| SLK World Junior Member Join Date: Aug 2008 Location: Lagos
Vehicle: Benz 190
| The Fuel Door Lock is malfunctioning. The vacuum bellow works fine, but the pin doesnt retract, I usually have to retract from the trunk/boot manually. How can I detach the lock from the car to have a closer look/inspection and possibly repair or replace. Tony. |
| Elite SLK World Member Join Date: May 2007 Location: Søgne
Vehicle: 96 SLK 230K
Country: Thanks: 17
| Hi Tony, and welcome Fuel door on a 190 ????
| Door lock LED flashing? | jfb1977 | General Discussion | 4 | 10-07-2008 06:46 AM |
| Door lock switch on dash does not work | bumanng | Ask DansSLK | 13 | 08-10-2008 10:21 PM |
| Door Lock Resolved, Now Horn Honks!!! | b.a.g. | Ask DansSLK | 1 | 05-14-2008 03:05 PM |
| Door lock issue... | b.a.g. | Ask DansSLK | 5 | 05-14-2008 06:58 AM |
| Vacum Door Lock System | GmniDrm | SLK R170 General Discussion | 0 | 03-02-2007 12:34 PM |
