Old 01-03-2008   #1 (permalink)
Vehicle: '05 SLK55
Default AMG* submenu w/ Racetimer
Is this available on all AMG SLK's? I don't have it.
Is it only on certain model years or Euro only? Can I have my dealer activate in with STAR?
http://www4.mercedes-benz.com/e/cars...07.html#N16122
AMG* menu
These functions are only available on AMG vehicles.
Menu overview: see more.
Use the buttons on the multi-function steering wheel.
Press or to select the AMG menu.
Gear indicatorUpshift instructionEngine oil temperature
In the manual gearshift program, the menu is displayed in red when the engine reaches the overrevving range. You will also see the shift up instruction . The shift up instruction is the only thing shown in the multi-function display until you shift gear.
The engine oil temperature indicator flashes if the engine oil temperature has not yet reached 80 †. Avoid driving at full engine output during this time.
Displaying the on-board voltage
Gear indicatorOn-board voltage
Press , or to select a different display.
RACETIMER
With the RACETIMER you can record times in hours, minutes and seconds.
While you have the RACETIMER displayed, you will not be able to adjust the volume using the and buttons.
Press repeatedly until the RACETIMER appears.
Gear indicatorRACETIMERLap
You can start the RACETIMER when the engine is running or if the key is in position 2 in the ignition lock.
To start: press to start the RACETIMER.
It is possible to store a maximum of nine laps.
Gear indicatorRACETIMERFastest lap time (best lap)Lap
Overall evaluation
RACETIMER overall evaluationTotal time drivenTop speedDistance coveredAverage speed
Lap evaluation
This function is only available if you have stored at least two laps and have stopped the RACETIMER.
View nmslk's Photo Album nmslk is offline
Old 01-03-2008   #2 (permalink)
Good news - You can get it.
Bad news - You need a new combi.
Old 01-03-2008   #3 (permalink)
alroumi's Avatar
Its available on only 2007 SLK55's and above.
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
Old 01-03-2008   #4 (permalink)
Vehicle: '05 SLK55
What is a combi? I know it as a stationwagon.
Can it be retrofit with the SDS?
Old 01-03-2008   #5 (permalink)
alroumi's Avatar
Combi is instrument cluster's and gauges if I am not mistaken nmslk.
Old 01-03-2008   #6 (permalink)
alroumi's right mate the combi is the instrument cluster (combi simply because of the combination of lights, dials and displays).
DAS won't be enough I'm afraid because the older clusters don't support the newer software versions.
Old 01-03-2008   #7 (permalink)
Vehicle: '05 SLK55
Got it thanks. I'm just trying to find all the hidden goodies that can be made available.
-nmslk
Old 07-09-2008   #8 (permalink)
Vehicle: '05 SLK55
I have a new cluster which has the AMG screen and lap timer available. Reading the instructions I need to do 2 laps to get the recap but what do I need to push to show the recap?
Thanks,
nmslk
AMG accessories for non AMG SLK Otsego Ask DansSLK 4 09-27-2007 06:07 AM
SLKWorld 2006-2009
