Is this available on all AMG SLK's? I don't have it.
Is it only on certain model years or Euro only? Can I have my dealer activate in with STAR?
http://www4.mercedes-benz.com/e/cars/slk/betriebsanleitung/vertiefen/N15A07.html#N16122
AMG* menu
These functions are only available on AMG vehicles.
Menu overview: see more.
Use the buttons on the multi-function steering wheel.
Press
or
to select the AMG menu.
Gear indicator
Upshift instruction
Engine oil temperature
In the manual gearshift program, the menu is displayed in red when the engine reaches the overrevving range. You will also see the shift up instruction
. The shift up instruction is the only thing shown in the multi-function display until you shift gear.
The engine oil temperature indicator flashes if the engine oil temperature has not yet reached 80 †. Avoid driving at full engine output during this time.
Displaying the on-board voltage
Gear indicator
On-board voltage
Press
or
to select a different display.
RACETIMER
With the RACETIMER you can record times in hours, minutes and seconds.
While you have the RACETIMER displayed, you will not be able to adjust the volume using the
and
buttons.
Press
or
Press
repeatedly until the RACETIMER appears.
Gear indicator
RACETIMER
Lap
You can start the RACETIMER when the engine is running or if the key is in position 2 in the ignition lock.
To start: press
to start the RACETIMER.
It is possible to store a maximum of nine laps.
Gear indicator
RACETIMER
Fastest lap time (best lap)
Lap
Overall evaluation
RACETIMER overall evaluation
Total time driven
Top speed
Distance covered
Average speed
Lap evaluation
This function is only available if you have stored at least two laps and have stopped the RACETIMER.
Press
or
AMG* menu
RACETIMER
Overall evaluation
Lap evaluation
