| Register | SLK Products | Clubs | Garage | Blogs | Members List | Social Groups | Search | Today's Posts | Mark Forums Read |
| General Modifications R171 Details that make your car different |
| | #21 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
The module i am looking into is indeed a timed relay. however there are no moving parts like on a relay... all digital alroumi, as always Thanks for the support! | |
| Sponsored Links | |
| | #22 (permalink) | |
Vehicle: 2006 Designo Mocha Black SLK55 AMG
Country: Thanks: 677
Chats: 1 | Quote:
, Ive got your back
__________________ 06 Designo Mocha Black SLK55 AMG 06 Porsche Cayenne S 07 Jaguar XKR Coupe' | |
| | #23 (permalink) |
Chats: 0 | Another thing to maybe keep in mind. If you somehow add a resistor or something to fool the computer while the lights are blinking, doesn't that mean the computer will also be fooled when the light actually burns out? |
| | #24 (permalink) | |
Chats: 1 | Quote:
| | #25 (permalink) | |
Vehicle: 05 55 (Brabus 6.1 S)
Country: Thanks: 352
Chats: 28 | Quote:
It would be impossible to indefinitely fool the computer as adding resistance to the circuit or removing resistance from the circuit will generate warnings the power would have to be switched to the resistor only when the unit had the lights in the off phase. Hope this makes sense Dan
| Sponsored Links | |
| | #26 (permalink) | |
Chats: 1 | Quote:
| | #27 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Dan, You are correct. The Benz lighting system constantly monitors each exterior bulb. Therefore if a resistor is needed, it must be connected at all times. The 2 thing that make adding a resistor ok, are: 1. LED lights have a huge lifespan, so the chance of it actually burning out is slim unless there is an outside factor, like water or such. 2. Each one of us is so crazy about our cars, we hardly need the lighting computer telling us a bulb is out... we will damn well notice it ourselves ![]() I will be able to provide some feedback tomorrow when i crack open this pandora's box of electronics. Also follow up for the motion sensor will come as well. |
| | #28 (permalink) |
Chats: 28 | Thanks noregret, Just one query the lighting system monitors increased resistance also so would a permanent resistor in the current not cause problems i.e. the system would behave normally when the light is off but would generate fail messages when the lamp is on because of increased resistance? It might not matter anyway i was looking in WIS and on document says the stop lamp is monitored but a newer document says that it is not in he loop for the same reason you gave in for number 1 in your last post it might be worth pulling the wire and trying the brakes see if you get an error. If you don't then you can save adding a resistor to the system it could just cut the power to the lamp and be done with it no extra hassle. Keep me posted mate hopefully it all goes well for you. Dan
| | #29 (permalink) |
| Founding Member #2 Join Date: Jun 2006 Location: Orange County, CA
Country: Thanks: 1,263
Chats: 5 | Noregret, please also include some pix on which screws or pins to remove at the back panel that is attached to the lid, which wires to connect to, etc., Thank you for all your modifications.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake. |
| | #30 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
If what you say about the 3rd brake light is true in terms of not being monitored as the other 2 brake lights, then this will be cake to mod with a flasher. However i remember reading in the manual there is an error message for the center brake light as well, which would lead me to think it is monitored. Either way, i can find out once i get it open, but the damn rain here is putting it off. etyu, camera is still on the fritz, but i can see if i can get a loaner again. HAHA, maybe i should start my own webpage for mods like Piecha did... The "Kleyman" modules > Hey that sounds close to Kleeman... maybe we are of the same stock | |
| Sponsored Links | |
| | #31 (permalink) |
Chats: 28 | OK noregret i just checked again and my WIS just says it monitors both but i don't think we have carried out any mods to the system so you are in a better position than me to comment on what degrees of resistance it calls normal as the computer documents don't mention exact numbers and you have first-hand experience. My manual makes no mention of the third light being monitored neither does the WIS backup-light diagram however another WIS document does say it is monitored but obviously has no backup lamp so i cant be sure maybe my EU version is not monitored and your US one is as you say you will be able to tell when the cover comes off and from experience with harnesses they are normally of high enough quality to withstand extra loads as you say there won't be a massive resistance increase so i would bet that they can handle it alright. Good luck and nice idea with the web page you would have my support with it mate. Keep us posted Dan
| | #32 (permalink) | |
Chats: 5 | Quote:
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake. | |
| | #33 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Well here are the results my friends... The 3rd brake light is monitored by the lighting computer, and gave me an error when disconnected. First i checked if the system monitored resistance, or just a closed circuit. Connected a 194-type LED bulb containing 5 LEDs > got a Bulb out warning. System pulses 12v to sense resistance. Connected a 5w resistor to the circuit along with the 194-type LED bulb... Whalla! no error message. What this means is that the LED cluster has a built in resistor that i can not get to. The mini harness connects to the 3rd break LED cluster and is very easy to get to from the trunk lid. So what does all this mean... If the flasher module continues to draw power while connected, i have a feeling it will provide enough resistance on its own. If however it does not have enough resistance, then a 5w 12v resistor such as the one i tried will do the trick. Downside as mentioned earlier is that if the 3rd break light ever actually burned out, the system would not give you an error. (chance of this actually happening is slim to none) and for us SLK crazy people, i think we would notice on our own ![]() I will contact the company, and have them put one together for me... I think hands on testing in this case will be the only way to get it figured out as none of these people have any knowledge how it would react with our lighting computer. |
| | #34 (permalink) |
Chats: 5 | To get to the wiring harness/wiring loom of the third brake light, do you just remove the 5 plastic pins holding the black plastic to the lid? When everything is figured out, could you post the tutorial? Supplier (web address or phone no.), part no., resistor specifications, etc., Thanks again.
| | #35 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
I will post up all the details, part numbers, modules, and so on once i get it all together. | |
| Sponsored Links | |
| | #36 (permalink) |
Chats: 28 | Hey buddy, Glad you got it sorted it appears the older document is right then i will be sure to send the result to MB. Just a 5w resistor was all it took i thought it would be a little more than that well done on the testing. Surely the flasher would just short the connection and bypass the light fixture that would be the simplest option would it not and that would still allow current flow via the module but then these things don't always follow the easy option do they but if the small resistor is all it takes then it does not make a massive difference anyways would the company knock a unit up with the resistor installed to simplify the install further? Good luck Dan
| | #37 (permalink) | |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Quote:
I doubt they will install one for me, however, as you said it may not need one since the flow of current still continues when the module is connected in-line. If they built this unit with a capasitor so that it continuesly draws power, but flashes depending on timing relays, Then we won't need a resistor at all. So it is a good thing in this testing phase that the module comes without one. I can solder the resistors on for all interested and ship out directly. (international is ok too) Looks like its time to place an order and take it from there. Last edited by noregret4life; 07-23-2006 at 11:18 AM. | |
| | #38 (permalink) |
Chats: 28 | Good Luck mate hope it all goes well when the module turns up. Keep us posted Dan
| | #39 (permalink) |
Chats: 5 | Good luckx2. You've at least one very interested person.
| | #40 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
Chats: 0 | Just wanted to give everyone interested an update: The module should be arriving this week (i hope) I already have a resistor ready incase it is needed... Will post details once i have a go at it... can't wait to get my hands on this new mod... |
| Sponsored Links | |
| Bookmarks |
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/general-modifications-r171/298-brake-light-flasher.html | ||||
| (Center) 3rd Brake Light Flasher - Page 2 - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 12-07-2006 05:37 PM | |
| (Center) 3rd Brake Light Flasher - Page 2 - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 12-07-2006 03:01 PM | |
| (Center) 3rd Brake Light Flasher - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 10-03-2006 01:10 AM | |
| (Center) 3rd Brake Light Flasher - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Refback | 09-19-2006 01:56 AM | |
| White third brake light | bejak | General Modifications R171 | 6 | 09-26-2009 12:09 AM |
| AMG smoked rear light clusters / 3rd brake light. | jfb1977 | Where to get R171 SLK Items | 2 | 07-24-2008 12:40 PM |
| 3rd brake light flasher | st2288 | General Modifications R171 | 21 | 05-23-2008 11:11 AM |
| 3rd Brake light flasher | noregret4life | General Modifications R170 | 30 | 12-21-2007 12:22 PM |
| Fitted the brake light flasher | PAPA | General Modifications R170 | 21 | 11-21-2006 04:47 AM |
