Go Back   SLK World Forum > Mercedes Benz R170 SLK Class Cars > General Modifications R170
General Modifications R170 Details that make your car diffrent
Visit Autogeek.net
Old 06-05-2008   #1 (permalink)
Cold Shot's Avatar
Vehicle: 2007 SLK55 AMG
Other Toys: 2007 ML 350
Donation Level 6
Default A few new (minor) mods...
Spent a few hours washing the SLK today, which is always an opportunity for a few pics. I bought a new dish cleaning, spongy thing for doing the wheels. It took about two hours to clean the inside of the rims without dismounting them. I really liked the results...but man was that a lot of work. I think I have a system now that will shave about 30 minutes off the next attempt.
I have installed the following since my last pics:
-Eurolight clear side markers (with stock clear bulbs)
-AMG valve stem caps
-R170 stubby antenna (with signal boost mod)
The signal boost mod on the antenna was kindly performed by another SLK World member. He did a great job. He will go nameless unless he wishes to identify himself. I now have excellent reception of SmartKey for SmartTop operation. Not fully tested, but well over 100' in all directions. I checked FM signal and all is good. I rarely listen to anything other than Sirius (please Lord...give us XM stations after the merger).
The valve caps were not that expensive after my Mercedes Benz Club of America discount. If they get ripped off...so be it. My car is rather secure most places I take her.
As previously mentioned, I cracked a small part of the lower outer lens of the drivers side Eurolight upon install. After pouring a ton of water on the car today, no moisture formed on the inside. I think it will be OK.
Here are some new pics, and there are others in my new album.
EDIT: Posted in wrong section...Should have been in the R171 General Mods section. My bad.
2007 Black/Black SLK55 AMG (Green Filters, SmartTop V1, Eurolight Clear Side Markers, R170 Modded Antenna)
2007 Pewter/Black ML350
19xx White/Blonde Wife (Lmtd Edition Model)
Last edited by Cold Shot; 06-05-2008 at 08:43 PM. Reason: Cause I'm an idiot and can't pay attention.
View Cold Shot's Photo Album Cold Shot is offline   http://www.slkworld.com/Boss Key
The Following User Says Thank You to Cold Shot For This Useful Post:
Old 06-05-2008   #2 (permalink)
Vehicle: 2009 SLK 350
Looks fantastic. You did a great job with the mods
View Dave54's Photo Album Dave54 is offline   Boss Key
The Following User Says Thank You to Dave54 For This Useful Post:
Old 06-05-2008   #3 (permalink)
-1-
Don
-1-'s Avatar
Very nice, your SLK 55 looks great. Two hours on the wheels, sound like torture, but I admire your dedication. Remember, a job worth doing is worth doing well. I have the same three mods on my SLK.
-----------------1-----------------
---------SLK 55 ///AMG---------
TOP D0WN-URGE 2 DRIVE GOES UP
View -1-'s Photo Album -1- is offline   Boss Key
The Following User Says Thank You to -1- For This Useful Post:
Old 06-06-2008   #4 (permalink)
That black SLK looks really sharp The clear side markers and mod R170 Euro Spec antenna looks real smart on the black 55.
Here's what I do/use to clean the wheels (takes about 20-30 minutes for 4 wheels) each time before washing the car body:
Materials:
1. Old cellulose sponge (hand-me-downs from the kitchen). This way the sponge is well-worn but still useful and has less chance of scratching the wheels.
2. Modified long brush tool used to clean the coils from underneath the refrigerator (available at WalMart, Home Depot, Sears, etc for about USD $6). This tool comes originally with a tapered end that's about 1/2" wide and 4" long, the main body has bristles that are 1.5" wide and are soft enough to not cause any scratches. To modify: remove the black rubber end cap by twisting it off, cut at the junction between the 1.5-inch-wide main body and the narrow o.5-inch-wide tapered end with pair of pliers (easily done as the twisted wire is on the soft side), reinsert the black rubber end cap by twisting. It's important to reinsert the black end cap or you'll have a sharp edge that can damage paintwork. This also prevents the remaining bristles from unraveling and coming off. The modified brush is about 8.5 inches long on the bristle part, not counting the wooden handle (which is another 8 inches long) and should work ok for wheels that are 9" deep.
3. Meguair's Wheel Brightener wheel cleaner D-140 (safe for clear coats, factory painted and chrome wheels, non-acid), diluted 1:4 (as recommended by manufacturer) in a spray bottle that has graduations on its side. I bought a gallon from a car detailer supply place for USD $24. This was 20 Jan 2007. Pix below show that I still have 2/3 left today (17 months). I generally use this every 1-2 weeks before each car wash.
Method:
1. Rinse wheels with gentle spray from garden hose to remove most of the accumulated brake dust.
2. Spray the diluted wheel brightener solution from Meguairs unto the wheel including the inner surface (usually one squirt between each spoke aiming from the center and outward towards the inner horizontal surface). This stuff works great on removing brake dust.
3. Gently agitate with the wet but worn (but still usable) cellulose sponge. I start at the hub and lug nuts, and then on each spoke at the vertical surface, then on the innner horizontal surface (the sponge only cleans the outer 2 or 3 inches of the inner horizontal surface of the wheel). I also use a dripping garden hose (noozle is opened very slightly) on one hand to continuously keep the sponge wet (much like lubricant being slowly poured over something that's being worked on in industrial applications) while doing the agitation.
4. Use the modified brush to clean the rest of the inner horizontal wheel surface by inserting in-between spokes and clean with a gentle to-and-fro and sideways motion, dripping garden hose on one hand and the brush on the other.
5. Rinse the entire wheel with a gentle spray from garden hose once the whole wheel is done.
Each 16-spoke OEM wheel takes about 5-6 minutes.
I also sometimes spray Z-6 gloss enancer (other products will also work) unto a clean cloth and treat the wheels (after they've been dried with compressed air and towel).
Hope the above saves you some time in cleaning the wheels. I think it works well to keep the wheels relatively clean without having to remove the wheels to clean the inner surface. My apologies for the long post.
The Following 4 Users Say Thank You to etyu For This Useful Post:
Old 06-06-2008   #5 (permalink)
Senior SLK World Member
Vehicle: 2002 slk230K 2008 Honda CRV
Car looks great, did you look at a pair of black side marker lights before getting the clear one's???
View livefreeordie's Photo Album livefreeordie is offline   Boss Key
The Following User Says Thank You to livefreeordie For This Useful Post:
Old 06-06-2008   #6 (permalink)
-1-
Don
-1-'s Avatar
Cleaning the wheels is my least favorite part when washing my cars. I've learned several things, the bigger the wheel, and less spokes, the better. A good brush for reaching tough areas is a must. Dripping water from the rusted rotors makes a mess.
Old 06-06-2008   #7 (permalink)
alroumi's Avatar
I am Mclovin it, nice reg plates too.
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
View alroumi's Photo Album alroumi is online now   Boss Key
The Following User Says Thank You to alroumi For This Useful Post:
Old 06-06-2008   #8 (permalink)
N4PWJ's Avatar
Vehicle: 2006,slk280,carlsson
Other Toys: Caterham
i see what you did there MO, Superbad...what a movie!!! especially his genitil drawing obsession .
nice car...black is hard to beat when shined up correctly!
View N4PWJ's Photo Album N4PWJ is offline   Boss Key
The Following User Says Thank You to N4PWJ For This Useful Post:
Old 06-06-2008   #9 (permalink)
alroumi's Avatar
Glad you caught it mate,
Old 06-06-2008   #10 (permalink)
Click it or ticket!
SLKCop's Avatar
Very nice job, Cold Shot. Black is definitely the color! I like the valve stem caps also. Sharp looking.
Mike
View SLKCop's Photo Album SLKCop is offline   Boss Key
The Following User Says Thank You to SLKCop For This Useful Post:
Old 06-06-2008   #11 (permalink)
Cold Shot's Avatar
Donation Level 6
No, I pretty much knew I wanted clear\silver to compliment the headlights and mirror housings. Maybe if I had black wheels it would have been a consideration for me.
View Cold Shot's Photo Album Cold Shot is offline   Boss Key
Old 06-07-2008   #12 (permalink)
Life is good...
V8SLK's Avatar
Vehicle: 05 SLK55 AMG
the stubby antenna and clear lenses (lensi?) look great... probably the best bang for the buck in appearance mods. your car has that tough, but classy look that i really like.
Scott
View V8SLK's Photo Album V8SLK is offline   Boss Key
The Following User Says Thank You to V8SLK For This Useful Post:
Old 06-07-2008   #13 (permalink)
Mighty Joe's Avatar
Vehicle: 2006 SLK55 AMG
Black is beautiful!!!
View Mighty Joe's Photo Album Mighty Joe is offline   Boss Key
The Following User Says Thank You to Mighty Joe For This Useful Post:
Exhaust Mods kiwii Ask DansSLK 4 02-22-2008 03:48 AM
SLK350 Mods F111F Ask DansSLK 12 05-24-2007 04:48 AM
What SLK Mods do you have done? Bill T General Discussion 30 03-28-2007 03:04 AM
Oregon community no longer allows police to issue minor traffic tickets FPF422 Off Topic 0 03-04-2007 05:08 AM
Latest Mods 2.0 noregret4life General Modifications R171 13 02-12-2007 11:40 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
