My rearview mirror just developed a bubble type discoloration suddenly.
As this may have happened several days after spraying it lightly with a cleaner. Is it possible to dry it out? If not, I plan to replace it.
I have a 2002 SLK230 and will be looking for a excellent condition used mirror. However, I heard there may be a newer model there might be better to buy. Mine seems to have been made by Donnelly. Any comments about what model or where to purchase it would be appreciated.
Also I would very much like explicit directions as to how to remove it correctly.
How to remove:
If you put your finger on the "foot" of the mirror - close to the windshield - you'll feel a little hole there.
If you push a 5mm- 1/5 inch -rod in that hole, and twist the whole mirror (with "foot") 90 degrees, you can remove the mirror from the gluepad
__________________ [LEFT] To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts.
Gabus[/LEFT]
[LEFT][COLOR=red]The Rolls Royce is the Mercedes amongst cars[/COLOR] To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. [/LEFT]
[LEFT] To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. [/LEFT]
Thank you Gabus for your info.
Now I'm simply trying to remove the section attached to the sunvisors so that I can reach the mirror.
So far:
I've put top down and removed 4 Phillips type screws that were holding the sunvisors on. The 5 foot top section does not want to slide off the windshield easily. It seems to be stuck near the center portion..
Do I need to remove the microphone cover? Pry it off?
Do I need to remove the overhead lens cover? Pry it off?
I was able to figure this out so no one needs to write back. Microphone cap and lens cap come off easily with a small pry screwdriver.
For those with a 2002 SLK, it is necessary to remove two screws underneath the overhead light lens, in order to pull off the 5 foot section that goes across the windshield.
This enables one to reach the mirror to twist it off like Gabus said. It takes quite a bit of force to remove it.
Thanks a bunch for this Mercedes site, as it has been very helpful.
Also helpful was a video showing the actual rearview mirror removal:
Thanks for the great feedback on the mirror. I was able to remove mine by following your tips but also used a vise wrench on the mirror since I ws replacing the old one with a new mirror. It came off really easy that way!
I ended up buying a new one for @ $210 from the dealer versus going through a refurb process.
