Old 06-09-2008   #1 (permalink)
Senior SLK World Member
Vehicle: 2005 SLK-350, Black on two-tone biege/black
Default removing the sirius antenna
My SLK has the Sirius antenna on the trunk, and I'm wondering if it's possible to remove that without damaging the trunk lid, etc. Anyone know? I'll be going with an aftermarket nav system and have heard the MB sirius setup is incompatible with aftermarket systems. I'm hoping to remove the antenna without needing to replace my trunk lid or do major body work on it.
View linuxpro's Photo Album linuxpro is offline
Old 06-09-2008   #2 (permalink)
Vehicle: SLK55 2006
There is a huge hole where the sirius antenna pod sits, plus depending on the age of your car, you might have some fading and ring caused by the rubber gasket.
Old 06-09-2008   #3 (permalink)
-1-
Don
-1-'s Avatar
You have the old style, larger, Sirius satellite antenna. Not sure how large the hole in the trunk lid is. You might consider replacing with the newer, small style antenna just to cover the hole if that works.
THE MON55TER ON THE BLOCK
Sirius Antenna Adapter Kit shpritz Ask DansSLK 1 05-22-2008 11:13 PM
Removing CD Changer in Trunk. FreddieR170 General Discussion 2 05-20-2008 01:20 PM
Sirius Antenna Trunk Wart Tummy SLK R171 General Discussion 21 03-25-2008 09:53 AM
Removing Teeth DansSlk Off Topic 19 03-21-2008 11:58 AM
Sirius Antenna Cable Routing bildio SLK R171 General Discussion 3 11-04-2007 05:14 PM
SLKWorld 2006-2009
