Go Back   SLK World Forum > Mercedes Benz R170 SLK Class Cars > General Modifications R170
General Modifications R170 Details that make your car diffrent
Visit Autogeek.net
Old 05-28-2008   #1 (permalink)
noregret4life's Avatar
Vehicle: '05 SLK350
Cool NoRegret Customs Puddle Light – IPO
I know it’s been a while since I’ve posted a new mod or concept for everyone to dig into, so I figured with spring here it was time to break the spell.
What I have for you is an Initial Public Offering (IPO) for a custom Puddle Light Kit for your SLK and just about any other car you may have on your lot.
A good reference point will be my current kit. As you will see there are 4 LED modules. Currently each LED module contains 3 LEDs. These LEDs are the square surface mounted type. NOT the typical dome LED bulbs used for car alarms and such. Each module is a rectangle shape, with 3 LEDs in a row.
The NEW kit will be upgraded to 4 LEDs per module. However it will now be a square shaped module with 4 LEDs, one at each corner. (Please see pic attached below)
There will be 5 modules on each side. Although I feel that 4 are modules is enough for the SLK, to make the kit compatible with larger cars, I have upgraded to 5 modules. Great thing is that you can simply cut away the last module and use it anywhere else you like. Interior, dome light,… so on.
Each module is only 55mm x 55mm. The modules mount using 2 tiny screws. You can also attempt using 3M tape but I recommend using the screws since they hold 100% and leave only minimal marks if ever removed.
Between each module there will be 24” of wire. More than enough to hide, tuck way, and use on SLKs and SUVs alike. SLK only calls for around 17” of wire between 4 modules.
The kit is still in the R&D stages, however as with the Kleyman 3rd Brake Light Flasher, I am offering a few kits to anyone interested to offset production costs. These kits will be no different than the final. 98% sure.
Please note, these are not cheap LEDs used by other kits. These are Industrial LEDs same as those used in backlighting buildings, store signs, and interior design.
For the IPO the color will be white, however if in the future there is demand for other colors, Red, Yellow, Blue, Green will be available. Also a more advanced kit may also be available with RGB bulbs capable of color switching.
Puddle lights can be wired directly to your door lights, dome light, or ambient lighting as well as just a regular switch. I can assist with info on installation and best practices.
For info or interest, please drop me a PM. Reservations are limited.
Obsidian Black Metallic / Red Leather
Comfort, Lighting • Premium Package • Heating Package • Airscarf • Sport Suspension • MHI Installed • Entertainment Package • Nav
Komfort Variodach Module (Piecha) • Kleyman Puddle Lights • Euro Clear Side Markers • Pirelli PZero Nero • Custom Flipout 7" LCD • w/Rear Camera • Front Nightvision Camera • TV tuner • 250gig Media Drive (movies/pics/music) • Kleyman 3BFM V1.5 (Noregrets Custom Works) • White LED License plate bulbs • Chrome Rear Turn Signals • 50watt Xenon White Reverse Bulbs • 8000K Fog Light HIDs • Full LED conversion:doors, parking, sidemarkers, dome lights
_________________
-NoRegret Customs-
View noregret4life's Photo Album noregret4life is offline   http://www.slkworld.com/Boss Key
NoRegret Customs Puddle Light – IPO noregret4life NoRegret Customs 17 3 Weeks Ago 10:56 AM
Door Light lcerini SLK R171 General Discussion 11 05-05-2008 05:30 PM
Puddle Lights tungster General Modifications R170 19 03-26-2008 02:07 AM
En-LIGHT-en me! RacerCub68 SLK R171 General Discussion 10 07-11-2007 03:54 AM
Brabus Puddle Lights. Baron7700 Where to get R171 SLK Items 22 01-13-2007 01:08 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
