Welcome to SLKWorld
LinkBack (4) Thread Tools
Old 4 Weeks Ago   #101 (permalink)
Senior SLK World Member
Silver Supporter
Vehicle: 2009 Mars Red SLK55
Just installed and it works! However, in the process, I kind of bent one of the really thin metal pieces at the end of the smarttop black wire and the metal piece broke off. However, I managed to squeeze the metal in and hoped that there would be enough metal to metal contact for the smarttop to work and it seemingly does. However, there is a slight delay after i press the buttons 3 times. It takes a the car 2-3 seconds to respond and lower the top. I wonder if this is normal.
On the whole, however, I gotta thank SLKworld for this sticky. To all newbs like me, PLEASE READ THE THREAD it helps. I avoided a lot of trouble.
One thing I noticed, reinstalling the side panel is sometimes an issue. If your hood lever rubs against the side panel you haven't installed the side panel correctly. There's a small plastic holder than the side panel has to go under.
EDIT: I checked the little vid on the mods4cars site. It isn't really 2-3 seconds, just like a second or two before it actually starts the whole lowering process. I guess its ok. You guys think that broken wire made a difference? I mean I'm not physicist but I do know that if there's no contact the thing wouldn't work at all...
View smoothbnzf4n4tc's Photo Album smoothbnzf4n4tc is offline
Old 4 Weeks Ago   #102 (permalink)
Originally Posted by smoothbnzf4n4tc View Post
It takes a the car 2-3 seconds to respond and lower the top. I wonder if this is normal...
Roughly 2 seconds.
See if it (roof module) still works after some driving around in the next few day/weeks, especially after hitting some bumps. If SmartTop still works, then you're fine.
Old 4 Weeks Ago   #103 (permalink)
Silver Supporter
Good, it is 2 seconds then.
Good idea, I'll drive it around a bit more and see if it still works after I hit some speed bumps, though the weather up here is getting crappy and foggier now.
Old 3 Weeks Ago   #104 (permalink)
Vehicle: SLK200K
Other Toys: Kawasaki ZZR250
After 3 hours of back pain, cuts on my arm and fingers i have finally installed it. I cant believe i waited for a year before purchasing it
I couldn't figure out how to take off the accelerator pedal so i had to squeeze my fat hands on the already very small gap which took a lot more effort
Almost paid 200 AUD for an audio shop to install this for me! luckily i decided to try it by myself
View RaihaX's Photo Album RaihaX is offline
Old 2 Weeks Ago   #105 (permalink)
IIRC, there's only one bolt that holds the accelerator pedal assembly (drive-by-wire) to the floor. It should be easy to remove.
Old 2 Weeks Ago   #106 (permalink)
Vehicle: SLK200K
Yeah i realize i took off the plastic cap covering it and I just couldn't unscrew it (not being able to see the thing doesn't help either)
Oh well at least i got it working, one thing i notice i was playing around with the setting and when i turned on "Chirp" what is it suppose to sound like? It seems like it sounded the same as before...
Old 2 Weeks Ago   #107 (permalink)
I think this only applies to 2005-2007 US spec SLK's where it uses the factory installed car alarm to do the "chirping" and not using the horn. IIRC, there was a procedure to reseat a fuse (found in fuse box at the engine compartment).
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/general-modifications-r171/2564-just-popped-smarttop-v2-into-my-07-slk280.html
Posted By For Type Date
Nogen erfaring med smarttop til SLK350(R171) - Øresundsdebatten This thread Refback 10-11-2008 11:38 AM
SLK (R171) remote vario-roof operation retrofit? This thread Refback 06-04-2008 05:37 PM
SLK (R171) remote vario-roof operation retrofit? This thread Refback 05-20-2008 09:22 AM
SLK (R171) remote vario-roof operation retrofit? This thread Refback 05-20-2008 09:20 AM
Smarttop Purchase shpritz Where to get R171 SLK Items 9 06-06-2008 04:56 PM
question smarttop v 3.1 jbanks15 SLK R171 General Discussion 13 05-25-2008 04:34 PM
Popped out for some ciggies Woolly SLK Videos 17 08-01-2007 05:27 AM
SmartTop for R170 BENZO Ask DansSLK 13 04-17-2007 11:58 AM
DUH..... It's SmartTop!!! RacerCub68 General Modifications R171 10 01-24-2007 04:04 AM
