| General Discussion R170 / R171 |
| Elite SLK World Member Join Date: Nov 2006 Location: Minneapolis, MN
Vehicle: '05 SLK55
Country: Thanks: 1
| Can the Speedtronic function be used to limit a valet drivers speed when driving my car? I'm wondering if I can set the max speed to 35mph (or anything) when I have a valet park my car by using the speedtronic function? Any tips? http://www4.mercedes-benz.com/e/cars...en/N18383.html Speedtronic Speedtronic brakes automatically so that you do not exceed the set speed. variable for speed limits, e.g. in built-up areas more
You can operate cruise control and variable Speedtronic with the cruise control lever.
LIM indicator lampSelecting variable Speedtronic Check whether LIM indicator lamp is on. If it is on, variable Speedtronic is already selected. If it is not, press the cruise control lever in the direction of arrow .LIM indicator lamp in the cruise control lever lights up. Variable Speedtronic is selected.You can only exceed the limit speed stored if you deactivate variable Speedtronic:
Storing the current speed You can use the cruise control lever to restrict the speed to any speed above 30 km/h while the engine is running. Press the cruise control lever briefly up or down .The current speed is stored. You will see the stored speed in the multi-function display. Selecting a stored speed Briefly pull the cruise control lever towards you .Making adjustments in 10 km/h increments Briefly press the cruise control lever up for a higher speed or down for a lower speed.or Keep the cruise control lever pressed until the desired speed is set. Press the cruise control lever up for a higher speed or down for a lower speed.Making fine adjustments in 1 km/h increments For a higher speed: pull the cruise control lever briefly towards you .or Keep the cruise control lever pulled towards you until the desired speed is set.Deactivating variable Speedtronic There are several ways to deactivate variable Speedtronic: Briefly press the cruise control lever forwards .or Briefly press the cruise control lever in the direction of arrow .LIM indicator lamp in the cruise control lever goes out. Variable Speedtronic is deactivated.Cruise control is selected. Variable Speedtronic is automatically deactivated if you depress the accelerator pedal beyond the pressure point (kickdown) and your current speed does not differ by more than 20 km/h from the stored speed. You will hear a warning tone if this is the case. Permanent Speedtronic You can use the on-board computer to limit the speed permanently to a value between 160 km/h (e.g. for driving with winter tyres) and the maximum speed. Shortly before the stored speed is reached, it is displayed in the multi-function display. You cannot exceed the stored limit speed, even if you depress the accelerator pedal beyond the pressure point (kickdown). Setting permanent Speedtronic Press or to select the Settings menu more. Press to call up the selection of submenus. Press or to select the Vehicle submenu. Press to select Speed limit (winter tyres) . Press the or button to select the desired setting.The following settings can be selected:
To select a different display, press , or . |
| Sponsored Links | |
Country: Thanks: 298
| Thank you for the detailed information, I highly appreciate your contribution.
Country: Thanks: 96
| Speedtronic permanent limits don't apply to all the AMG's unfortunately and the variable limits are reset with the ignition but you could use it to limit the speed so long as the engine is not stopped and the dude does not know how to deactivate it.
| | #4 (permalink) | |
Vehicle: '05 SLK55
Country: Thanks: 1
Is there something I can do to check to see if I am able to set permanent limits on my AMG? I haven't seen the winter tire screen on my model. Thanks, Michael | |
| Sponsored Links | |
Country: Thanks: 96
| Basically mate just follow the instructions for setting permanent speedtronic in the pic you posted. If you can't see the menu then the function is not available.
Vehicle: '05 SLK55
Country: Thanks: 1
| I'll check next time I take her for a drive. I'm glad I found the info. I never knew there was a Speedtronic that was different from cruise control. I just saw the LIM light and didn't know what it was. If anyone else in the US wants to try and post results that would be great as well since my car is sleeping in the corner of my garage until the snow melts. -nmslk |
| | #7 (permalink) | |
Vehicle: 2006 SLK 280 w. 6M
Country: Thanks: 18
I thought all cars in the US, even those with auto tranny, don't have the limiter (I assume because of liability concerns), but I may be wrong. Either way, because of the override, I don't believe this feature would be suitable for preventing the valet parking guy from messing with your car. It's really meant to help you reduce your contingent of speeding tickets. | |
| | #8 (permalink) |
Country: Thanks: 96
| Thats partially true, the detent is an over-ride but its also kickdown so in an auto tranny its functional. Also the permanent speedtronic cannot be bypassed only the variable system can be.
| | #9 (permalink) | ||
Country: Thanks: 18
| | #10 (permalink) |
Country: Thanks: 96
| You said its the override for the speed limiter, i said thats partly true permanent speedtronic cannot be overridden. That is not the same as the max speed limiter. Read the blurb posted by nmslk.
| Sponsored Links | |
| Speed limit beeper | altugk | General Discussion | 5 | 07-14-2008 03:52 PM |
| Drivers republic | alroumi | Off Topic | 4 | 04-29-2008 03:00 AM |
| Valet Lock | AMGRoadster | SLK R171 General Discussion | 5 | 09-09-2007 11:49 PM |
| Why you should NEVER VALET the SLK | in2dwww | SLK Videos | 0 | 03-06-2007 12:45 PM |
| Shaking Drivers side Mirror | noregret4life | Ask DansSLK | 5 | 09-15-2006 03:58 PM |
