| SLK World Member Join Date: Jul 2006 Location: Athens, Greece
Vehicle: '06 SLK 200 K, '06 C 200 Sports Coupe
| I purchased the smartTOP roof module and got it today. I will probably install it this weekend. I have the following questions prior installing the module: - How will the module be connected to 12V power? - Do I need any cuts to existing cables or adding to the current cables either from the car's or the module's. - Do I need any special tools? - Are the door sill panels removed easily? - Since I have a manual gearbox, I also have a 3rd pedal. This makes the removal of the carpet more difficult? If anyone knows any of the above, let me know. Last edited by thanosSLK; 12-04-2006 at 06:26 AM. |
| Founding Member #8 Join Date: Jun 2006 Location: Co. Durham, UK
Vehicle: 2004 SLK350
Country: Thanks: 28
| Check out this link for installation instructions:- http://www.wilhelmy-it.de/sms/db/sma.../en.php?mode=1 γειάσου και καλή τύχη !
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. 2005 BMW LT - 16 countries, 2 CONTINENTS & counting 2004 MB SLK 350 Andradite Green (6 speed manual] 1999 Ducati ST2 2003 Vauxhaul Vectra 1974 Triumph Bonneville 750 T140V 1937 Norton 500 single (all still current) |
| I have already saw the instructions in the link you sent me. The thing is that since I am unaware of the procedure I would like to know if there is something I should pay attention to... |
| | #4 (permalink) | |
Country: Thanks: 376
Page 30, post no. 295 of this link: http://www.benzworld.org/forums/r171...e-roof-30.html, if you want to draw power from the fuse box instead of crimping. No special tools except for the torx screw and small screwdrivers to release the side tabs in order to remove the CAN BUS cover. The door sill panel come off easily just pull upward and away with medium force, you will hear it click away/disengage form the clips. Start from the rear end and work towards the front. It should still be "do-able" on a left hand drive vehicle with manual transmission and a clutch pedal. I used a wooden dowel (with masking tape at the ends, to minimize scratching paintwork) to prop the carpet up and away.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. Last edited by etyu; 12-04-2006 at 01:44 PM. | |
| So, you think that it is better to draw power from the fuse box instead of crimping?? Is it better for security reasons? Do you know from where I can purchase the fuse holder and the extended cable? Do you know their specs? Also, I think that the impedance of the cable will change as I will have extend the original cable, so as to reach the fuse box. I guess that the mod will be easier to be spotted as the new fuse holder can be seen by an MB mechanic... |
| | #6 (permalink) | |
Check out page 28 (my post) on the link I provided above in an earlier post and page 30 has a picture of the ATO add-a-circuit. This can be purchased from any auto supply store. The chances that a tech will have to open a fuse box is low unless you have electrical issues. It doesn't matter how long the power supply and the ground wire is. It is the length of the wires that lead to the CAN BUS that has the impedance optimized (I believe).
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. Last edited by etyu; 12-05-2006 at 01:29 PM. | |
Country: Thanks: 96
| Better to go with the fuse box option the reason being your going to get a more reliable connection and you have fuse protection also as etyu pointed out no chance of tapping something that should not be messed with and causing yourself some major headaches or worst case major bills. There is very little that can go wrong simply adding a fuse its basically plug and play just disconnect your battery while you are installing the fuse holder just because its good practice to do so you can hook it back up again afterward and just install the fuse once your done. CAN BUS wires are more important and should never be extended unless done correctly because you can kill the car with a dodgey connection, extending them should not be done unless its really the last option as i say so long as you do it right and don't add a stupid amount of wire you wont get any problems but if it ain't broke don't fix it you know what i mean
| | #8 (permalink) | |
| Elite SLK World Member Join Date: Jul 2006 Location: South Beach (Miami Beach, FL)
I think I need to get in there and solder the wire up for support. | |
| | #9 (permalink) |
Country: Thanks: 96
| Good idea don't let it break whatever you do.
| | #11 (permalink) |
Country: Thanks: 96
| The dealer should not check fuses unless something is wrong with the car there is no check done during services that instructs them to do it so unless you have a problem with the car that they suspect leads back to a blown fuse they wont find it.
| | #12 (permalink) |
| I've went in for maintenance 3x -- first acquaintance visit, ECU cold weather recall and service A. The varioroof module was deactivated prior to service each time and no word from the technician. I even demonstrated the module to the service advisor on the first visit and he was quite amused (I do have a good relationship with the service advisor and service manager), and I live in SoCal.
| | #13 (permalink) |
| Elite SLK World Member Join Date: Aug 2006 Location: Home of the brave
Vehicle: 05 SLK55 AMG
Country: Thanks: 40
| i just disabled my module since we're going in for c service tomorrow. i'm curious if anybody knows...once re-enabled, does one need to reprogram the module? does it go back to the default settings or go back to the last programmed setting?????????????????? |
| | #14 (permalink) |
| Scott, I disabled the SmartTop module prior to going for service A. After reactivating the module, the prior settings were kept, it did not revert back to the factory default settings, e.g., the ignition off allowed in Function 2 was retained, the ignition on allowed in function 3 was retained, and the program to operate roof while vehicle is in motion was retained. I double checked by going into the programming mode and checked each function with the up button and checking how many times the right indicator light/turn signal lamp flashed within each function.
| | #15 (permalink) | |
Country: Thanks: 135
My battery is fully charged now and I'm getting a roof error, visit workshop, haven't had time to look at it yet.
| | #16 (permalink) |
Country: Thanks: 96
| Disconnect the module mate from both CAN and Power if possible then disconnect the battery for about 20 mins to erase the cars fault memory power it back up check everything works as per factory then reconnect the module like the first time you installed it. A bit of bad design by the original manufacturers of the roof module there it obviously does not make it self available on the bus quick enough and does not allow communication to pass it without it being in the loop at all times.
| | #17 (permalink) | |
| | #18 (permalink) |
Country: Thanks: 96
| No worries mate. The car does a check on all its systems once power is restored and all modules are required to be active and ready to respond within X number of seconds the roof module obviously is not powering up quick enough and thats stopping the car from speaking to the vario roof controller causing your error
