Go Back   SLK World Forum > Mercedes Benz R170 SLK Class Cars > General Modifications R170
General Modifications R170 Details that make your car diffrent
Click Here
Old 04-22-2008   #1 (permalink)
Click it or ticket!
SLKCop's Avatar
Question Wheel Sizing Help...
Hi all, since I’m not knowledgeable about wheel sizing I figured I’d set this question out to those who are more proficient than myself.
I have a 2002 SLK230Kompressor and I’m curious if the stock MB wheels/tires from a 2006 SLK350 will fit my vehicle without any modifications to my car? I know the bolt pattern is the same (5x112), but I was told I needed to check offsets and some other measurements.
Any help is greatly appreciated.
Thanks!
Mike
View SLKCop's Photo Album SLKCop is offline   http://www.slkworld.com/Boss Key
Old 04-22-2008   #2 (permalink)
alroumi's Avatar
I think it will fit without any modifications because I highly doubt your brake calipers and setup is larger than the one on the SLK R171's.
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
View alroumi's Photo Album alroumi is online now   Boss Key
Old 04-22-2008   #3 (permalink)
PAPA's Avatar
Vehicle: slk 320
The offset on r170 is 35mm, and you can run upto 8.5x18 f and 9.5x18 r with no rolling of arch, Any wider rear may need arch mods, Wider front will tramline BAD! If the offset is out you may be able to fix it with spacers
Hope that helps.
Whats the spec on the wheels you want ?
View PAPA's Photo Album PAPA is offline   Boss Key
Old 04-22-2008   #4 (permalink)
Click it or ticket!
SLKCop's Avatar
The wheels I"m looking at are stock MB wheels from a 2006 SLK350.
View SLKCop's Photo Album SLKCop is offline   Boss Key
Old 04-22-2008   #5 (permalink)
PAPA's Avatar
Vehicle: slk 320
Sorry m8 what I know about the r171 you could write on a stamp, Do you know the size m8 ?
The offset is the main thing IMO
Old 04-22-2008   #6 (permalink)
Click it or ticket!
SLKCop's Avatar
Well, I just learned that the offset for the R170 is 35-38mm for front and rear. The offset for the R171 stock wheels is 36mm for the front and 30mm for the rear, so I guess my plan of that upgrade will be in vain.
Thanks to all for trying to help out with this!
Mike
Old 04-22-2008   #7 (permalink)
PAPA's Avatar
Vehicle: slk 320
Nah dont write them off yet, some one has them on im sure, Let me think who and where and ill ask them for you, Im sure I have seen r171 wheel on a r170.
Old 04-22-2008   #8 (permalink)
I know for sure that the AMG 18-inch 16 spoke wheels (front and rear) from the R171 were fitted on a R170 without any problems (simple replacement, no spacers, etc). It was the OEM one from V8SLK (R171 SLK 55) unto Oscar's R170 (forgot his username).
For the SLK 350 the wheel specs are: 7.5Jx17 (front) and 8.5Jx17 (rear).
Old 07-10-2008   #9 (permalink)
I'm in a similar situation (and similar occupation LOL)...I have a set of new 18" Miro Colleczioni black rims (ALT MIRO DESIGN) with Mercedes caps available on ebay asking $699us for the set of 4...the front 18X8.5"/rear 18X9.5" fit with what PAPA notes as potential...and the bolt pattern 5X112 is good...the challenge I'm concerned with is the offset in the front is 32mm (rear is 35mm so all good there)...I'm also unaware if this will be an issue on my r170 (2000 slk230 sport)...could someone offer an experienced opinion if this is okay and a workable setup?
Thanks kindly, Charlie
View ironchariot's Photo Album ironchariot is offline   Boss Key
Which wheel? jnb SLK R171 General Discussion 15 01-15-2008 07:44 PM
wheel offset Genesis_SLK350 Help and Support 1 09-15-2007 03:39 AM
I've Dinked my Wheel Jiveman SLK R171 General Discussion 5 07-03-2007 05:16 PM
F1 Steering Wheel? nmslk Ask DansSLK 3 05-03-2007 06:41 PM
Wheel Bolts ! DansSlk Off Topic 10 05-03-2007 09:18 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
