't have tested them but we don't for see any issues
ive been searching online to find out how to turn on external media but have so far been unsuccessful.
Does anyone know how to enable external media?
toyjeep is offline
#2 Old 01-10-2017
Quoted: 3976 Post(s)
@Seanhump
@SoCalBeachRunner
Wavetrac LSD thread here:
#3 Old 01-10-2017
did you get your free datacard?
http://www.slkworld.com/vehicle-data...d-free-us.html
not an expert, do you have this option in your datcard
518 UNIVERSAL COMMUNICATIONS INTERFACE (UCI)
i notified a few experts to this thread
#4 Old 01-10-2017
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 352 Post(s)
Assume you have it connected ok ... ..?
Which headunit do you have ..? Post a pic if you're not sure
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#5 Old 01-10-2017
Hopefully attached is pic of my head unit. Thanks for helping
toyjeep is offline
#6 Old 01-10-2017
I think i do have it all connected correctly. MMI end is plugged in in glove box. Blue light is on on the bluetooth dongle end. Phone connected to the bluetooth device successfully without needing a pass code as per description. In audio menu i have selected media interface but cant find external media. not in the car now but i remember music register (or something similar) being an option and along with the 6 discs and memory card. Tracks play on my phone and no sound comes out the phone as though it is coming out of another source.
toyjeep is offline
#7 Old 01-10-2017
he has ntg 2.5
#8 Old 01-10-2017
MartinatMersea's Avatar
Vehicle: 2012 SLK55
Other Toys: Volvo 480 Turbo, Various Gadgets
Quoted: 131 Post(s)
I have just been to the garage to look at my setup and in the Audio menu you need to scroll down to Media Interface and press OK. Make sure that on your phone that in the Bluetooth settings it actually says that the phone is connected to the dongle you have purchased. According to the instuctions you copied in post 1 you will not see any reference to the music being played ( tracks, artist etc.)in graphical terms on the screen of your head unit. However, you should be able to hear it through the Comand NTG2.5 which is the system you have in the car. For info I purchased a Tune2Air to play music from my smartphone over Bluetooth which is great and it works on the same principal. Hope this helps. Thanks Martin
PS: see picture of audio menu that I took just now.
PPS: Another thought also make sure you turn up the volume on the Smartphone as well as the volume on the head unit.
jbanks15 and Seanhump like this.
Martin
Mods:
CKS Bonnet/Hood Fins
AMG Grill Badge
MartinatMersea is offline
#9 Old 01-10-2017
I just get no device connected message. It's definitely connected physically in the glove box and by Bluetooth on the phone. Volume definitely turned up. Seems I need to enable external media somehow in comand according to the supplier on Amazon?
toyjeep is offline
#10 Old 01-10-2017
Well if Sean don't know ....
let's see what John says @SoCalBeachRunner
#11 Old 01-10-2017
Option 518 Media Interface: What to activate in STAR?
ipod interface, media interface, or DVD changer
#12 Old 01-10-2017
Seanhump's Avatar
Quoted: 352 Post(s)
The Comand stuff is one of the few area's that I've not had much to do with - I went the aftermarket route ..!!
Sean
Mods so far...
Seanhump is offline
Human Verification
Poor man's bluetooth cassette adapter Burt20 General Modifications R170 9 07-17-2014 12:57 AM
NTG1 and HFP Bluetooth adapter with iPhone jas72 SLK R171 General Discussion 9 06-23-2014 06:01 AM
FS Dension Gateway 500 w/ Bluetooth Adapter discoduck SLK Parts For Sale 16 08-22-2011 12:06 AM
Second generation bluetooth adapter? Charlie SLK R171 General Discussion 6 05-08-2007 08:39 PM
