Windrestrictor
Old 07-21-2007   #1 (permalink)
Senior SLK World Member
Vehicle: 05 SLK 200
Question ///DVD Module from Piecha\\\
http://www.piecha.com/02b77898be08b6...8eb113f301.php
What I understood from google translate of the page, it also enables to add TV tuner and rear view camera. As far as I know there is no "video in" at the back of the R171 comand and I don't see any in the picture of the module. If it does what it says it is a nice module. I don't have comand by the way but I am interested in this DVD module, it can make me buy a comand
Gero please inform us about this module, you are the man
View diclehana's Photo Album diclehana is offline
Old 07-21-2007   #2 (permalink)
Not really in favor of these myself because they block the speed signal on CAN from reaching the audio gateway so the system thinks your standing still all the time and allows you to view video but if your in a location with no good GPS signal it will also stop your nav from working
Old 07-21-2007   #3 (permalink)
Vehicle: 05 SLK 200
DVD Nav is not working in my country. Maybe there is a way to disable the module likeroof module. Thanks for the quick reply
Old 07-21-2007   #4 (permalink)
Gabus's Avatar
Vehicle: 96 SLK 230K
Other Toys: Volvo L3314N
Piecha writes that it don't affects the navi.....
(Durch die Bildfreischaltung wird das Navigationssystem nicht beeinflusst.)
Gabus
Old 07-21-2007   #5 (permalink)
Yeah i noticed that but to block the signal to the TV part of the system you have to sacrifice it all over the MOST.
I have seen modules like this in use before and its all the same, to be fair so long as you have a GPS signal its not a problem but if you lose the connection the nav will freeze
Old 07-22-2007   #6 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
You're right.
As soon as there is no gps signal (tunnel or very bad reception), the navigation use other sensors : internal gyrometer to detect if the car turns right or left, and speed to detect how many meters the car has done.
------Michel------
-SLK 55 AMG 2005-
View Zeiser50's Photo Album Zeiser50 is offline
Old 07-22-2007   #7 (permalink)
Diclehen, Marcus Piecha got it in his own car. It´s working great, but to watch TV you need something more. (I´m too bad in electronical things and so I don´t try to explain it)
Now, you can watch a DVD and your Navi is working at the same time. In a couple of weeks he will offer one special modul for the roof and DVD
And: he is working for a special Performance exhaust for the SLK200, the Avantgarde forntspoiler gets a change - more agressive, last but not least: There is a special Anniversary program for the 55 to come. It will be tremendous, but I´m not allowed to tell details.
Old 07-22-2007   #8 (permalink)
Vehicle: 05 SLK 200
As I told you before you are the man in Germany. I am not interested in DVD Nav as I told you before. But it is nice to hear module works fine with it. I need to understand how I can connect rear view camera and TV tuner to the comand. Because I did not see any video in's in the module. when you shift to the rear gear is the camera activated? Do you press Video button to go between a camera,DVD and TV?
Old 07-22-2007   #9 (permalink)
I understand it in that way: if you don´t watch a DVD and press the video button it switches to the rear camera which you have to install first.
Old 08-08-2007   #10 (permalink)
Vehicle: CLK 500 Cabriolet
By pressing 3 buttons on Comand you can set the DVD Player to play while in motion. FOR FREE! I cannot understand that Piecha would be up to a rip off like that one!
View jamesbond007's Photo Album jamesbond007 is offline
Old 08-08-2007   #11 (permalink)
Here you go:
This guide will unlock the comand console v2.0 for the following
Mercedes cars -
CLS - W219
ECLASS - W211
SLK - R171
S CLASS W220 (WIDESCREEN)
SL R230 (WIDESCREEN)
INSTRUCTIONS
Press the audio button to get into audio mode.
To access the engineering mode
Press and hold the mute button (mute)
Press and hold the phone button (phone
Press and hold the serv button (serv)
Simultaneously hold all 3 buttons for about 45 seconds until you
get a message on the screen which says "Welcome to
Engineering Mode"
To enter the secret menu
Press and hold the “*” star key
Press and hold the “#” hash key
Press and hold the “<” arrow left key
Simultaneously hold all 3 buttons as indicated above –
To access the video in motion menu press the button next to
Dr.Dist.
Using the arrow keys deactivate all of settings with the OK button
Press the back button to get back to the main menu.
To access the DVD region menu, press the button next to regcod.
Using the arrow keys, highlight the region free setting and enable it
using the OK button.
To activate the settings press back then end and switch the
command console off then back on again.
All setting may be activated and de-activated as many times as
you want.
Old 08-08-2007   #12 (permalink)
Founding Member #8
Vehicle: 2004 SLK350
I thought Engineering Mode has been disabled in the latest firmware up(down??)grade.
1999 Ducati ST2
2003 Vauxhaul Vectra
1974 Triumph Bonneville 750
T140V
1937 Norton 500 single
(all still current)
Old 08-08-2007   #13 (permalink)
The instruction works for all models from 2004 to 2007? Which wonder...
Old 08-08-2007   #14 (permalink)
Anyway, worked on mine (2005)
Old 08-08-2007   #15 (permalink)
The code is working until year 2005, no longer In that year "Q" died
Old 08-08-2007   #16 (permalink)
OK, if that is the case, I understand why Piecha developed a module.
Old 10-13-2007   #17 (permalink)
Silver Supporter
Vehicle: 2009 Mars Red SLK55
So what is the consensus on DVD modules? Will they stop the NAV from working properly? Is there anyway to have the DVD module without affecting the Nav? What about the Mods4Cars DVD module?
View smoothbnzf4n4tc's Photo Album smoothbnzf4n4tc is offline
Old 10-13-2007   #18 (permalink)
Stay away from them they will stop the nav functioning correctly and store fault codes
Old 10-14-2007   #19 (permalink)
Sidenote: Welcome SmoothBnzf4n4tc
Piecha Vario-roof module issue? ghostdunks
