Go Back   SLK World Forum > General Discussion about Mercedes Benz SLK's > General Discussion
www.windrestrictor.com
Old 01-25-2008   #1 (permalink)
nevets's Avatar
Other Toys: 07 Infiniti M35x, 08 Infinity QX56, 2002 Honda Shadow ACE 750, Maxum SR 1800,
Default Fog Light Lens
Anyone have any idea why something like this would happen...and any experience in correcting? I haven't taken it apart but it looks like the lens is burned, is that possible with glass? or is the lens some plastic composite?
Steven
06 SLK 350, Iridium Silver, Blk Int, Chrome Trims, AMG Body,
Aerowings,Wide Base Tire Flares (Thx CDRN) Green Filters,
Filled Sidemarkers, Painted Ant, Komfort Module (Thks NR4L)
Rear Spoiler - Piecha, Brabus springs, R170Moded Ant,
19" TSW Bremma, Mich PS2
View nevets's Photo Album nevets is offline   http://www.slkworld.com/Boss Key
Old 01-25-2008   #2 (permalink)
easty's Avatar
Vehicle: ///AMG
Donation Award
Thats certainly a default mate and you should prompt to have it replaced free. what queries me is why the AMG lamp on the 350? Did you get it swapped out? The non-amg spots have a replaceable cover you can take apart and swap. the AMG is a sealed unit and the whole thing will cost roughly $180
View easty's Photo Album easty is offline   Boss Key
Old 01-25-2008   #3 (permalink)
Super Moderator
Is that the new kit mate and was it like that when it arrived?
If it was mate push the seller to replace it for you, unfortunately Merc won't warranty it unless the AMG kit is on your datacard.
Like Brian says its all sealed up so to replace is more costly than on the non-AMG unit.
Old 01-25-2008   #4 (permalink)
nevets's Avatar
I should have known better...your observations are spot on, actually the lights are from a used AMG kit that I just bought from someone on the west coast...just delivered. It came off his 350 that was upgraded later (like I intend on doing).
...I was surprised to see it like this upon arrival although I knew I was buying used body parts this wasn't expected. I have already settled with the previous owner over the damage...I was just wondering if anyone had any experience with correcting outside of purchasing a new one...which sounds like what I am going to have to do..everything else..bumper cover(s), side skirts, et al was in good shape..and considering the final adjusted price at less than $1k for the complete kit, completely worth it regardless of this damage.
Steven
View nevets's Photo Album nevets is offline   Boss Key
Old 01-25-2008   #5 (permalink)
-1-
Don
-1-'s Avatar
Steven, good luck with the AMG kit. The lens on the fog light looks more like something spilled inside and dried. I don't believe it burnt as it appears since the lens is glass. Disassemble the light and see if the lens will clean up. Great price on the full AMG kit.
-----------------1-----------------
---------SLK 55 ///AMG---------
TOP D0WN-URGE 2 DRIVE GOES UP
View -1-'s Photo Album -1- is offline   Boss Key
Old 01-25-2008   #6 (permalink)
nevets's Avatar
Originally Posted by -1- View Post
Steven, good luck with the AMG kit. The lens on the flog light looks more like something spilled inside and dried. I don't believe it burnt as it appears since the lens is glass. Disassemble the light and see if the lens will clean up. Great price on the full AMG kit.
Thanks Don...I am definitely going to try and salvage if I can...Seems like they are sealed units from what Dan and Easty said...either way I am itching to get these parts on....just have to be a little patient right now...
Steven
Old 01-25-2008   #7 (permalink)
Vehicle: SLK55 2006
Although sealed, you can take out the bulb, pour rubbing alcohol in, and use a long Q-tip to clean it through the bulb socket.
BTW, it's probably from using a bulb that is higher than stock wattage.
View cyberdrakon's Photo Album cyberdrakon is online now   Boss Key
Old 01-26-2008   #8 (permalink)
easty's Avatar
Vehicle: ///AMG
Donation Award
That's good info mate, I was wondering the same, but never looked at the unit that closely to see if it was possible.
Old 01-26-2008   #9 (permalink)
nevets's Avatar
Good advice...I will try and report back... all parts are at the body shop for a few weeks..
Steven
xenon fog lights !! no-way Performance MODS for the R171 9 07-30-2008 03:40 AM
clear front marker lenses V8SLK General Modifications R171 16 06-26-2008 07:40 PM
Fog light cracked. Animali Ask DansSLK 11 07-15-2007 08:43 PM
R171 Fog Light Holder Part# noregret4life Ask DansSLK 18 03-30-2007 03:09 PM
Water spots inside headlight lens Dinoman SLK R171 General Discussion 21 08-01-2006 01:18 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
