Old 09-10-2006   #1 (permalink)
gmabli's Avatar
Other Toys: 1986 HD Heritage Softail - A classic in mint condition!
Default Do Brake Rotors Have a Short Life??
Took my wife's C320 in for brake pads. She saw the message in the display and went right over to the MB dealer. The car has about 25K miles.
After inspection, they were 'happy' to report that it only needed pads and not replacement rotors. I said that there was no warning (grinding, reduction of braking ability) to signal that the pads were overdone. The reply was that the pads needed replacement, but hadn't damaged the rotors. They told me that MB rotors need to be changed often and that by the next change of brake pads, maybe 40-50K miles, we would need new rotors on the car.
So, fellow SLK owners out there with higher mileage than the 6K miles on my machine, do you regularly change rotors? Those that have other MB models, do you have to change your rotors approx. every other change of brake pads?
Seems excessive to me as I've had American cars with close to 100K miles that never needed rotor replacement.
Thanks!
View gmabli's Photo Album gmabli is online now
Old 09-10-2006   #2 (permalink)
Founding Member #7
mtiede's Avatar
I had my SLK 320 for 3 years and about 48000 miles. No rotors needed. Though maybe the next person needs them
I suspect it is more a function of how much hard braking you do and that might happen more frequently with SLK55's.
Old 09-10-2006   #3 (permalink)
Vehicle: Obsidian black SLK
As far as brake components are concerned, their life is mainly dependent on the driver's use of the brakes..
Some people go through the same set of pads and rotors in half the mileage compared with others.Style of driving, routes driven etc, are factors.
Better brakes usually have a higher wearing rate on their sub-components
View ierax's Photo Album ierax is offline
Old 09-10-2006   #4 (permalink)
The current 2000 BMW 323i and recently sold 1998 E320 both had rotors changed at around 40-50K miles, on their second set of brake pad change.
Old 09-14-2006   #5 (permalink)
Ynot's Avatar
The SLK350 rotors are originally manufacturered by Brembo (correct me if I'm wrong), with regular driving, from my experience they last around 50/60K miles so it sounds about right.
Old 10-21-2007   #6 (permalink)
Vehicle: purrrr fect.
hey guys, i've been a bit busy and haven't been stuck into the forum in a little while. However, I'd like to enquire about disc rotors as my 350 has done now around 25,000 km thats around um 15-16,000 miles? I see a lip forming on the front rotors on both sides. Its not deep and the rotors are still thick. I was wondering if I can just change the pads and change the rotors on the next service. If I change the rotors, is there anywhere on the net where i can order these rotors to save against my local mb parts work shops here in Sydney Australia?
Q
View quaidorsay's Photo Album quaidorsay is offline
Old 10-24-2007   #7 (permalink)
Ynot's Avatar
Originally Posted by quaidorsay View Post
hey guys, i've been a bit busy and haven't been stuck into the forum in a little while. However, I'd like to enquire about disc rotors as my 350 has done now around 25,000 km thats around um 15-16,000 miles? I see a lip forming on the front rotors on both sides. Its not deep and the rotors are still thick. I was wondering if I can just change the pads and change the rotors on the next service. If I change the rotors, is there anywhere on the net where i can order these rotors to save against my local Mercedes Benz parts work shops here in Sydney Australia?
Q
Search for "brakes" under post started by me, there are two web links there, can't remember the url.
Old 10-24-2007   #8 (permalink)
Vehicle: SLK55 2006
Mercedes makes their rotors softer so they can stop better and still remain relatively quiet. Their rotors are also quite a bargain compared to many other luxury cars...on almost all of our MBs, we have had to change the rotors every 2 or 3 sets of brake pads.
Old 10-29-2007   #9 (permalink)
Thanks Cyber. Hey Ynot! whats up!?! Hope things are good.
I tried to search for your posts and got a post started by you about AMG Brakes but nothing really about slk350 brakes.
If you could send me the link if you find it, cheers bud!
Q
Old 10-29-2007   #10 (permalink)
Ynot's Avatar
Q
Everything is going well, thanks,
I re-read my post and I guess I don't have part#'s of the 350 brake system, thought I did. what's wrong with getting the 55 brakes. Did is going to be an ask Dan question.
yellow brake rotors shahedC Caring for your SLK 9 07-30-2008 01:22 PM
Replacing rotors gknight8 SLK R171 General Discussion 1 06-02-2008 06:19 PM
Dumb question - how to check brake pad life Hakaze Ask DansSLK 14 09-21-2007 10:48 AM
PDF Of Best Life Magazine Article Re My SLK B55 AMGs 11 02-17-2007 09:09 PM
Best Life Magazine Article Re My SLK B55 SLK R171 General Discussion 0 02-17-2007 06:53 PM
SLKWorld 2006-2009
