| Register | SLK Products | Clubs | Garage | Blogs | Members List | Social Groups | Search | Today's Posts | Mark Forums Read |
| General Modifications R171 Details that make your car different |
| | #161 (permalink) |
| Founding Member #2 Join Date: Jun 2006 Location: Orange County, CA
Country: Thanks: 1,263
Chats: 5 | (I am speechless).
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake. Last edited by etyu; 10-02-2006 at 07:52 PM. |
| Sponsored Links | |
| | #162 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Ok everyone... Here are the install and programming instructions. If anything is unclear, please let me know and i will make the changes. http://www.angelfire.com/planet/nore...leyman___1.pdf |
| | #163 (permalink) | |
Chats: 5 | Quote:
MAGNIFICENT WORK. Very professional. A work of art.I can see why it took some time to assemble the Kleyman 1, 3rd Brake Light Flasher Module v1.5. Just one quick question. On what panel are the two silver pins located (between which the resistor assembly would be attached)? I haven't had the chance to open the black plastic panel, I guess this should be self-evident when the panel is removed.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake. | |
| | #164 (permalink) |
| Don - Founding Member #4 Join Date: Jun 2006 Location: Virginia USA
Country: Thanks: 227
Chats: 0 |
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ----------------1----------------- --------SLK 55 ///AMG--------- 19s AND ALL THE GOOD STUFF |
| | #165 (permalink) | |
| "Sergeant At Arms" Join Date: Jun 2006 Location: Valrico, Florida
Vehicle: 2009 SLK 55 AMG
Country: Thanks: 167
Chats: 11 | Quote:
__________________ Jeff, Retired US Army Master Sergeant 2009 SLK 55 AMG Black/Black Premium 1, Multimedia, Lighting packages Clearshield Protective Film OEM MB Plexiglass Windscreen Tinted Clear Side Markers w/LED Bulbs LED License Plate and LED Parking Light Bulbs (SLK Store) Smarttop version 3.22 Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works) | |
| Sponsored Links | |
| | #166 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
I guess i didn't make that clear if you are just reading the instrucitons and not installing. Once you open the rear panel, the 2 silver pins are actually the mounting spots for your license plate on the ouside of the trunk lid. Can't miss them. There is very little room behind the panel, and the spot where to attach the resistor is smack in the middle away from everything. | |
| | #167 (permalink) |
Chats: 11 | nr4l, you did such a great job on the directions. i am going to go through this whole thread and see if i missed any videos. i see the standard and the burst. do you plan on attaching any new vids based on the 5 switch positions? Thanks question concerning service mode: by default strobe burst no repeat is on. the blue dial is then at what position? full clockwise or full counter clockwise? in other words, if i want to go to service mode immediately, other than flipping 2 off and 3 on do i have to move the blue dial at all if i never have used flash? thanks
__________________ Jeff, Retired US Army Master Sergeant 2009 SLK 55 AMG Black/Black Premium 1, Multimedia, Lighting packages Clearshield Protective Film OEM MB Plexiglass Windscreen Tinted Clear Side Markers w/LED Bulbs LED License Plate and LED Parking Light Bulbs (SLK Store) Smarttop version 3.22 Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works) Last edited by jbanks15; 10-03-2006 at 12:03 PM. |
| | #168 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
I'm not sure if those videos are still active, but i am trying to figure out how to put together an animated .gif pic, so it will be easy to download and host long term. hope to have that up soon. | |
| | #169 (permalink) |
Chats: 11 | you probably missed my question. hope it is not confusing: question concerning service mode: by default strobe burst no repeat is on. the blue dial is then at what position? full clockwise or full counter clockwise? in other words, if i want to go to service mode immediately, other than flipping 2 off and 3 on do i have to move the blue dial at all if i never have used flash? thanks
| | #170 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
The blue dial is in "middle" position by default. So in order to go directly to service mode, you would need to flip 2 off, 3 on and turn the dial clockwise till the end. Just to clear things up. The blue dial controls the rate of flashes during the "flashing" modes and "Constant Blinking". Not strobe burst. By selecting 2 off, 3 on, you are going into "Constant Blinking" mode, and by turning the blue dail, you are actually increasing the rate of the blinks to a point where it is constantly on. Also, i just wanted to add that you can feel free to play with the various modes as much as you like. No need to power the car off either. Just lay off the brake and make adjust the settings, then test, and repeat if you like. | |
| Sponsored Links | |
| | #171 (permalink) |
Chats: 11 | excellent reply. thanks. you should get the check tomorrow or thursday.
| | #172 (permalink) |
| Fanatical SLK World Member Join Date: Jun 2006 Location: North Carolina
Vehicle: ///AMG 06
Country: Thanks: 28
Chats: 0 | Fantastic instructions mate. Very professional. Have you not got some macroflash software? it should be quite easy to create a little example of the various modes in falsh. |
| | #173 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
Will be looking into that. | |
| | #174 (permalink) |
| SLK World Member Join Date: Jul 2006 Location: Athens, Greece
Vehicle: '06 SLK 200 K, '06 C 200 Sports Coupe
Chats: 0 | noregret4life, I like most this flashing: http://vid67.photobucket.com/albums/...u/MOV00801.flv. This is the module's default behavior? Which mode is it, "3 Flashes, no repeat"? If I also install LEDs for the license plate, will the car be affected due to the 3 resistors that will be installed? Forgive me about this if I'm wrong but I haven't performed such action before. |
| | #175 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
thanos, check my PM... | |
| Sponsored Links | |
| | #176 (permalink) |
Chats: 0 | noregret4life, don't you check your PMs?? ![]() What will happen if the brake light (or even the LEDs at other lights) burn? How can we change the light/LED in this case? |
| | #177 (permalink) | |
Vehicle: 05 55 (Brabus 6.1 S)
Country: Thanks: 352
Chats: 28 | Quote:
Cut him some slack with ya
| | #180 (permalink) |
| SLK World Member Join Date: Mar 2008 Location: Long Island, NY
Vehicle: RED SLK350
Chats: 0 | noregret4life, I was thinking instead of using a resistor to fake out the computer. How about a small 12v light bulb attached across from +12 and gnd? it will a lot less heat generated. I did that to fake out a Bimmer for my friend's aftermarket HID . I tried it last night and it worked on the my 05 slk... |
| Sponsored Links | |
| Bookmarks |
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/general-modifications-r171/298-brake-light-flasher.html | ||||
| (Center) 3rd Brake Light Flasher - Page 2 - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 12-07-2006 05:37 PM | |
| (Center) 3rd Brake Light Flasher - Page 2 - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 12-07-2006 03:01 PM | |
| (Center) 3rd Brake Light Flasher - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 10-03-2006 01:10 AM | |
| (Center) 3rd Brake Light Flasher - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 09-19-2006 01:56 AM | |
| White third brake light | bejak | General Modifications R171 | 6 | 09-26-2009 12:09 AM |
| AMG smoked rear light clusters / 3rd brake light. | jfb1977 | Where to get R171 SLK Items | 2 | 07-24-2008 12:40 PM |
| 3rd brake light flasher | st2288 | General Modifications R171 | 21 | 05-23-2008 11:11 AM |
| 3rd Brake light flasher | noregret4life | General Modifications R170 | 30 | 12-21-2007 12:22 PM |
| Fitted the brake light flasher | PAPA | General Modifications R170 | 21 | 11-21-2006 04:47 AM |
