Go Back   Mercedes SLK World Forum > Mercedes Benz R170 SLK Class Cars > General Modifications R170
General Modifications R170 Details that make your car diffrent
Welcome to SLKWorld
Old 11-13-2006   #1 (permalink)
PAPA's Avatar
Vehicle: slk 320
Default Fitted the brake light flasher
Hello all i have just fitted the brake light flasher unit, took 11 mins start to finnish.
A vid for you http://www.zippyvideos.com/429268679...6/flash_short/
take off the plastic panal inside your boot, three clips. cut the two wires that go to light unit, brown = earth Black = live ! Good job didnt do it myself strip the ends and fit to mod 4 small screw pots. double sided tape comes on the backof mod peel and stick
Some pics of install spot
http://img329.imageshack.us/my.php?image=fittingxy5.jpg
http://img245.imageshack.us/my.php?i...scf0002wy4.jpg
already had a guy ask me about it when i stoped today
And peeps defo stay back of your ass
This one only has one flash mode
View PAPA's Photo Album PAPA is offline
Old 11-13-2006   #2 (permalink)
-1-
Don
-1-'s Avatar
Looks good. What brand is the flasher and what was the cost?
THE MON55TER ON THE BLOCK
Old 11-13-2006   #3 (permalink)
Looks cool.
Old 11-14-2006   #4 (permalink)
bazzle's Avatar
Vehicle: slk230 1998
http://www.gominigo.com/23445.html?*...ession*id*val*
is Papas. $24
Mine on order is
http://www.comagination.com/bflasher.htm
$29 IBF4 DOT legal
Bazzle
Old 11-14-2006   #5 (permalink)
Originally Posted by bazzle View Post
With the R170, are resistors needed to prevent error messages (lamp malfunction warning) in the MFD?
Old 11-14-2006   #6 (permalink)
BipesD's Avatar
Vehicle: SLK 230
California DOT legal.
View BipesD's Photo Album BipesD is offline
Old 11-14-2006   #7 (permalink)
Vehicle: SLK32 AMG
Originally Posted by PAPA View Post
.... cut the two wires that go to light unit, brown = earth Black = live ! Good job didnt do it myself strip the ends and fit to mod 4 small screw pots. ...
That mods not for me. Cutting into a wire harness sends chills to my bones. I'd prefer plug and play like Lenny's.
Old 11-14-2006   #8 (permalink)
bazzle's Avatar
And some of us dont mind getting our hands dirty and doing things. This is one of the simplist things you can do.
Bazzle
Old 11-14-2006   #9 (permalink)
Vehicle: SLK32 AMG
Bazzle
But if you have to abandon the mod, you have one sorry wire harness.
Old 11-15-2006   #10 (permalink)
bazzle's Avatar
Hmm, I can tell you dont work on cars or equipment. Ive modified, cut up, rejoined, played with, transplanted many many parts etc etc on cars, mechanical and electronic equipment over the last 40 years.
Bring your Benz to me and Ill fix up your mess ups.
Bazzle
Old 11-15-2006   #11 (permalink)
PAPA's Avatar
Vehicle: slk 320
look at the pics could not be easier, its two wires , there is a binding the covers the wires that you roll back, so if you took the mod off, and rejoin the wire roll the binding back done no one will ever know.
"With the R170, are resistors needed to prevent error messages (lamp malfunction warning) in the MFD?"
no the warning light does not light on the dash
Old 11-15-2006   #12 (permalink)
-1-
Don
-1-'s Avatar
Hey, where is this business located? Europe, USA?
Old 11-15-2006   #13 (permalink)
Vehicle: '05 SLK350
PAPA, Great job with the install!
As i do not have access to an R170, i was wondering if you could do a little favor... Can you go into your access panel and unplug the 3rd brake light hanress from your module. Meaning disconnect everything, the module & brake light, from the car harness and see if you get a bulb out warning.
I am just curious if your module provides enough resistance to not trigger the bulb out, or if the R170 does not monitor the 3rd brake light at all.
Old 11-15-2006   #14 (permalink)
...Mine on order is
$29 IBF4 DOT legal
Bazzle
From looking at the wires, this can be made plug-and-play by Lenny by attaching the appropriate connectors. Are the exterior lamps (including the 3rd brake light) on the R170 monitored?
Old 11-15-2006   #15 (permalink)
BipesD's Avatar
Vehicle: SLK 230
The brake lamps at the corners are. The 3rd light is LEDs and too little current to be monitored.
Old 11-15-2006   #16 (permalink)
Vehicle: '05 SLK350
Well in the case of R170s you are all lucky. Because in the R171 it is monitored along with every other exterior bulb.
Thanks for the info BipesD
Old 11-16-2006   #17 (permalink)
bazzle's Avatar
There you go
Glad in this forum weve all got R170's
Bazzle
Old 11-16-2006   #18 (permalink)
DesignoSLK's Avatar
Vehicle: 2000 Designo SLK230
Donation Level 3
I think the only thing I would add would be a micro switch for by-pass when it comes time for inspection. I'm unaware if this will be an issue in Germany. So I'd just install the by-pass to be safe.
Since LENNY hasn't posted a price or more modules yet...hint, hint.
Kevin
An American in Germany...
Old 11-16-2006   #19 (permalink)
BipesD's Avatar
Vehicle: SLK 230
