| Senior SLK World Member Join Date: Dec 2006
| I own a 06 RHD slk350 and I'm having some difficuilty installing the smarttop module. I got through removing the caps and carpetting fairly easily but i'm stuck on some parts, I'd be glad if anyone could give me a hand. . First I do not quite understand step 9 where it states "becaus of the module's universal compatibility and different pin-assignments used by MB all moduls are shipped with just the black pins on the ends of the wiring harness, along with the needed plastic caps. Insert the pins on the module wire harness into the supplied plastic caps........." When I got the module the wires ar already inserted in the caps in the correct positions as stated in the pictures, so I'm just going to take it as I dont have to do anything here. Then for Step 11 about the red wires, I've literially searched for more than 1 hour and I can only locate 2 red wires, one is extremely big, and the other one is intertwined with another white wire. I've already red some of the other posts of previous installations so I know neither is the one I want, but there is no other red wire!?!? I see a red and purple one but thats for SLs instructions. I do not want to tap my wires in the fuse boxes because that can be easily spotted by MB mechs and also its on the wrong side. What should i do here? any clues? |
Country: Thanks: 376
| Here's a link to RHD install:http://www.benzworld.org/forums/r171...ht=RHD+install Check out post #24 and 25 on page 3.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. Last edited by etyu; 06-29-2007 at 03:22 PM. |
| That is not bad for a RHD vehicle. It took me about the same time on my first install and that's on a LHD vehicle. Subsequent ones take about 60 to 90 minutes.
| SmartTop Roof Module Updates for 09 SLKs | WhiteRabbit | SLK R171 General Discussion | 13 | 09-17-2008 09:01 PM |
| Installing speakers - how? | SteveSLK06 | General Modifications R171 | 7 | 07-17-2008 03:09 AM |
| SmartTop Module | Woolly | General Modifications R171 | 20 | 04-08-2008 05:18 PM |
| Original Issue Piecha module vs SmartTop, personal impressions | etyu | General Modifications R171 | 36 | 04-07-2008 12:19 AM |
| Anyone have the Smarttop module and/or green filters? | ppower | Help and Support | 9 | 03-05-2007 11:56 AM |
