Dash Cams - - Mercedes Benz SLK Forum
 6Likes
  • 2 Post By Seanhump
  • 1 Post By Trev5
  • 1 Post By DucatiSteve
  • 2 Post By ZeroZero
#1 Old 5 Days Ago
Vehicle: 2009 350 SLK R171
Dash Cams -
Hi all.
I've seen Tesco are doing a good entry level dash cam
Buy Nextbase 112 Dashcam with SD Card and Carry Case from our Dash Cams range - Tesco
I know there are obviously much better more expensive units but i want to put one in each of my 3 vehicles and hard wire them so 40 each including the memory card is a pretty good place to start.
Has anyone hard wired a dash cam in a R171 SLK if so what is the best route.
My other cars i know well and have had had dashboards out etc but the I've only just bought the SLK and this will be the first job ive done on it.
Stuart
toyjeep is online now
#2 Old 5 Days Ago
Quoted: 3306 Post(s)
a search of our site reveals some info
https://www.google.com/#q=site:slkwo...ras+hard+wired
https://www.google.com/#q=site:slkwo...1+dash+cameras
Wavetrac LSD thread here:
#3 Old 5 Days Ago
osi
osi's Avatar
Vehicle: 2005 SLK55 AMG R171
Seems like a good little unit. Running wires from under the dash, up the A pillar and along the top windscreen is actually not that daunting as I remember when I ran a mic for my Dynavin Head unit. I'm sure you'll find the know how on SLKW!
Via Taptalk
osi is offline
The Following User Says Thank You to osi For This Useful Post:
#4 Old 5 Days Ago
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 293 Post(s)
I've got mine hardwired in, and the power feed comes from the rear of the accessory socket .. the power cabling runs above the passenger kick panel following the existing wiring for the foot well lights, up the side of the dash behind the interior fuse box panel, up the A Pillar (again, following the existing route) and up to the dash cam which is on the left of the rear view mirror ... The Video out feed follows the same route back to the head unit ...
(Old pics attached - it's now on the other side of the mirror and therefore less visible, and the head unit has been upgraded, but you get the idea ..!!)
etyu and Avel Du like this.
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is online now
#5 Old 5 Days Ago
55russamg's Avatar
Other Toys: Lego
Quoted: 276 Post(s)
Cool
I purchased a Toguard Mini for her indoors.
Including SD card.
Seems quite good.
Cheers Russ
Metalic Mystic Blue - AMG 5.5 Engine
SmartTop
USB socket in Centre Arm Rest
Aluminium mounted LED Side Lights - Nice & Bright
Super White Fog Lamp Bulbs
55russamg is offline
#6 Old 5 Days Ago
Trev5's Avatar
Vehicle: 2010 SLK350 Sports Pack
Quoted: 76 Post(s)
I fixed My Mobius Camera to the left of the rear view mirror, using this bracket:
https://www.joovuu.com/gb/mounts/248...ase-mount.html
Then ran this USB power cable behind the A pillar trim:
https://www.joovuu.com/gb/other/108-...dwire-kit.html
Tricky part is getting the cable down a small gap between the dash board & windscreen.. (Where the Tax disk use to go)
Then wired it into the cables behind the 12v power socket in the passenger foot well - Though I have since bought (but not installed) the piggy back fuse connectors, to go into the fuse box by the passenger door mirror.
One word of warning: When I tried installing My Dash Cam on the Right Hand Side of the rear view mirror, it knocked out the built in Sat Nav signal...
>> Few Pics:
toyjeep likes this.
Trev5 is offline
The Following User Says Thank You to Trev5 For This Useful Post:
#7 Old 5 Days Ago
Vehicle: 2013 SLK250
Quoted: 32 Post(s)
Originally Posted by toyjeep View Post
Hi all.
Stuart
This has a 120 wide angle view. Not really wide angle, get a 170 angle view.
720p high-definition recording. $25 one I just bought for my wife has 1080p.
I think that you can do better for less.
etyu likes this.
DucatiSteve is offline
#8 Old 5 Days Ago
ZeroZero's Avatar
Other Toys: Two Smart ForTwo(carbon footprint. offset) G-Paddles
Quoted: 139 Post(s)
Hi All
If you would like or prefer your dashcam working 24/7 & still start the engine , Try a power-magic unit easy to fit & works well , It will shut the dashcam down if your battery goes below 11.8v etc or after a preset time .
Andy
etyu and toyjeep like this.
2005 Obsidian Black 55 AMG
Black Power Coated Rims with Diamond Cut Edge
Magnaflo Xpipe kept all 4 Cats (now two removed)
Shorty Antenna (no signal type)
Tar.ox Front Rotors
Blackvue DashCam
with In-Car Wifi
AMG Puddle Projectors
Kleemanns Headers
Eurocharged tune
G-Paddles Red Ones
ZeroZero is online now
Human Verification
What dash cams do you use? CH3CK3RZ SNR Off Topic 21 11-17-2016 11:41 AM
Dash cams? slk320chick General Discussion 52 12-05-2013 04:42 AM
Prestigio RR 300 Dash Cam + Tetrax Fix Magnetic Mount randombloke Off Topic 2 09-03-2013 09:13 AM
Russian Dash Cams Berliner Heckflosse Off Topic 0 08-04-2013 07:44 PM
Insurance - Dash cams, snapshot bobl General Discussion 3 07-13-2013 02:18 PM
