| SLK World Junior Member Join Date: Feb 2007
| Hi everyone, i am trying to change the front and the back turn signal light bulb, but i have a hard time reach the light bulb base, is that some way i can access to it, i try to take out the bolt from the front light but still cant take them out, and the rear light is all cover up. Also, doesnt anyone did take out the light from the mirror also please reply thanks |
Country: Thanks: 376
| The front turn signal lamps can be accessed by first removing the flexible air inlet tubes that leads to air box. The plastic housing that holds the turn signal lamp has a vertical tab that runs along the middle of the housing for "easy" twisting and removal. You approach this by standing at the front facing the vehicle and reach to the left side (left turn signal lamp)of the vehicle with your left hand. You approach from the side instead of straight on from the rear of the housing. Use the right hand for the right turn signal lamp. The rear turn signal lamps can be approached by opening a trap door like cover in the flexible black lining that covers the rear tail light assembly. This is more straight forward. Do this ONLY when the engine is cool or near room temperature. I changed the front turn indicator lamps on a weekend before the engine has been started.
| hi mine is a slk55 and because the head light cord are there i have hard time reaching to the front left light bulb. i try to go from the wheel fender but still cant reach it does anyone did that in their car? please reply |
| How to strengthen signal with the R170 Antenna | dsb | General Modifications R171 | 285 | 4 Days Ago 05:19 PM |
| Side Mirror Turn Signal Replacement | SLKDawg | SLK R171 General Discussion | 17 | 08-28-2008 12:38 PM |
| To change or not to change (spring)? | bangkokSLK | Ask DansSLK | 4 | 04-21-2008 10:15 AM |
| LED Bulb Rear Turn Signal Light Upgrade | zxxn | General Modifications R171 | 32 | 07-16-2007 11:02 AM |
| Change the gear change/automatic gear box SLK 280/350 | Banned | General Modifications R171 | 8 | 02-05-2007 10:37 PM |
