Brake or neutral when idling at the stop lights? - Mercedes Benz SLK Forum
General Discussion Not SLK Model Specific
 5Likes
  • 3 Post By ken320
  • 1 Post By randombloke
  • 1 Post By CT_SLK
#1 Old 07-28-2013
Vehicle: SLK32 AMG (2002)
Other Toys: Yamaha FZ1 (gen1) and DRZ400E
Quoted: 18 Post(s)
Hi
I've never been too sure as what is best to do and have never seen a definitive answer.
Natural thing for me to do is to slip the car into N and apply handbrake rather than keep it in D with foot on brake stopping the car from creeping forward. It feels like it might be unnecessarily waring out the 'clutch' and brake light bulb although I'm sure its not.
Any thought as to what Mercedes might recommend?
Steve
steve pring is offline
#2 Old 07-28-2013
MOD MAN
Dsr207's Avatar
Vehicle: 2012 SLK 250
One of the features included in the 2012, is the brake hold(not sure what year it started) At a light, if you press the brake all the way in after stopping, the brake hold engages and you can take your foot of the brake at that time. It disaegages when you press the gas pedal. So it seems to be the best way according to MB, is to hold the brake. If it looks like it will be a long stop, I usually shift to neutral as a habit any way.
Mods ..SmartTop..SmartTV..Illuminated doorsills..Chrome hood fins..Illuminated WindRestrictor..Alpine active rear camera..FrontZone curb sensors..Midcity engineering remote start..Dronemobile..Web ready..
Dsr207 is offline
#3 Old 07-28-2013
Quoted: 18 Post(s)
I've heard that shifting to N can cause more wear that leaving it in D, that's one of the reasons I've asked.
As for the brake hold feature in the 2012, I remember my fathers Mk 10 Jaguar having that feature back in 1963 over 50 years ago.
Steve
#4 Old 07-28-2013
randombloke's Avatar
Vehicle: Gone: 2013 SLK 55 AMG
I think this is a hold-over from manual transmissions, and from automated manual boxes as there is wear taking place on the clutch throw out bearing if it is not put into neutral, but this isn't a factor in a torque converter auto.
http://www.rospa.com/roadsafety/advi...gearboxes.aspx
When stationary in traffic, even for many minutes, it is not necessary to move the gear lever into neutral because the torque converter absorbs the engineís propulsion force but does not transmit it all to the gearbox. No wear is taking place. In fact, more wear will take place if you engage neutral then engage a drive gear when it is possible to move off. Most gearboxes will automatically select first gear when the vehicle becomes stationary.
Gone: SLK 55 AMG (2013) Iridium Silver / Bengal Red / Black Ash
randombloke is offline
The Following 2 Users Say Thank You to randombloke For This Useful Post:
#5 Old 07-28-2013
MOD MAN
Dsr207's Avatar
I think it depends on manual or automatic..When driving a manual, I always shift to neutral at long stops, not saying that is good or bad, just my habit , never did any harm in my case.
Edit.. By the time I usually respond, I miss another input..didn't see the last one
Dsr207 is offline
#6 Old 07-28-2013
MBDiagMan's Avatar
Vehicle: '01 SLK320 6 speed manual
Other Toys: Modified Cessna 140, 300E 5 speed manual
Are you driving a manual or an automatic?
MBDiagMan is offline
#7 Old 07-28-2013
Don't forget your cat nap
ken320's Avatar
Vehicle: 2001 SLK 320
Other Toys: '55 MG TF-1500 (RHD)
It has always been apparent to me that the only purpose for a stop light, stop sign, or any stop for that matter, is to provide an opportunity to perfect your 0-60 (or for that matter 0 to whatever you fancy) times.
Therefore logic dictates that the car must remain in gear to expedite the departure. This requires one foot on the brake. This factor provides an advantage to the automatic transmission. A manual transmission requires one foot for the clutch and one for the brake. For nearly all drivers, this exhausts the foot supply. However with the automatic, the left foot can be used for the brake, while the right foot is free to maintain the absolute optimum RPM for maximum off the line acceleration.
It is possible to hold the car in position with the hand brake. However since even the boldest of us would agree that one hand should be reserved for the steering wheel, the hand normally used to express one's opinion of the nearby drivers' reactions to your departure techniques is tied up with releasing the hand brake.
Ken
nadnerb, steve pring and Dsr207 like this.
Avatar is Daisy. She is a SLK Guard Cat.
ken320 is offline
#8 Old 07-28-2013
MOD MAN
Dsr207's Avatar
Will, Here is your answer Steve..
Dsr207 is offline
#9 Old 07-28-2013
I've always used the hand brake and putting the gear in neutral in an auto gearbox when stopping in traffic lights. I grew accustomed to it because my foot gets tired depressing the brake especially if the stop lights would show longer seconds before it would change. I do this out of convenience while waiting for the light to change. The problem I've experienced with this is that in time the hand brake would need adjustment. When the car was bought brand new the handbrake would produce 3-4 clicks when pulled, the mercedes dealer told me that when you hear more than 4 clicks when you pull the hand brake, you need to bring it back to have it adjusted again. The hand brake loses its default adjustment through time and use.
Using the handbrake and depressing your foot in the brake does not overly bring about damage in any components, it is designed to be used in normal car operations. What you should be thinking about is the convenience. If you put your gear into neutral and using the handbrake you'll have a bit longer time to accelerate out of the stop light which would result in someone honking behind you or be a little late for your schedule, but it would be a good feeling to relax your foot for a bit. Using your foot to hold the brake would give you a faster time to get out of the stop but it will tire your foot.
Jayzen is offline
#10 Old 07-29-2013
Vehicle: SL400 (R231 2017)
Quoted: 77 Post(s)
?.........It disaegages when you press the gas pedal. So it seems to be the best way according to MB, is to hold the brake.........
Does the same if you forget to release the parking brake.
Rorywquin is offline
#11 Old 07-29-2013
Why would you go to the trouble of releasing the parking brake when it automatically disengages by design?
Dsr207 likes this.
#12 Old 07-29-2013
Vehicle: 2008 SLK350
I used to sit at stop lights with the clutch in and foot off brake on level ground until I got hit from behind after I let off the brake. The driver behind wasn't paying attention and started to move when my brake lights went off. Brake lights don't stop the driver behind from hitting you, but I try to do everything I can to protect the space behind me. A driver class I took recommended keeping the brakes well engaged so a minor collision from the rear didn't push you into the cross traffic at the intersection.
Wheeler is offline
#13 Old 07-29-2013
Speaking as someone who was hit from behind in my other car over the weekend, I can really appreciate the logic of having the brake lights on to catch the attention of other drivers.
#14 Old 07-29-2013
Vehicle: 06 SLK55 Caspian Blue
Other Toys: 07 R500 4Matic Alabaster White, 08 Infiniti G35x
Manual - shift to neutral, let the clutch out, maintain pressure on brake pedal.
Automatic (torque converter) - leave it in gear, maintain pressure on brake pedal.
A torque converter is designed to slip at idle speeds with zero damage to the system. The built in slippage is one of the main differences in "feel" that people notice vs a clutch that locks up with no slip. It's also why your automatic transmission equipped car doesn't stall at idle speeds.
Gbarringer100 likes this.
CT_SLK is offline
#15 Old 08-01-2013
Dolau's Avatar
Vehicle: SLK 200 kompressor 2003
Other Toys: Yamaha FZ6S2
So being new to automatic boxes after 20 years of stick change cars... Mine is pretty eager to be away when left in drive and it is all that the foot brake can do to hold her back - is this normal ?
Dolau is offline
#16 Old 08-01-2013
Chuck 07 350
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 61 Post(s)
Note for what it is worth. The hand brake works off brake shoes in the hub of rear wheels only. Where foot brake is pads on all four disk brakes. Therefore the foot brake has more holding power. Hand brake is more for use when the car is parked and auto trans in park or for manual trans in 1st or second gear and engine off.
Gbarringer100 is offline
#17 Old 08-01-2013
No, not normal. What is your idle speed? Torque converters are speed dependent. Are your brakes severely worn? Weak right leg? At an idle speed of 600-700 rpm, your brakes should have no trouble overcoming the small amount of torque being transmitted through your transmission with light pressure on the brake pedal. The SLK200 isn't exactly a torque monster.
My SLK55 idles at about 600 rpm and a light press of the brake pedal is all that's needed to hold the car at a stop. While we're on the subject, this SLK55 has about the lowest idle speed of any car I've ever owned. I assume it's normal as the car seems happy at that engine speed.
CT_SLK is offline
The Following User Says Thank You to CT_SLK For This Useful Post:
#18 Old 08-02-2013
nadnerb's Avatar
Vehicle: SLK 200 172 2013 Black
Quoted: 46 Post(s)
I was under the impression that a hand brake was only for hill starts and when parked
nadnerb is offline
#19 Old 08-02-2013
Vehicle: SLK 280
Other Toys: 1998 BMW540i, 1989 Toyota Hilux 4x4
My BMW V8 idles at about 550rpm in drive and 600 in neutral, so I think it's quite normal.
Peter T is offline
#20 Old 08-02-2013
Dolau's Avatar
I think mine idles on 'choke' nearer 1000 and then drops to 5/700 when in drive not sure that low down what the bottom rev reading is.
I will be sure to watch it next trip but once the beast is warm it is not so bad.
My brakes are good and just been cleaned and freed off by my mechanic
Dolau is offline
Human Verification
R170 SLK Brake Lights Not Working slkplay SLK R170 General Discussion 10 03-09-2016 12:22 PM
SLK230 Brake lights always on krhanger SLK R170 General Discussion 3 08-28-2012 09:09 AM
Using Neutral @ Stop SoopRoop AMGs 20 07-19-2011 03:09 PM
