Windrestrictor
Old 12-27-2006   #1 (permalink)
Founding Member #8
Vehicle: 2004 SLK350
Default SmartTop Module
Anyone want a full piccy install on a RHD R171 - I got my module on Sat Morning (thanks Bill) - shall fit it in the next couple of days - if you want, ? I'll take piccies, whilst I fit it. Let me know.
1999 Ducati ST2
2003 Vauxhaul Vectra
1974 Triumph Bonneville 750
T140V
1937 Norton 500 single
(all still current)
Old 12-27-2006   #2 (permalink)
-1-
Don
-1-'s Avatar
Yup, that would be great. I know several have moved from the Piecha to the SmartTop. I like the additional features, but the bottom line is "up and down" and being a semi practical person, Ill keep the Piecha.
THE MON55TER ON THE BLOCK
Old 12-27-2006   #3 (permalink)
Step by step install piccies on a RHD R171 would be GREAT!!
Old 12-28-2006   #4 (permalink)
A tip for those installing the SmartTop or the later issue Piecha module on LHD:
1. The module is wider by 5mm on each side and is harder to nest inside the wire loom/harness box. Use the continuation of the wire harness cover in the rear instead. This cover is almost square and the tab that holds this cover is towards the side of the car (the exact opposite of the elongated wire harness cover which is towards the midline of the vehicle). The cover is easy to lift (not all the way up but about 60 degrees or more)and this is where the wire harness bends towards the midline of the car, at the rear of this bend is enough space to tuck the varioroof module in and there will be enough length of wire to reach the CANBUS connectors. Scott (V8SLK) is familiar with this set up.
2. After removing the CANBUS cover, I shaved off the little tabs (the legs of the T) that go toward the inner surface at each side of the cover (this is the part that makes it difficult to pull the cover off causing others to even break the cover in half). Use a sharp hobby knife and be careful not to cut oneself and I used a small sander on the motor tool to sand off the irregularities and smooth out the inner surface. The second time was easy in removing the CANBUS cover, when I switched to the SmartTop module. One has to lift one side of the cover with moderate force from the finger and it clicks off. Small screwdriver not needed.
Old 01-09-2007   #5 (permalink)
How did the install go(for RHD vehicles)? Were you successful?
Old 01-10-2007   #6 (permalink)
Founding Member #8
Haven't got around to it yet hopefully in the next week or so.
1999 Ducati ST2
T140V
(all still current)
Old 01-10-2007   #7 (permalink)
Silver Supporter
beverage's Avatar
Vehicle: R171 2005 SLK200 Kompressor
Other Toys: Cars & Computers
Smile
Yup pictures and a full write up will be useful, as I'm still planning on getting a module for mine, but was waiting for you to do you yours first
Just in case there were any issues ...
Fingers crossed for the weekend then!!!!
View beverage's Photo Album beverage is offline
Old 01-10-2007   #8 (permalink)
jimbobalooba's Avatar
Vehicle: 2006' SLK 200 SE
Other Toys: Bikes
It's something I have been considering for a while now, but I'd probably wait till summertime anyhow.
I'm still weighing up the pros and cons
It would be cool to operate the roof whilst moving but in Scotland I don't know if its worth it because if you're gonna be driving with the hood down, you know at the start of the journey. I've got the key-roof operation so I'm still not sure.
The pics would definitely help me decide, thanks very much!
View jimbobalooba's Photo Album jimbobalooba is offline
Old 01-10-2007   #9 (permalink)
Founding Member #8
Jim, you cant beat the pose value - sitting outside the village pub, with your car outside, click the button in your pocket and the roof goes down -not that I'd do that !! - I fitted a **** Bipes system on my R170, and I loved it.
1999 Ducati ST2
T140V
(all still current)
Old 01-10-2007   #10 (permalink)
Founding Member #8
I've just been hit by the site sensor - I can't say **** - I've got to use the diminutive form of Richard !!
1999 Ducati ST2
T140V
(all still current)
Old 01-10-2007   #11 (permalink)
Founding Member #8
OK, how does this sound - - - you order one, N4PWJ, orders one, then we have a 'mini meet' in the NW and all fit them together - if you order from this forum, they arrive within bout 4-5 days (as long as it's not xmas). - I'll bring my electronic tool kit !!
1999 Ducati ST2
T140V
(all still current)
Old 01-10-2007   #12 (permalink)
Silver Supporter
beverage's Avatar
Wink
I like your thinking, I can't order till after payday (end of the month) and then I go away in Feb ... but all very do-able. Me and electronics don't always go hand in hand
N4PWJ - what do you say??
Old 04-06-2008   #13 (permalink)
Donation Award
Did this RHD installation guide come off?
View ryan.stephens's Photo Album ryan.stephens is offline
Old 04-07-2008   #14 (permalink)
Senior SLK World Member
snowbyhui's Avatar
Vehicle: 06 SLK55
Other Toys: Lexus 400h, Wii
Talking
Finally...Smart Top installed, after 2 days of work
The biggest issue that I had was with the big plastic cover that cover the CAN bus, almost spent an hour on it and eventually broken the cover latch, well it still goes back on and secure.
The other major problem was with the 12V Red wire. The installation says NOT to use the Thick one, but using the thinner one. Which I did and nothing happen after all is connected.
Then I found from another forum Benzworld.org and they have a much more detailed instruction listed, I wish I had read that before I went with the Smart Top instruction. It turns out that there is a third solid red wire, sort of middle size amount the 3 red wires. Connect the power and Whwow, what a magic!!
Here is the link that I found on Benzworld.org -> http://www.benzworld.org/forums/r171...ally-once.html
It is a long Thread, but definitely worth while to go over it for the detail before installing the smart top.
View snowbyhui's Photo Album snowbyhui is offline
Old 04-08-2008   #15 (permalink)
Founding Member #7
mtiede's Avatar
I think if you search here you will also find at least one thread. I think I described my not so fun time doing the install. I also broke the black box (in more than one place ) and described what it takes to get the box open. I think I get too pissed when I work on something like that and problems come up. I find it easy to break things and sometimes words are said and objects fly
Old 04-08-2008   #16 (permalink)
Donation Award
I know the feeling
Old 04-08-2008   #17 (permalink)
snowbyhui's Avatar
Vehicle: 06 SLK55
Smile
i did try the search on this forum, but couldn't find it for some reasons, probably didn't use the right combination of words
anyhow, the my fingers still hurts even just doing the typing... i know exactly what you had experienced
it is getting warm here in Toronto and sun is out today, time to enjoy the top down drive now.
afterall, it is all worth the effort!
Old 04-08-2008   #18 (permalink)
Link: http://www.slkworld.com/general-modi...07-slk280.html
For removing the CANBUS cover:
Here's what I found to work easier: Insert two flat wooden coffee stirrers or flat wooden matchsticks to each side (narrow side) of the CANBUS cover so the locking tabs are lifted. Trim the length of the wooden inserts if necessary to the same height as the cover. Use masking tape to hold the wooden sticks in place. This will release the tabs that hold the CANBUS cover. Now gently pry off the CANBUS cover using a small flat head jeweler's screwdriver (extra small flat head screwdriver). Work from the middle of the cover where you will see 2 small slots,and slide the screwdriver towards one side of the cover. Once you release one side, it will be easy to release the other side.
After removing the cover, I use a motor tool (or a small sharp blade will work) to trim off the T-shaped tabs. This will make future removal much easier by just using the fingers.
Hope the above helps.
