Go Back   Mercedes SLK World Forum > Mercedes Benz R170 SLK Class Cars > General Modifications R170
General Modifications R170 Details that make your car diffrent
Windrestrictor
Old 07-18-2008   #1 (permalink)
SLK World Junior Member
Default No AM reception on a 99 SLK230
Hi all!
I just bought a 99 SLK230, and while playing around and testing features, I discovered that I get ZERO AM reception and pretty poor FM reception (fair amount of FM static, etc)
The car was shipped to me, and the antenna was unscrewed by the transport company. I put it back on, finger tight...
Could the poor reception be due to the antenna not being tight enough?
If I do need to replace the antenna, I assume I may need to replace the entire assembly, cable and all, since their could be a pinch or short in the cable, etc.
Does anyone know of an online source for the entire antenna assembly, cable and all? Any ideas also on a non-OEM solution possible, since I will be replacing the stock sound system completely once I figure out this AM reception issue.
-David
View daveshea's Photo Album daveshea is offline
Old 07-19-2008   #2 (permalink)
Gabus's Avatar
Vehicle: 96 SLK 230K
Other Toys: Volvo L3314N
Guess it's the cell phone antenna you screwed back
Radio antenna is located in your back bumper. I would guess you have a problem with the signal amplifier. That is located in the left corner of your trunk. If you remove the first aid kit you can see the amp in the hole behind it.
Gabus
Old 07-19-2008   #3 (permalink)
Thanks for the tip. The car is being serviced for something else, but once I get it back, any idea on an aftermarket or online source for the antenna assembly, including the amp and cables?
Old 07-19-2008   #4 (permalink)
Founding Member #7
mtiede's Avatar
Maybe the bumper was replaced and the antenna wasn't? Or maybe the antenna connection is loose?
98 SLK230 Vibration AJExtreme SLK R170 General Discussion 4 05-30-2008 09:51 PM
SLK230 folding roof Paul Kearsley Help and Support 13 09-21-2007 01:10 PM
SLK 280 2006 Satellite radio bad reception cmilian Help and Support 4 05-29-2007 01:37 PM
SLK230 vs. SLK320 MCFaisal General Discussion 3 03-22-2007 10:41 PM
how do you do burnouts in the slk230 MCFaisal SLK R170 General Discussion 10 02-21-2007 01:24 AM
