Welcome to SLKWorld
Old 06-06-2007   #1 (permalink)
Talking LED Bulb Rear Turn Signal Light Upgrade
Today I replaced rear turn signal bulbs to LED bulbs. I bought 3W amber LED 1156 bulbs from eBay and planned to put 8 ohm 50w load resistor to make them as 21w - oem bulb is 21w. Unfortunately, it has been very hard to find and buy 8 ohm 50w power resistor. I just got bulbs today and tried without load resistor.
IT'S WORKING FINE WITHOUT LOAD RESISTOR!!!!
I think the bulb is 3w and 3w is enough to avoid bulb faliure warning!
It's almost direct replacement. Only two modifications I did to fit the bulbs:
1. grinding off one of the pin on the bulb because it's 1156 not 1156A, so pin position is different.
2. grinding off four tabs inside bulb holder because LED bulb shape. (see 3rd photo)
I'm really happy because I don't need to tab wires to put load resistor!
It's very clean installation. I decided to replace front turn signal bulds and rear backup light bulbs with 3w LED.
They are really as bright as oem bulbs and blinking action looks very cool!!!
View zxxn's Photo Album zxxn is offline
Old 06-06-2007   #2 (permalink)
Vehicle: SLK55 2006
Hm...looks cool, any pictures with the lights on? any chance of before and after?
Old 06-06-2007   #3 (permalink)
Sorry, I didn't take pictures for before and after. But, brightness is same to oem bulbs. The LED elements in that bulb are chip LEDs. Those chip LEDs have almost 180 degree wide beam angle. It's amazing...
Old 06-07-2007   #4 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
Whaooo !
i've tried to do the same.
My results :
a) With a led bulb, it is not so bright as the original bulb . i've tried with two different kind of bulb :
- http://superbrightleds.com/specs/1157-x24.htm,
- http://autolumination.com/1156_1157.htm (lighttower more than 3W)
It seems that you have found a better bulb than me. Do you have some info regarding the bulb manufacturer (or seller) ?
b) Impossible to install my the led bulb without a resistor. Maybe your led bulb eats more amps.
So, for the time being, the original bulb remains.... But i have to test your bulb.
------Michel------
-SLK 55 AMG 2005-
View Zeiser50's Photo Album Zeiser50 is offline
Old 06-07-2007   #5 (permalink)
Does your 3W LED bulb require load resistor?
Maybe my LED bulb is more than 3w.
I ordered same type LED bulbs for front turn signal lights.
When I get them, I will measure resistence. 12V 3W bulb should be 48ohm
and 12V 21W bulb should be 8.25ohm...
I will calculate wattage of the bulb based on resistence.
I think the reason my LED bulb is brighter than conventional LED bulb is
its chip LED elements have wide angle light beam(almost 180 degree)
and the beam pattern uses turn signal light reflector well....
Old 06-07-2007   #6 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
Zxxn,
i'm not sure you will able to make a impedance measurement with led. Only current measurement is possible. I will check on my side with the bulb data sheet in order to understand why a resistor is needed for me and not for you.
Is it this bulb : http://cgi.ebay.com/ebaymotors/VLEDs...spagenameZWDVW
------Michel------
-SLK 55 AMG 2005-
Old 06-07-2007   #7 (permalink)
Vehicle: 99 SLK230
Other Toys: TOO MANY TOYS
I can answer them questions. In France the electrons are different. Mama said snails have something to do with it, I don't know about that, but mama is always right. I will ask Bubba this afternoon , he is tha resident electronics xspert, he wired up the lights on my tracter when me an everybody else gave up. Them lights work jus fine now, cept when it rains or tha sun is too hot or when tha moon is low in tha sky or when tha dawg barks.
View 412driver's Photo Album 412driver is offline
Old 06-07-2007   #8 (permalink)
Originally Posted by Zeiser50 View Post
Yes, that is same one I bought.
Old 06-07-2007   #9 (permalink)
Senior SLK World Member
Vehicle: 06 SLK55 AMG
i wonder how does it look like at night?
can you take some pic and show us?
View leelk's Photo Album leelk is offline
Old 06-07-2007   #10 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
i love this kind of humor . !!! Great !!!
i don't know if you smoke the herb behind your house .....
But do not change your stuff !!!
------Michel------
-SLK 55 AMG 2005-
Old 06-09-2007   #11 (permalink)
Default LED Front Turn Signal Lights....
I received LED bulbs for front turn signal lights this morning. As this type of LED bulbs has polority, first try failed....
After flipping the bulb, it's working fine....
As everyone knows, it's really painful replacing front turn signal bulbs.
After having tons of scratches on my wrist, I completed replacing bulbs and I'm happy.
No pain no gain.....
Old 06-10-2007   #12 (permalink)
Did you need resistors on these? (front signal indicator lamps).
Old 06-10-2007   #13 (permalink)
Vehicle: 99 SLK230
A smile is worth 10000 words and adds 2 days to your life. Hope my BS and humor gives you 1000 smiles a day.
Old 06-10-2007   #14 (permalink)
I heard an anecdote that laughter and smiles add to one's longevity. Certainly proven in studies that a positive attitude at the outset of a significant illness usually yields better survival rates/data.
Keep it up Doug. Don't stop!
Old 06-10-2007   #15 (permalink)
No resistors needed. That's why I put these LED bulbs. I don't like putting resistors because they produce extreme heat and need to tab wires.
Old 06-10-2007   #16 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
i need to try them !
------Michel------
-SLK 55 AMG 2005-
Old 06-18-2007   #17 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
Bulb has been bought.
Hope i will receive them before my next trip in Japan (next week).
i will post some "piturs" of the result, for each model.
------Michel------
-SLK 55 AMG 2005-
Old 06-18-2007   #18 (permalink)
I have a stupid question, if they're just as bright then wats the pointin changing them?
View phatchink's Photo Album phatchink is offline
Old 06-18-2007   #19 (permalink)
Vehicle: SLK55 2006
They light up faster, and SHOULD last longer.
Old 06-18-2007   #20 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
Switch on and off faster. No other reason than cosmetic .
------Michel------
-SLK 55 AMG 2005-
View Zeiser50's Photo Album Zeiser50 is offline &n
