Go Back   SLK World Forum > Mercedes Benz R171 SLK Class Cars > General Modifications R171
Tire Rack- Revolutionizing Tire Buying
LinkBack (4) Thread Tools
Old 05-29-2007   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Vehicle: SLK280
Default Install of HIDs into R171 SLK
Finally got around to installing a HID kit for my low beam headlights on my 2005 SLK280, and I've detailed the install as follows.
A big help from stevenlau from this thread(http://www.slkworld.com/help-support...-kit-r171.html), whose picures and commentary were very useful. He mounted his ballast on a cross beam that for some reason, I didn't have in my car, so I had to find an alternate mounting location.
Here's a picture of the kit. Its not my kit per se(I forgot to take a pic when I first got it), but I've been told its the same thing, so I took the pic from a guy who was selling the kit(sorry!!). Its a Kingwood kit made to replace H7 halogens with 6000k H7 HID bulbs, and I'm led to believe that it is waterproof and shock-resistant. All the cable connections seem to be made with water resistance in mind(ie. they have seals, etc..) and theres a picture of the kit working in water here http://www.mobilehid.com/
The kit comes with ballasts, 2 H7 HID bulbs, mounting brackets, some nuts, bolts, washers, and wiring harnesses. There are two wiring harnesses, one for connecting as such: stock H7 bulb fitting -> blade connectors to wire -> wire to ballast to convert voltage -> from ballast to H7 HID bulb.
The other harness is an addition to the first harness and has relays and fuses in the harness, and is designed so that the stock H7 bulb fitting is connected to the relay, which then triggers a direct connection from the battery to the ballast, which then leads to the bulb. I decided to NOT use the relay harness for 2 reasons 1) the wires that came with the harness weren't long enough to get to the battery AND connect to both lights and 2) figured that the electrical system in the SLK was robust enough to handle it without a relay, as Dan mentioned that its pretty strong. Making this decision to not use the relays also resulted in a favourable side effect later on(I think...).
I took a picture of the beam pattern against a wall with the stock halogens. Also marked off the beam pattern with some masking tape, so I could compare later to see if I had inadvertently misaligned it while installing.
Picture of the underside of the light assembly. To get to this, I basically had to undo all the screws fastening the plastic liner in the wheel well. All up, per side, its 6 grey screws, and 2 silver screws. Its a bit of a pain putting it back on so all the screws fit as well. While unfastening the plastic liner, I just turn the wheel all the way to one side or the other to get access to the screws, and while working on the mounting, I turn the wheel inside. Its enough room to get access to everything. In this picture, you can see where the metal beam that stevenlau mounted his ballast doesn't even exist on mine(!!!), so I decided to screw the mount to those plastic black portrusions pointing down(outlined in red). I just got some self-tapping screws from the hardware shop to do that.
View ghostdunks's Photo Album ghostdunks is offline   http://www.slkworld.com/Boss Key
Old 05-29-2007   #2 (permalink)
Vehicle: SLK280
Pictures of the stock H7 bulb with the metal retainer on the bottom. This metal retainer is what is used to secure the bulb to the housing, which is different to how bulbs are usually secured. AFAIK, bulbs are usually clamped to the housing, but in the SLK, it uses this metal retainer. Stevenlau had to dremel a hole in the metal retainer to fit his bulb in, but I decided not to make any changes to the metal retainer just in case I had to restore to stock halogens. The tabs outlined in red are what are used to lock the bulb into the housing. The bit outlined in blue denotes the bottom of the bulb/retainer assembly. The small metal bit on the left forces the whole assembly to only go in one way, with that metal bit on the bottom.
Pictures of the HID bulb. As you can see, because I didn't want to make any changes to the metal retainer, I decided to cut the wires leading to the bulb and replace with crimped connectors. This lets me insert the HID bulb into the metal retainer(without modifying the retainer), then connect it back with the cut wires on other side. If I didn't cut the wires, I wouldn't have been able to fit the wires connected to rubber grommet through the hole in the metal retainer.
Pictures of the HID bulb fitted to the metal retainer. As you can see in the pictures, with the way the HID bulb is constructed and because of the metal bit which forces the bulb to be only mounted in a certain way, this means that the metal strip on the topside of the HID bulb is on the top side. Wasn't sure if this was the right orientation because on other installs I've seen in other cars, the metal strip is on bottom side. Checked with Dan and -1-, and they both said that on the factory xenons, the metal strip is on top, so I guess its all OK!
Here's the dustcover after I had modified it to fit the rubber grommet. All I did was drill/dremel a hole in the dustcover large enough to fit the grommet, then inserted the grommet into it. Easy as pie! I was going to seal the edges with silicone, but the fit was pretty tight, so I just left it.
View ghostdunks's Photo Album ghostdunks is offline   Boss Key
Old 05-29-2007   #3 (permalink)
Vehicle: SLK280
Pic of the HID light installed on one side. You can compare the brightness and color difference with the stock halogens. I had also changed the stock parking light(type w5w) and fog light(type 9006/HB4) with some Phillips CrystalVision halogen bulbs, which are supposedly 4300k in colour. The parking light seems white enough, but the fog light still seems pretty yellowish, but there does seem to be a difference in colour if you compare to stock.
Pic of the completed install from the inside. You can see here the wires coming out of the dustcover, which then lead to the ballast mounted underneath the lighting assembly. I also thought it was a good idea to use some sticky-backed felt on the ballast so that where it had contact with the metal mounting bracket, there was some felt there to take the shock and to avoid metal on metal grinding. It also made the ballast sit nice and tight inside the bracket.
Pic of the beam pattern after I had installed the HIDs into both headlights. As you can see, the beam pattern matches the stock halogens(marked by the masking tape) so there probably wasn't any need to get the beam pattern adjusted. I went to the dealer anyway just to double-check it, and they confirmed that there was no need to adjust the beam pattern at all. You can also compare this pic with the picture of the beam pattern with the stock halogens and see the colour difference is quite dramatic.
Pic of the car with both headlights replaced with H7 HID bulbs, parking lights and fog lights replaced with 4300k halogens
The "favourable" side effect I alluded to earlier, which I attribute to connecting the HID bulbs direct to the stock halogen bulb fitting, and NOT using a relay, is that I never got the strobing. This was an effect that a lot of other people had experienced after they had installed their HIDs whereby, if they turned the lights on without the engine, it would be fine, but if they turned the engine on, the HIDs would flicker or strobe. Rapid voltage pulses like this will cause damage to the ballast. This flickering or strobing was attributed to, as far as I know, the onboard computer where it detects a problem with the bulbs because the resistance is too low, so it thinks the bulbs have blown. The fix for this was to get the dealer to set Xenons=Present on the gateway, so that it expects less current(as the HID bulbs only use 35w as opposed to 55w for stock halogens). I'm still not exactly sure whether this is right or not, just that I never got the strobing effect from the start, and I think it was because I didn't use the relays.
I did go and get the dealer to set Xenons=Present today anyway just to make sure I wasn't causing any inadvertent faults, and also to check the beam pattern. Told them to change it in two places, the Main diagnostic in controller, and also the Gateway, as that was what I had found from other threads on installing HIDs. They could only find the Gateway setting and changed it, but couldn't find the other setting. Not sure if this will cause any problems, but I didn't have any obvious issues before I had the setting changed, so its not like I can check whether the strobing occurs at all.
Anyway, very happy with the finished product. Now thinking if I should change the stock fog lights for HIDs(so they match the headlights), only problem would be to find a place to mount another ballast!
The Following User Says Thank You to ghostdunks For This Useful Post:
Old 05-29-2007   #4 (permalink)
-1-
Don
-1-'s Avatar
Great job, great results. Thanks for taking the time to record with pictures and narratives for others to use. I notice your "whites are whiter" and your "brights are brighter". You might not understand that, it's from a bleach commercial and I thought it would apply. Regarding your fog lights. I removed the ugly yellow looking bulbs and replaced with aftermarket 5000k halogen bulbs rather than going with a HID fog kit. I don't think I'll use the fogs much, but if I do, the color is real close to the 5000k Philips HID bulbs I recently replaced. Cost for bulbs was about $10. Again, fantastic work and thanks for sharing.
-----------------1-----------------
---------SLK 55 ///AMG---------
TOP D0WN-URGE 2 DRIVE GOES UP
View -1-'s Photo Album -1- is offline   Boss Key
Old 05-30-2007   #5 (permalink)
Life is good...
V8SLK's Avatar
Vehicle: 05 SLK55 AMG
an exemplary post!
Scott
View V8SLK's Photo Album V8SLK is offline   Boss Key
Old 05-30-2007   #6 (permalink)
Ynot's Avatar
I agree, looks 10x better than the halogens, those who say they are happy with halogens doesn't drive much at night. But most importantly, much brighter, looks good, I want to swap my halogen fogs to HID too but don't know how to do it and don't used my fog's much so don't feel the need to swap it.
View Ynot's Photo Album Ynot is offline   Boss Key
Old 05-30-2007   #7 (permalink)
Vehicle: SLK280
thanks for the vote of appreciation, guys. Like I said in another thread somewhere, its only by looking on forums like these that I learnt enough about the stuff and got confidence from the research that I would even attempt something like this, and the least I can do is document my progress so that it can further help other people who are thinking of doing the same thing. I know stevenlau's posts were invaluable to making my install go as smoothly as it did, so thanks must go to stevenlau.
Btw, -1-, what brand aftermarket 5000k halogen bulbs did you end up going with? I've heard good things about PIAA, but they're quite expensive here in Australia.
Old 06-22-2007   #8 (permalink)
Vehicle: 2006 SLK 350 Iridium Silver | 2007 CLS 63 AMG
Looks amazing! Im ordering the HID kit right now, since that is the only option I did not get when I purchased my slk350 ...
Was it hard installing the Fog Lights ? and the Driving/parking light bulbs ?
View slk350ncls63's Photo Album slk350ncls63 is offline   Boss Key
Old 06-23-2007   #9 (permalink)
Vehicle: SLK280
fog lights and the parking lights were pretty easy. Simple twist to unlock them and then pull the holder out, then take the bulb out of the holder, replace bulb, push holder back into light assembly, then twist the other way to lock them. Only complication I had was I kept touching the bulb accidentally(cos I'm clumsy :P), so I kept a little bottle of spray alcohol and cleaned the bulbs before I put them in. You definitely want to avoid touching the bulbs(both halogen and HID) if you can, but if you do, spray the alcohol and wipe it with lint-free cloth.
What location are you at?
Old 06-23-2007   #10 (permalink)
im in los angeles, california. I ordered the HID kit from mobilehid.com, but as for the fog lights , im thinking of getting these PIAA ones which are replacements for hb4 type.http://cgi.ebay.com/ebaymotors/ws/eB...2174369&rd=1,1
Old 06-24-2007   #11 (permalink)
Vehicle: SLK280
Interesting, I've heard of those PIAA leds, but never seen it in action. Let us know how you go with that. Just a quick note, I think the LED based bulb will draw a lot less power than the stock halogen ones, so you might get a "bulb out" warning if you switch them, because the computer may think because of the current draw, that the bulb has blown. Not sure what the cutoff point is though. Can be easily remedied with addition of a suitable resistor in the circuit, but you may not need to.
Someone else on the forum was playing with upgrades to LED bulbs, so his experiences might be helpful:
http://www.slkworld.com/general-modi...t-upgrade.html
Old 06-24-2007   #12 (permalink)
-1-
Don
-1-'s Avatar
I agree, I think you'll have problems with the LED lights. If so, the remedy is to use a resistor. Those LED bulbs are EXPENSIVE at $89 plus shipping with no guarantee they will work. I spent about $10 for a set of H7, 5000K halogen bubs that look great and match my factory xenons with Philips 5000K D2S HID bulbs. Let us know if the LED bulbs work. I assume you're going with the white LEDs?
Old 06-25-2007   #13 (permalink)
I actually held off since the seller has multiple of those on sale... after reading your post and the one above, i've decided not to get them... I will take the option you suggested... thanks!
Old 07-07-2008   #14 (permalink)
vincent007's Avatar
Vehicle: White '09 SLK 350
Other Toys: Honda Valkyrie, Honda Ridgeline
Send a message via AIM to vincent007
Ghostdunks, Thanks very much for the pics and instructions! Thanx to you, I was able to install the HID kits in a little under three hours! The install looks very neat and professional. "Dremeling" the hole went smooth as well as using the existing protrusions to mount the ballast. Again, thanx!!!!!
Vinny
2009 SLK 350, Arctic White, SmartTop roof module v3.22
View vincent007's Photo Album vincent007 is offline   Boss Key
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/general-modifications-r171/2936-install-hids-into-r171-slk.html
Posted By For Type Date
How can I improve lights? This thread Refback 10-19-2007 06:14 AM
How can I improve lights? This thread Refback 08-13-2007 10:35 PM
How can I improve lights? This thread Refback 06-19-2007 11:26 PM
How can I improve lights? This thread Refback 06-19-2007 08:00 AM
Install of aftermarket radio and BT kit to replace Audio20 in the R171 SLK ghostdunks General Modifications R171 32 4 Weeks Ago 09:00 PM
R171 OEM Bluetooth Phone Install dodman SLK R171 General Discussion 35 07-13-2008 02:47 AM
Installing Command Aps on SLK 200 R171 apjeovic Help and Support 1 06-11-2007 05:44 PM
More SLK History info SLKman General Discussion 2 04-15-2007 12:07 AM
