R172 AMG Seats into an R171 - Mercedes Benz SLK Forum
 32Likes
#1 Old 06-20-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
My biggest complaint with my slk55 since I got it was the uncomfortable seats. As a bigger guy, with broad shoulders, they just don't work right for me. I found a set of seats out of an R172 slk55 on ebay, so I picked them up. I'll update this thread as I go with what's needed to retrofit them into an R171.
I found a couple threads on here about people putting R172 seats in, confirming that physically they'll bolt up. What I haven't seen is anyone that has retrofitted the electric seats with memory.
The seats that I bought showed up yesterday.
Bengal red seats, complete with seat heaters, air scarf, and adjustable lumbar support.
For reference, the layout of the components on the bottom of the seat
The goodies in the back of the seat
Close up of the seat controller plugs
Prior to ordering, I spent quite a while going over the seat control boxes to make heads or tails over what it going to be necessary wiring wise to change things over. The biggest issue being that the R172 seat control switches are mounted remotely and get appear to get their signals via CANBUS.
On the bright side, the seats have the same wiring connectors coming off the motors, going to the same pins on the seat controllers, etc. A close examination of the 172 seat controller shows that it has all the pins for the 171 seat switch. My current plan is to pull the seat switches off a 171 seat and try them out with the 172 seat controller. If this works out, I will mount the seat switches into the side of the 172 seats. If this doesn't work, I will wire up a 171 seat controller. The 171 seat controller is shared with other MB vehicles that have lumbar support, so I believe I can make that work in a backward compatible way.
bumpa2 and Jules555 like this.
mllcb42 is offline
The Following 2 Users Say Thank You to mllcb42 For This Useful Post:
#2 Old 06-20-2016
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 352 Post(s)
Morning
I looked into the electrical side of this a while ago - I got as far as being fairly happy that the 171 controller would interface to the 172 seat motors, that I coould fit the 171 seat buttons to the side of a 172 seat, and that the heater / airscrf stuff *SHOULD* hook up to the 171 ECU with (possibly) just a change of plugs ...
It'll be interesting to see how you get on - I'd do the same if / when I find a cost effective set of seats ....
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#3 Old 06-20-2016
Minion
slk320chick's Avatar
Quoted: 143 Post(s)
I know there are others that have successfully fitted 172 seats into the 171 by now right? Wouldn't it be nice if there were a magic set of instructions for purchase? Go here, buy this type, pay this guy to put them in..tadahh.. Where is Bradley when I need him.
Commenting to follow-can't wait to see how it turns out.
slk320chick is offline
#4 Old 06-20-2016
Vehicle: 2005 SLK350 Auto Caspian Blue/Beige Trim ,Heating, Lighting, Comfort, Premium, Entertainment w/Nav
Other Toys: 1967 Chevrolet El Camino
Quoted: 184 Post(s)
Very interesting, subscribing to this.
Pioneer4x4 is offline
#5 Old 06-20-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
There are others that have fit the mechanically adjustable ones in. They bolt right in. It's all the electrical goodies that are different in this case. Hopefully this will become the instructions for how to make them all work.
bumpa2 likes this.
mllcb42 is offline
The Following User Says Thank You to mllcb42 For This Useful Post:
#6 Old 06-26-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
I ended up getting a pair of GL550 seat switches for cheap on ebay.
They look like they ought to work as a good substitute for the silver painted r171 seat switches at a fraction of the cost. I'll try to mount them up to the 172 seats like the stock seat switches and go from there. I also ordered a pair of seat wiring harness from an E class. Just something to scavenge some wiring connectors from.
WoZ53 likes this.
mllcb42 is offline
#7 Old 07-02-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
Well, it should come as no surprise that they pass the test fit test
All the wiring connectors hook right up. I'm currently sorting out the mounting of the adjustment switches to the side of the seat...
Do I keep the 172 side trim panel, and try to mount the seat switch? If I do, it'll end up quite a bit further back on the seat and may have some clearance issues.
Do I adapt the 171 side trim panel and try to mount it to the seat? The switch already is mounted, and it fits the space right, but I'll have to make new mounts and find a way to mount the lumbar adjuster.
Do I put the seat switch somewhere else entirely? Makes the mounting issues easier, but means cutting up something else which I'm hesitant to do.
mllcb42 is offline
#8 Old 07-03-2016
Seanhump's Avatar
Quoted: 352 Post(s)
So the bases have changed them - the side panel mounts are different on the 172 seats .?
Sean
Mods so far...
Seanhump is offline
#9 Old 07-03-2016
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Other Toys: Astra 1.9 Twintop
Quoted: 470 Post(s)
Sounds like a brilliant project, looking forward to seeing how it progresses !!
curro101 is offline
#10 Old 07-03-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
Correct. I'll take some photos later today to show the differences.
mllcb42 is offline
#11 Old 07-03-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
Test number 1:
R172 seat controller plugged into GL550 seat switch - doesn't work. Doesn't totally shock me, as the R172 seat controller is likely looking to the CANBUS for signals for seat adjustment, but figured it had the connections for the 171 seat switch, so might as well give it a shot. Oh well. Next step, swap in the R171 seat controller.
mllcb42 is offline
#12 Old 07-03-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
Test number 2:
R171 seat controller, R171 seat switch - Still no luck. Seat doesn't want to move. So much for the super easy solutions. I might actually have to burn some calories on this one.
On the bright side, both the seat heaters and the air scarf work perfectly.
mllcb42 is offline
#13 Old 07-03-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
Test number 3:
R171 seat controller, GL550 seat switch... all 3 plugs actually plugged in.
Everything works, including the lumbar adjust. Apparently if you actually plug in everything, things work a lot better.
Pioneer4x4 likes this.
mllcb42 is offline
#14 Old 07-03-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
Test number 4:
R172 seat controller, GL550 switch with everything correctly plugged in and verified... no movement.
So that's the answer to how to make the electricals work... you need to replace the R172 seat controller in the seat with an R171 unit and wire in a compatible seat switch to plug #7 on the seat controller. The part number for the plug that plugs in to #7 on the seat controller is 0395456528.
mllcb42 is offline
#15 Old 07-04-2016
JudgeMing's Avatar
Vehicle: MY2012 R172 SLK 55 AMG
Other Toys: AN650Z (Grey)
Quoted: 180 Post(s)
Do you have access to STAR? Are there any fault codes reported?
Formerly: AurŽ, black 2005 R171-350 w. AMG package, Akzentrot interior and almost full options.
Current: Metallic iridium silver 2012 R172-55 AMG with red accents, BMC airfilters, ECU tune, KW V3 coilovers, SS brake lines, rear cam, dash cam and almost full options.
JudgeMing is online now
#16 Old 07-04-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
I do not have any STAR access, but no errors are showing up on the dash. I would be curious to find someone with STAR to investigate further though.
mllcb42 is offline
#17 Old 07-04-2016
Seanhump's Avatar
Quoted: 352 Post(s)
Going by the electrical diagrams, I'd figured that a 171 seat controller would be needed to keep things straight forward - keeps the seat controls simple and removes the need to fiddle with the coding (you could extend the short wiring on the 171 seat controls if you wanted them elsewhere in the car ....)
Sean
Mods so far...
Seanhump is offline
#18 Old 07-04-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
That's essentially what I am doing. Using the 171 seat controller box and the gl550 seat controls. They're nearly identical to the 171 seat controls except they're black instead of silver and have one extra degree of freedom that the seat doesn't have. I could mount them pretty much anywhere, but I think a position similar to the 171 seats will be the winner.
jwslk likes this.
mllcb42 is offline
#19 Old 07-04-2016
WarwickThumbNT's Avatar
Vehicle: 2005 SLK200 Obsidian Black Beige leather interior with Vavona wood. Airscarf, Comand, heated seats.
Other Toys: Various basses including Warwick, Fender and Electric Upright Bass
Quoted: 85 Post(s)
Thumbs up
Nice job that man!
WarwickThumbNT is offline
#20 Old 07-04-2016
Vehicle: 2006 SLK55
Quoted: 35 Post(s)
Opted to mount the seat controllers to the 172 side trim pieces. So I made a template off the 171 side trim pieces
and after a while with the dremel and a file
etyu, curro101, rhartson and 1 others like this.
mllcb42 is offline
Human Verification
My modification thread (Includes AirScarf install) Adamantium General Modifications R171 370 08-26-2016 04:10 AM
R171 slk55 and r172 slk55 razr-01 AMGs 115 02-19-2016 08:52 PM
Mercedes-Benz V-Class AMG Line is a Reality, Will Take a Bow in Frankfurt Berliner Heckflosse Off Topic 0 08-26-2015 02:00 PM
AMG 55 nappa seats - colour question Paul Grainger SLK R171 General Discussion 1 08-16-2009 07:03 PM
NY Auto Show AMG Event? editor58 General Discussion 7 03-21-2008 12:32 AM
