Old 07-31-2008   #1 (permalink)
SLK World Junior Member
Default Hydraulic Fluid for Roof Pump
Does anyone know if there's another brand/type of hdraulic fluid that can be used in the roof top system. I need to get both my roof top cylinders replaced as they are both leaking, badly. I can get about 2 complete cycles, top down/then up, before i need to refill the hyd pump resevoir. 1 quart of MB hyd fluid is $30. If there's an alternate and acceptable brand I'd sure like to know about it.
View cw4bryant's Photo Album cw4bryant is offline
Old 07-31-2008   #2 (permalink)
I've never seen the specs on any of the systems sorry but i suspect its MB or the highway.
Whats the delay in getting the cylinders replaced? why don't you just drain the system down and not use the roof until its fixed, that fluids not good for the bodywork.
Brake fluid part of Service E? linuxpro General Discussion 4 06-03-2008 07:12 AM
brake fluid flush every 2 years? nappy SLK R171 General Discussion 6 08-15-2007 07:21 AM
Fuel Pump suntan Ask DansSLK 7 08-08-2007 11:00 PM
Hydraulic roof leak being fixed nmslk SLK R171 General Discussion 13 05-30-2007 08:30 AM
IC Pump–Dead, Alive, or Struggling to Survive?? SLK32GIRL Ask DansSLK 10 03-01-2007 06:21 AM
SLKWorld 2006-2009
