Go Back   Mercedes Benz SLK World Forum > SLKWorld Sponsors > Elite 1 Performance Studio
Elite 1 Performance Studio High End Tuning, from sporty aerodynamic parts like rear diffusers in Carbon Fiber, noble aluminium rims and stainless steel sport silencer up to custom made interior/exterior in Carbon and Leather.
Old 02-09-2010   #1 (permalink)
Vehicle: 2007 SLK R171
Default Power-Converter intermedia
Now significantly cheaper - with even more comfort
Quick Linkhttp://www.elite1autodesign.com
What does the POWER CONVERTER?
The slow response time, which is caused by the electronic throttle, is with the Power Converter completely repealed.
The acceleration - Are already coming out of the idle speed -- "Memorial is no second" very spontaneous, torque and full torque.
The New Generation Power Converter "Race Control" was developed with an even faster chipset and equipped with a separate switch that can be installed just as you like in the vehicle. With the switch at any time, even while driving, the Power Converter on MEDIUM (considerably more agile) or SPORTS () very athletic or in the STATE SERIES be turned off.
The power converter is in two versions available.
Depending on the type of vehicle is the model "Intermedia" RC or "CS" RC To use design.
The range of services at a glance
Clearly powerful Response already from the idle speed and over the entire speed range.
Very fast Response to the throttle.
Full of torque from low revs out already. The driver is subjectively marked by a substantial performance taught.
Ideal supplement to chip tuning, because the power delivery and torque output at low revs is already fully present.
No additional load on the engine, the engine management system will remain unchanged.
Using a separate switch indiviuell also adjustable at any time during the trip.
Significant powerful acceleration and pulling power. Full power is unthrottled immediately available.
Noticeably faster gear changes - Very beneficial and positive when overtaking or when driving on twisty roads.
Significantly shorter Gaspedalweg - Must log occur spontaneously, the change of gear without pressing on to kick down.
Easy Installation (approx. 10 minutes) through plug and play connector. (The module is only zwischengesteckt without) any damage to cables.
The Power Converter can always be removed without leaving a trace and in another Mercedes-Benz will be installed again. Ideal for leased vehicles.
No penalty for vehicle, engine and electronics, which will remain untouched.
View Elite1's Photo Album Elite1 is offline
Sprint Booster VS Piecha power converter kalani Performance MODS for the R171 1 07-15-2010 11:41 PM
SmartTop Roof module Install for the R171 etyu DIY Section 11 08-15-2009 05:31 PM
Grinding/Vibration noise when FULL power Otsego Ask DansSLK 10 07-08-2009 04:20 PM
New Interior Lighting noregret4life General Modifications R171 24 03-14-2008 01:54 PM
Powered by vBulletin Version 3.8.5
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135
