Reset Transmission Adaptive Learning - Mercedes Benz SLK Forum
General Discussion Not SLK Model Specific
 152Likes
#1 Old 07-20-2013
Quoted: 4092 Post(s)
This procedure is all over our forum (and other forums).
It does work as I use it occasionally (like yesterday).
Posting and making a sticky for new members.
What it does? in a nutshell, it resets the ECU/TCU's learned detection of throttle inputs, effectively re-establishing the 0% and 100% pedal travel positions. , ie. quick rabbit starts as opposed to slow takeoffs. it gets used to how you drive.
R171:
If you want instant throttle response, you can have it for free.
With the engine off, turn the key to position 2 (don't start it.)
Press the throttle pedal all the way to the floor past the kick down click.
Hold it down for about 30 seconds.
Take your foot off the pedal and take the key out.
Wait 5 seconds, and start the car.
I bet you notice the change in response immediately.
For r170:
From Livefreeordie:Works for the R170's also. The only difference is keep pedal to the floor then remove the key.
R172: should work based on users, follow R171 steps.
etyu, matton, DesignoSLK and 40 others like this.
Wavetrac LSD thread here:
#2 Old 07-20-2013
randombloke's Avatar
Vehicle: Gone: 2013 SLK 55 AMG
does this work across all models?
Gone: SLK 55 AMG (2013) Iridium Silver / Bengal Red / Black Ash
randombloke is offline
#3 Old 07-20-2013
The threads mention the 55 and his 99 c280. others will chime in if they had it work. It worked on my previous 05 slk 350
#4 Old 07-20-2013
Other Toys: 1986 560SL, 2012 VW Tiguan, 2008 GMC Sierra slt
Quoted: 73 Post(s)
jbanks15, tricolour, Tolak and 2 others like this.
#5 Old 08-02-2013
Vehicle: 2008 SLK200
Other Toys: 2009 Harley Road King Classic, 1984 Harley Shovelhead
Thanks for the info will try it when I get home
Thegadge
thegadge is offline
#6 Old 08-05-2013
Vehicle: 2006 slk 350
Other Toys: more cars
I had a 2004 Dodge Ram pick-up truck that this also worked with. Seeing as how Daimler owned Chrysler for a bit and the Ram had a Mercedes transmission the option to reset the adaptive tranny would be similar if not the same. I will try it this morning when I go in to the office and let you know if I notice a difference
slew rate is offline
#7 Old 08-07-2013
Adaptive Tranny reset
Hello,
I performed the tranny reset, as described n this forum, 2 days ago. I noticed some improvement with firmer up shifting and quicker firmer downshifting. The most noticeable change is when I manually select the first gear and let the car shift itself up through the range.
I would like to know if others are willing to try this and post their results here.
Slew Rate
#8 Old 08-07-2013
Spudmuffin's Avatar
Vehicle: Looking for R171 SLK55! Previous: SLK200K (06), CLK55 AMG (03), SLK55 AMG (05), BMW E46, Fiesta ST
Quoted: 24 Post(s)
I've tried it 3 times, did not do very much (!!) at all.
Spudmuffin is offline
#9 Old 08-07-2013
Quoted: 323 Post(s)
Tried once, minimal change in behaviour.
#10 Old 08-07-2013
bac
DAS/STAR Registered Owner
bac's Avatar
Vehicle: 2004 SLK350
Other Toys: RS Megane 225
Quoted: 38 Post(s)
Made a big difference with my car but then I had an ECU remap done at the same time...
bac is offline
#11 Old 08-08-2013
royalpar1's Avatar
Vehicle: 2013 SLK 350
Other Toys: 2012 Maserati GTC Sport
I wonder if we take it to the dealer for a service and tell them to check the ECU and perhaps flash it, if we wouldnt be able to squeak a little more from the car? Would the dealer be able to do it or would they only be able to use factory flash?
Designo Moca Black, Black Premium Leather with Black Laquer Trim. P01 Package, AMG 18" Wheels, Keyless Go, rear deck spoiler, Panorama Roof, AMG Package Dynamic Handling, Sport Package, Lighting Package (Adaptive Highbeam Assist, Bi-Xenon Headlamps, Multimedia Package, Designo Light Leather, ,AIRGUIDE Windstop and PARKTRONIC w-Parking Guidance
royalpar1 is offline
#12 Old 09-03-2013
SLK World
Vehicle: Black SLK200K Sport Auto Tip 2009
Anyone done this on a 200k R171?
Can it be done anyone?
(car under bodyshop can't try...)
A.
animajazz is offline
#13 Old 09-03-2013
bac
bac's Avatar
Quoted: 38 Post(s)
This seems to work (with a few minor variations in procedure) across a fair range of MB products so I don't see why not...
Cheers,
Brian
bac is offline
#14 Old 09-03-2013
Agreed! You have nothing to lose and everything to gain.
#15 Old 01-17-2014
Vehicle: 2012 250 petrol black/red
Other Toys: Libelle Junior glider. Jaguar 'E' Type coupe. Claude Butler racing cycle (circa 1959)
Quoted: 213 Post(s)
Why does the 'adaptive learning' need to be re-set? What would have upset it? As most critics have observed the Merc. auto box IS slow & very last century ( my '13 auto sequential Audi was MUCH better)
LeftyS7 likes this.
oldmercman is offline
#16 Old 01-17-2014
as far as i have observed, things like stop and go traffic jams. someone else driving your car and it learning that person's behavior.
others will chime in. I reset it about every 6 months just because
#17 Old 01-17-2014
AND MABEL
DAVIETHESCAFF's Avatar
Vehicle: 2008 AMG 55
Quoted: 425 Post(s)
I assume different driving styles, winter to summer, will probably have an effect. I'll try this out with Mabel when I get home.
.........Happiness is not getting what you want, it's wanting what you have.........Daviethescaff
DAVIETHESCAFF is offline
#18 Old 01-17-2014
Deafy's Avatar
I'm confused (nothing new there). I thought consensus was reached that the soft reset only worked on 5g transmissions and only a long battery disconnect worked on 7g?
There's so much mystery regarding the workings of adaptive trannys. Why the hell can't Mercedes make all the parameters clear??
Trev5 likes this.
Deafy is offline
The Following User Says Thank You to Deafy For This Useful Post:
#19 Old 01-17-2014
Has anyone asked on AMG PL to see if they will give up the information?
King of Battle likes this.
#20 Old 02-05-2014
Vehicle: SLK 55 AMG STEEL GREY
Yes I believe it is.
Alejocar is offline
Human Verification
2005 SLK350 transmission downshift issue Iridium SLK R171 General Discussion 5 09-05-2015 09:54 AM
Memory for 7 speed Adaptive transmission GearHead SLK R171 General Discussion 25 03-30-2015 10:18 PM
7G transmission service completed efair SLK R171 General Discussion 0 06-04-2012 02:46 PM
Sprint Booster on SLK55 55AMGFAN AMGs 28 09-09-2011 02:55 AM
7G Auto Adaptive Transmission... Reset... HwoALanG SLK R171 General Discussion 2 03-14-2008 02:56 PM
