Spring is here~Gummi Pflege! Lube your seals/Lithium grease your joints /hinges - Mercedes Benz SLK Forum
General Discussion Not SLK Model Specific
 162Likes
#1 Old 03-13-2011
Wizard of ID
tcrankwa's Avatar
Quoted: 20 Post(s)
It's that time of year to pay special attention to your weather seals.
I've not found anything that even comes close to Gummi Pflege for protecting them
Buy here:
http://www.1z-usa.com/products/gummi-pflege-stick.html
or Amazon:
https://www.amazon.com/nextzett-9148...shopzilla0d-20
Jbanks15 also adding these links here for roof and joints/moving parts:
Benzworld.org - Mercedes-Benz Discussion Forum - View Single Post - Lubing vario roof - pics (1)Krytox (2)grease
and this from Muzu in German:
http://www.wusblum.de/fotos/slk/pfle...hmierblatt.pdf
and pics from the above pdf minus the instructions in German attached below as pdf
Use the lithium grease on joints and the gummi on seals
T1-T3 seals - gummi
T4- door latch - grease or lithium grease
M1 n M3 - grease or lithium grease
M2 = gummi
K2 gummi
K1,K3,K4 - latches and hinges - grease or lithium grease
K5,K6,K7 gummi - little bumpers
D2, roof latches - grease or lithium grease
Other Ds - if hinge, grease or lithium grease
if seal, gummi
Top pics R170, bottom pdf R171 but both models have similar if not exact lube points
DO NOT USE WD-40!!! IT IS A SOLVENT. NOT A LUBRICANT
CAUTION: Whether opening or closing the roof to lubricate, ensure when done, that you let the roof continue in whatever direction it was moving when you started to finish its cycle.
Holding roof open
DIY : R171 : Holding Roof Open : "Broomstick" modification
einszett Closes, Next Chapter Begins: nextzett
http://www.1z-usa.com/einszett-close...gins-nextzett/
etyu, ezsquid, Quarter and 22 others like this.
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
#2 Old 03-13-2011
Swagman's Avatar
Vehicle: 12' SLK55 AMG
Other Toys: 15' HYUNDAI SANTA FE
Quoted: 30 Post(s)
I have a pot ready waiting to go, when I have a nice weekend (and my car comes back from the dealer)
Do you do the seals in the order of the photos?, how long do you leave it to dry etc?
Also do you do it all with the roof down, or do you use the 'broomstick' method to hold the roof in mid transition to get any other seals? (that's if that system works on a 170?
Swagman is offline
#3 Old 03-13-2011
aka John
Chats: 1143
Quoted: 23 Post(s)
On the R171, the broomstick method works a treat. I've still got a load of Krytox I picked up, but the Gummi works very well, and god knows is a heck of a lot cheaper.
With the Krytox, I let it sit 45 minutes before wiping off all excess. With the Gummi, I don't think I waited that long, but it was a damned nice sunny day. Strongly recommend you pick a top-up day to lubricate!
klacuesta likes this.
Life is good - enjoy it with the top down!
UK-C200 is offline
#4 Old 03-13-2011
Wizard of ID
tcrankwa's Avatar
Quoted: 20 Post(s)
Well said! I do all the seals with the top down. Then put it part way up and do the rest. It dries pretty fast.
Let the Gummi Pflege dry for about ten minutes. It will be slightly tacky.
me2flsunfish likes this.
Margie and Terry
tcrankwa is offline
#5 Old 03-13-2011
Vehicle: '07 SLK 280
Other Toys: 1986 190E 2.3-16 Cosworth, 2006 Audi A3
Just ordered some, thanks for the info.
rjb190e is offline
#6 Old 03-13-2011
Wizard of ID
tcrankwa's Avatar
Quoted: 20 Post(s)
It's good stuff. Store it carefully or the sponge applicator will dry out.
Gunther likes this.
Margie and Terry
tcrankwa is offline
#7 Old 03-13-2011
Vehicle: 2010 SLK55 AMG
Other Toys: ML500, SL55 AMG
Thanks! I'll have to get some of that even thought my car is brand new.
DEV7 is offline
#8 Old 03-13-2011
Challenge's Best Friend!
Gregg's Avatar
Vehicle: 2009 SLK 350
Chats: 5
Quoted: 15 Post(s)
I agree...the Gummi is a wonderful product. Got too enthusiatic last fall and rubbed the sponged off the end of my bottle, so I'm looking for a replacement applicator. Yet another trip to the dreaded WM I guess!
carlover likes this.
Gregg is offline
The Following User Says Thank You to Gregg For This Useful Post:
#9 Old 04-02-2011
Vehicle: 350 SLK with AMG body styling
Chats: 2
Ive never heard of Gummi.. Had a look for it in my motor suppilers in the UK but no signs..
Is there an equivalent in the UK to buy? If there is where do you get it from?
Ta
alscar is offline
The Following User Says Thank You to alscar For This Useful Post:
#10 Old 04-02-2011
dog1940's Avatar
Vehicle: SLK200Kompressor AMG
Other Toys: Subaru Impreza
Here is a UK seller: http://myworld.ebay.co.uk/carcaredir...id=p4340.l2559
(The stuff's full name, to search for on the site, is Gummi pflege- German for rubber care.)
dog1940 is offline
The Following User Says Thank You to dog1940 For This Useful Post:
#11 Old 04-02-2011
Vehicle: 2012 SLK55 AMG, Diamond White
Other Toys: 2010 TT Black Edition
Quoted: 82 Post(s)
Will be doing this over the next few weeks. Had forgotten about some of those seals. Absolutely swear by this stuff.
Captainrave is offline
#12 Old 04-28-2011
Quoted: 82 Post(s)
Managed to get round to do these seals last weekend - they feel much softer now. Thanks for the pictures, nearly forgot some of the roof seals!
#13 Old 04-29-2011
NUG
Vehicle: 2005 SLK 350 Benitoite Blue
Other Toys: 2011 V-Rod Muscle (VRSCF), 2001 Deuce(FXSTDI)
Chats: 7
Send a message via Skype™ to NUG
Thanks for the tip. This stuff is awesome!
NUG is offline
#14 Old 04-29-2011
Wizard of ID
tcrankwa's Avatar
Quoted: 20 Post(s)
Originally Posted by rubenhak View Post
Thank you for detailed instructions! Will try to apply grease this weekend.
How is it different from R171 models? Does it have extra seals to be greased?
I don't think they're that different. Any 171 guys want to chime in?
If it's a rubber weather seal, go ahead and Gummi Pflege it. It won't hurt anything.
Margie and Terry
tcrankwa is offline
#15 Old 04-29-2011
Vehicle: Silver 2005 SLK 350 6 speed
will 1 bottle work for the entire car?
how often do you apply this? annually?
slk350wdc is offline
#16 Old 04-29-2011
Quoted: 82 Post(s)
1 bottle lasts ages and ages. I apply it every few months when I remember or if I detect any kind of leak.
#17 Old 04-29-2011
I have done all mine twice now. I stop the roof halfway to get at the seals. It never seems to object or show signs of sinking. Am I pushing my luck ??????
JonB is offline
#18 Old 04-29-2011
so glad I found this thread! ordering now from autogeek.net for $8.99 plus shipping (amazon was quoting 1-2 months for delivery). I've been meaning to search for this topic now that i've been driving the car more.
Thanks tcrankwa!
#19 Old 05-03-2011
Vehicle: Jan 2008 - SLK 200 Kompressor - Bright Silver Metallic
For those in the U.K. got mine from the following :-
http://cgi.ebay.co.uk/EINSZETT-GUMMI...#ht_4262wt_905
Excellent service
djsadie likes this.
John V6 is offline
#20 Old 05-03-2011
aka John
Chats: 1143
Quoted: 23 Post(s)
Ruben - with Gummi, I usually don't let it dry - I rub a liberal amount over the seals, then close / open a couple of times..
Krytox, on the other hand, does not evaporate, it penetrates, so you apply a very thin coat and let is sit for 30 minutes or so.
etyu and me2flsunfish like this.
UK-C200 is offline
Human Verification
Gummi Pflege for roof seals jst_at_home General Discussion 14 04-27-2015 01:03 PM
supercharger pulley spring -2004 slk200 zeusthegreatest Where to get R171 SLK Items 7 11-24-2012 06:52 AM
Gummi pflege is in the house sokoloff General Discussion 0 09-24-2009 02:18 PM
Gummi Pflege on all exterior rubber? pepper Caring for your SLK 3 09-23-2009 06:24 PM
